| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: 2011 camaro SS/RS Join Date: Nov 2011
underdrive pulley worth it?
SLP's underdrive pulley is it worth getting, do You need anything else to go with it etc...
2011 2SS/RS Airaid cai, ARH HF cats X pipe, SLP LM1, 160stat,RX Catch can, Tuned @ Tune Time Performance, side marker black outs, decepticon bowtie emblems, stealth turn sig. bulbs,Hyper White DTRL Painted GFX, Havoc Spoiler
![]() ![]() ![]() ![]() Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
A bitch to install, and chance of dead battery. Not recommended by me
K thanks
I have this same question and could use some more input. In two weeks I'm having a cam and bolt-on package done. So, I will pay no extra labor for the pulley install since the OEM pulley has to come off anyway. I hear pros about this pullyey such as it's cheap HP (5 - 8 HP for $200 -250). And the risks of a dead battery are oversated since a cammed car will have a higher idle speed anyway and that offsets the lower accessory rpms from the UD pulley. I dunno? I live in SC and the heat is tough on batteries anyway plus I certainly don't want any A/C performance issues. Folks who have a UD pulley on a cammed car - what has been your experience? Would you do it again or not and why? Any feedback would be appreciated.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 45th Anniversary Edition SS Join Date: Jul 2011
You will gain between 10-15hp on average for the UDP, so just figure the $/hp ratio and see if it makes financial sense for where you are at in your mod list.
I have exceeded the character limitation for mods in a signature...
#6 | |
#7 |
![]() Drives: 2002 Camaro SS Join Date: Jul 2009
I have 2 cars with an underdrive pulley and neither one have voltage issues. The install is not bad either as long as you have the right tools for the job.
#8 |
![]() ![]() ![]() ![]() Drives: 2012 5.0 Mustang, Brembo Track Pack Join Date: Jan 2011
Putting one on mine very soon. 5-10 rwhp is what I am hoping for.
2012 Ford Mustang 5.0. Brembo, 3:73s Sold
2012 Challenger 392 auto 12:40s 112 stock Sold 2010 1SS, LS3, Cammed, LTs, NT05R,12:20s Sold Last edited by newmoon; 01-19-2012 at 02:31 PM. |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 E92 M3 Join Date: Nov 2009
i am really into the little things to add HP so i didn't add one.
#10 |
![]() Drives: Camaro SS Join Date: Mar 2010
Pass
Increased my tire pressure for another 5HP.....very easy!
No china cheap bolt-on's, buffet, or yubiwaza here.....
#11 |
Butter Bar!
Drives: 2011 SS, 1998 Trans Am Join Date: Dec 2010
Not worth it IMO, I have better places to spend the money.
2011 Camaro SS, Summit White with Orange Stripes
1998 Trans Am, Red, Functional WS6 style hood, MTI Carbon Fiber Lid, ARH LT's, Magnamouth, LS6 intake, UMI STB, UMI LCA's, UMI LCA Reolcation Brackets, UMI Adjustable Lower A-Arms, BMR Upper A-Arms, UMI 35mm and 22mm Solid Sway bars, BMR Springs, KYB AGX Shocks |
#12 |
Quit being a pu$$y
I have one on every car I have owned. Definitely worth it. Made my 98 SS go 11.0 @ 122 with just bolt ons. Made my 11 Vert go 12.3 @ 113 with just bolt ons and I am also running a tiny 15 lb battery with no voltage issues.
#13 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
I wouldn't think keeping the battery charged would be an issue unless you aren't moving and just idleing a lot.
Heritage Grill, Cold Air Inductions Intake, Elite Engineering Catch Can, BMR 1" Lowering Springs, Sway Bars and End Links, Clear Image Jet Hot Ceramic Coated headers and High Flow Cats, Hurst Billet 2 Shifter, LSR Billet Strut Washers, DynoMax Axle Back Exhaust, JANNETTY MAGIC! |
#14 | |
![]() Drives: 91 Z71, 2010 Camaro SS LSX 454 Join Date: Nov 2008
LSX 454 (nuff said)
#15 |
![]() Drives: 2010 Camaro 1SS/RS 6 Speed Join Date: Jan 2012
Do you still see the same benefits of HP without the cam. I ordered LT with HFs and CAI. Thanks
#16 |
![]() ![]() ![]() Drives: 2011 Camaro 2ssRS Ls3 Join Date: Aug 2010
I was told by my locale gm performance shop that it isn't worth it. Keep in mind they were doing headers and cam install on my car at the time. They said it puts to much strain on other parts just for a few hp. That's what I was told.
#17 |
SScalator
When I was a punk underdrive pullies were installed when final drives were upped so the accessories would spin at stock speed when the car was moving.
Give me fuel. Give me fire. Give me that which I desire. |
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS / 1951 Mercury Join Date: May 2009
Bump.... What is the charging like after the UD pulley, my stock charging is 14-14.4 volts. L99.
2010 Camaro SS | LT's Cats UD CAI Tune DR |12.37@112
1951 Mercury | Chopped | SBC 1998 Formula | 348 TH400 88mm | 9.40@145 sold 2000 Camaro | 348 TH400 150 NOS | 10.0@134 sold ~All installs and tuning by Speed Inc. |
#19 |
i went ahead with the UD pulley as part of my cam install. So far and over 2000 miles later - it is a total non-issue. All accessories run like stock. Guage readings are all normal except for oil pressure which is higher than stock because of the Melling pump.
Vengeance cam, Vararam, ARH-full system, DMH cutouts, Pfadt Stage II springs/sway bars, MGW shifter, Axis "Allies" w/ 275/315 Nitto Invos
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: FSP Join Date: Jan 2011
It's worth it as long as you have no intentions of supercharging or running a large aftermarket stereo system. Other then that, is a cost effective way to free up roughly 10-12 rwhp.
#21 |
So charging near 14 volts? I'm comfortable with the power gain, I've had them before, I just wanted to see if it will have charging issues before I can tune it.
#22 |
Well, you made me go look. It must be me. Everyone always get these exact readings off the console guages ( like 28 psi oil pressure, or 225 degrees oil temp or 14.5 volts). My guages are not that exact or maybe my eyes are not that good. My volt meter reads at or just above the only mark between 12 and 19 which is what it was stock before the UD pulley. I guess that mark is 14.
![]() I think you will be fine. I've had no problems.
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS/RS M6/2500HD Lmm LTZ Join Date: Apr 2012
#24 |
![]() ![]() ![]() Drives: 2009 Pontiac G8 GXP Join Date: Feb 2012
I dont recommend a pulley on a stock engine or a very mild cam that idles low like stock. Once you get to an idle past 800rpm then the negatives about a pulley almost go away.
2009 PBM G8 GXP M6
#196 of 1829 JBA LT headers Spectre intake ![]() |
#25 |
SSDan, you can see the charging volts in that center display, just have to toggle through the options... Oil Life, Coolant Temp, etc. My stock 2010 L99 is 14.4 driving and hasn't gone lower than 14 at idle.
| Thread Tools | |
| TVS2300 & 1900 Pulley Info & Size ... | 8aStang | Forced Induction - V8 | 16 | 11-11-2011 09:55 AM |
| Underdrive pulley? | Rage | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 10-05-2010 06:13 AM |
| TSP Underdrive Pulley for sale!! | dmax86 | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 6 | 09-15-2010 10:30 AM |
| Mods for LS | sheila65 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 37 | 08-16-2010 05:44 AM |
| Underdrive pulley 10-HP gain. | rex113 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 10 | 01-05-2010 06:25 PM |
