ADM PERFORMANCE
Old 01-20-2012, 09:04 AM   #1
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
My experience with Noisy Lifters and Oil Filters
4 weeks ago my L99 with mods in my signature developed a flutter/lifter tick that was very random and only happened on warm starts( engine running for a period of time shut down and restarted a few minutes later). Fearing the worst I figured that the infamous AFM/DOD lifter issus was about to rear its ugly head at 27000 miles.
The weird part was that it only happened on the warm starts up when cranking post shut down and the temps here in FL were typically less than 50 degrees . At first I thought it may have been bad gas/pre- ignition as it was only happening randomly. I switch brands and that was of no help. I then talked it over with my Builder Greg from Anti-Venom; based on how random it was he asked "what oil filter are you using" I mentioned I was using a Mobil filter and oils. He suggested changing the filter which had only about 2500 miles on it and using the standard $4.00 AC Delco oil filter.
Well I went ahead and changed the filter; and no more lifter noise. I realize this is a very UN-scientific assumption on my part. I have always used M1 filter and never experienced this. Perhaps this was the luck of the draw and I received a defective filter that with a bad drain back valve.
Since switching to the AC-Delco filter I have also noticed an increase in oil pressure on cold starts vs the Mobil one filters. For those of you experiencing noisy valve train issues you may want to try the AC-Delo oil filter.
Awaiting 2014 C7
Snake Slayer is offline   Reply With Quote
Old 01-20-2012, 09:37 AM   #2
ron10
Drives: 2010 2SS IOM L99
very interesting.i also use the mobil 1 filter and have a small amount of lifter noise.will have to try the oil filter change.
Old 01-20-2012, 09:48 AM   #3
Russell James
Russell James's Avatar
Drives: Camaros
I use to see that a lot when I was a tech. Tons of aftermarket filters, especially from the cheapo instant oil change places, either don't have the correct anit-drainback valve, or a cardboard one that falls apart. In decades of using AC Delco filters, never once saw a bad one so that is all I'll ever use.
Air filters are the same way. Purolators being one of the most junk. I use to see tons of MAF sensors ruined by cheap Purolator air filters that were shedding little fibers onto the MAF hotwire and screwing it up. An OE AC Delco air filter will never do that. Save $5 on an air filter at jiffy lube, only to ruin a $100 MAF.
Old 01-20-2012, 01:19 PM   #4
Camaro84
Camaro84's Avatar
Drives: 2010 Camaro SS
Doesn't have anything to do with it. I live in south Florida and my lifters did the same thing on warm and cold start ups. The lifter have been redesigned to fix this issue. Had all my AFM lifters replaced last year and they haven't ticked since
Camaro84 is offline   Reply With Quote
Old 01-20-2012, 01:21 PM   #5
Camaro84
Camaro84's Avatar
Get your lifters done before your warrenty runs out!!!
Old 06-02-2012, 12:06 PM   #6
Supermaro585HP
Drives: 2011 Camaro SS RS
Mine makes the same noise. I took it to the dealer and they told nothing was wrong. I put my supercharger on and headers and exhaust and CAI on and I hear it louder. I think I'm pretty much F&^k^D now. This is a problem and it is bullshit that Chevy won't admit to the problem. The oil filter thing is interesting and I will try it but I don't think it is going to take care of it. I will let you know...
Supermaro585HP is offline   Reply With Quote
Old 06-02-2012, 02:10 PM   #7
TrojanRay2418
Drives: 2010 2ss/rs
how did you go about this? ive been given the run around with the dealers trying to tell me its normal.
TrojanRay2418 is offline   Reply With Quote
Old 06-02-2012, 03:52 PM   #8
Dtrimpi87
Banned
Drives: 2010 2SS/RS A6 & 2011 1LT/RS
I have the same lifter tick on random starts. I cant get it to tick reliably so I havent gone to the dealer yet. I have an extended warranty because i bough certified pre owned so I have plenty of time but it bothers me. Im going to do an oil change soon so i will also try the AC Delco filter.
Dtrimpi87 is offline   Reply With Quote
Old 06-02-2012, 04:42 PM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Lifter tick has been around FOREVER. I read a good writeup on oil filters that said essentially the same thing Russell said. They literally cut every known filter in half to see the internals. They found that many had carboard and very week drainback springs. M1 filters were found to be middle of the road. Wix, AC delco, and Purolator pure one filters were some of the best, with Fram overwhelmingly the worst.
For those don't know what a good drainback spring does, it prevents/slows the oil draining from the head, back to the pan. This has been linked to the cold start lifter tick. The better the DB spring, the more oil is kept in the head, thus quicker to pressurize the lifters, less lifter tick.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-02-2012, 05:23 PM   #10
camslambam
Drives: 2010 SS, 06 SRT10 Ram
ls3 conversion.
camslambam is offline   Reply With Quote
Old 06-02-2012, 05:49 PM   #11
Dtrimpi87
Banned
Originally Posted by camslambam View Post
ls3 conversion.
Thats what I will be doing I just cant convince myself to void my warranty yet.
Old 06-02-2012, 07:01 PM   #12
thesaint
Drives: 2011 camaro ss/rs
I am surprised to hear this about mobil 1 filters. I have read too many times on BITOG that Mobil 1 oil filters are some of the best you can buy, and are certainly better than stock.
If you have links to otherwise, I would love to read.
Thanks
thesaint is offline   Reply With Quote
Old 06-02-2012, 07:08 PM   #13
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
ls3 conversion.
NEVER LOOK BACK
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 06-02-2012, 07:28 PM   #14
Vintage-Iron
Banned
Drives: 2012 Chevrolet Camaro 1SS/RS
I havent changed my oil yet since my SS only has 500 miles on it but I am going to change it at 1000 miles and I was going to use Mobil 1 with a AC Delco filter, now after reading this I may just use the recommend oil from GM and also the AC Delco filter...????
Vintage-Iron is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 289 08-26-2017 12:29 PM
AFM turned off by my dealer???? fastfreddie 5th Gen Camaro SS LS LT General Discussions 95 08-25-2012 03:55 PM
Need Mechanics Help with Oil Pressure Issue on 1999 3.8 Camaro Solocus 4th Generation Camaros 8 05-06-2011 10:49 AM
L99 Lifters Ohten Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 25 06-29-2010 10:33 AM
GM's OLM & synthetic oils. duder4thgen Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 03-24-2010 12:37 PM
