sjm autoprod
Old 01-20-2012, 04:12 PM   #1
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
3 new cams from lunati for ls3!
So after my months of beating my head into the ground on a cam for my car, I finally found the one! Lunati just came out with 3 grinds made just for ls3 heads, they are not on the web site yet but are available. They have basicly 3 stages and I am going with the middle one.
218/228 @05 .549/.566 112lsa 108icl RPM range 1800-6400
This cam is way off from the normal cams being run that I see, but I am pumped to try! Will be running this on the stock ls3 springs as well. Tech told me this cam will have a some what lopy idle and make allot of mid range power with a good boost in top end. I was going to run there 222/228 and was informed by tech that cam is ment more for an ls2 and would not run as good. I am hopping for about 450hp at the wheels with a sick torque curve with this little cam . Hopfully next month the weather will start to break and its going in, cant wait
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 01-20-2012, 04:32 PM   #2
NinoSS
Drives: 2SS/RS CGM LS3
Good Luck!!! I went for a small cam as well, I got 442/417 to the wheels with the power right off idle.
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 01-20-2012, 05:13 PM   #3
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
I love Lunati, I have tried a ton of cams, and I like them the best. Well in old school cars. Not to sure about the LS3, But now you have me wanting to do a LS3 conversion just to have another lunati cam.
mgoodbar is offline   Reply With Quote
Old 01-20-2012, 08:14 PM   #4
Bad70supreme
Yes I trust lunati, they did me good in my olds! I have been reading allot of threads were guys were trying to run bigger cams with a small split and not getting the performance they expected. 2 guys ran 218/226 cams and said they out performed the 226/232 cam all the way till 6000rms. So I think lunati has done some home work on this!
Old 01-20-2012, 08:17 PM   #5
Transfusion
Transfusion's Avatar
Drives: 1SS Summit White
I saw there PDF on all the new cams yesterday. they had 3 for the ls3 and 3 for ls3 with hot heads ( not sure if this was the exact verbage). I'll see if i can find it again and post it, cause it has all of the info.
Found it.
http://www.lunatipower.com/Media/Doc...0LS%20Cams.pdf
Transfusion is offline   Reply With Quote
Old 01-20-2012, 08:27 PM   #6
Bad70supreme
Yep that's it!
Old 01-21-2012, 09:25 AM   #7
newmoon
newmoon's Avatar
Drives: 2013 Boss 302 RR
Not sure on the specs as I really don't claim to have any knowledge on camshaft specifications but I am running a Ed Curtis Lunati custom grind and I am plenty happy with it. It may not pull the peak numbers others are seeing with the larger grinds but I will say if drives better than stock has a nice lope and great below peak curve.
2013 Boss Mustang - Present Toy
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 01-21-2012, 10:34 AM   #8
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
I would suggest you upgrade the springs.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Lunati Voodoo Cam Video (233/245) Bell040 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 33 11-03-2014 09:09 PM
Zex bought out by Competition cams? ROD1 Forced Induction - V6 11 07-14-2010 12:00 PM
Competition CAMS nearly ready to release their L99 cams for the VVT AND AFM! PatrickfromMD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 07-30-2009 06:46 AM
CRANE CAMS IS DEAD TFord Off-topic Discussions 0 03-26-2009 01:38 PM
For the L99 Hesh Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 01-11-2009 12:44 PM
