01-21-2012, 02:56 PM | #1 |
Drives: 2010 Cyber Grey Metallic 2SS/RS M6 Join Date: Nov 2009
Upgrading from Pfadt lowering springs to Pfadt coil overs?
Hello all,
Was wondering what is the difference in feel between Pfadt lowering springs on stock struts vs Pfadt coil overs? I will be upgrading this summer but wondering if I can expect the ride quality to be better on coil overs? The ride quality on the lowering springs isn't that bad, but it is still somewhat harsh going over bumps. Do the coilovers "feel" the same roughly? |
01-21-2012, 03:27 PM | #2 |
With the coil overs not only will you be able to adjust ride height but you can also adjust the ride to how you want it. Going to the Pfadt coil overs will be a BIG step up.
01-21-2012, 05:27 PM | #3 | |
I'm not totally useless..
This! Though I personally feel the spring rates are too soft in the rear but that has been somewhat easily fixed with new springs!
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
01-21-2012, 05:48 PM | #4 |
Drives: Victory Red SS Join Date: May 2011
When u are ready to sell your lowering springs i will take them off your hands.
01-21-2012, 05:57 PM | #5 |
The ability to do exactly that with the Pfadt coil overs is one of the things that sets them apart. While most other coil overs on the market use custom wound springs, which limits you to their spring rate, the Pfadt system uses standard sized race springs allowing hundreds of spring rates possibilities in 25 lb/in increments. The standard spring rate combination (275 lbs/in front and 500 lbs/in rear) works great for most people, but the flexibility is there for those that need it.
01-22-2012, 11:03 AM | #6 | |
Hmmm, interesting. There must have been a change made. Probably "inspired" by me! Mine came with 275 front and 450 rear. I had to "convince" Aaron when he was replacing the fronts (to correct the "coil bind" problem us early adopters had and is no longer an issue) to give me 500 rears. And I found the 500's to be too soft for my taste (even with the adjusters cranked full) and have gone to 600's...but yes, it is as simple as buying new springs and swapping them out. Tho the process is not for the faint of heart. The rears are a bit of work!
01-22-2012, 10:46 PM | #7 | |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
At full stiff, it's a stiff ride, but your car will handle like it should (especially with Pfadt sway bars). Plus the ride height adjustment is awesome. Whether you install yourself or get it done, I'd play with it a bit to see what you like. I found the car handles and brakes muchbetter with some rake (front lower than rear). Make sure to measure before so you know how much to lower at each corner. Good Luck!
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
01-23-2012, 01:18 PM | #8 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
The great thing about coilovers is by replacing the factory strut with one of our own design we aren't limited by the capabilities of the factory struts. Like Avalnch touched on there is a wide range of adjustability that's available with the coilovers, so you will be able to tailor the ride quality to what ever it is you're doing.
If you're just daily driving the car you can expect the ride quality to actually increase over a drop spring package, depending on where you have your dampers set. Of course your track and aggressive street handling settings can be quickly changed so when you really want the car to perform it's an easy swap. Most users will likely never swap springs with our coilovers, we selected spring rates that would be great for most users looking to improve handling and ride quality. For those folks who prefer a more aggressive ride or heavily tracking their cars we do have spring rates available that will get your Camaro performing the way you want it too. If anyone has questions about our coilover products let us know! They're definitely my favorite product in our Camaro lineup. |
01-23-2012, 01:50 PM | #9 |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
I went from Pfadt drop springs to their coil overs. All I can say is that it was one of the best mods I've done next to the Whipple. I autoX and drive in the canyons and they make the car feel so much better. Well worth it.
01-23-2012, 02:35 PM | #10 |
I sent a client of mine this thread ( Darth Emma ), she in fact did just what you are doing. I will have her give you a good testimonial!
Best Regards |
01-23-2012, 03:01 PM | #11 |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
Brandon is right. I did exactly that last spring. I switched from Pfadt spring to Pfadt coilovers.
I thought the Pfadt springs were a great upgrade from the stock springs. They lowered the center of gravity of the car and made it corner much better with much less body lean (I also had Pfadt sway bars and end links installed with the springs). I drove on the Pfadt springs for about a year. This past April (2011), I decided that I wanted to try coilovers because I wanted the adjustability that comes with them. There are setting for street driving, drag racing, and road racing. There are also various setting for ride height. You can set the "stiffness" (dampening) of the coilovers by turning a small ring on them. There are 20 clicks of dampening adjustment, so you can set how hard or soft the car rides. The dampening adjustment is very easy to make and you can adjust the ride depending on where/how you drive. Most of the time, I like the "sporty street" setting (which is right in the middle at a setting of 10). Look at the last page of this document to see how the dampening is adjusted: http://www.pfadtracing.com/blog/wp-c...stallation.pdf You can also adjust the ride height. I have my car just a tad lower than it was with the springs. I really like the low stance. Adjusting ride height can also be done pretty easily, but you will need to have the car realigned if you change the ride height. Here is a picture of my car on the coilovers. So, it sounds like the coilovers will give you what you are looking for because you can set them for softer ride by going to lower dampening values. The down-side is that coilovers cost significantly more than springs. But, they are worth it to me. |
01-23-2012, 03:23 PM | #12 |
I will vouch for the greatness of the Pfadt coilovers. The adjustability is easy to use even without ramps. Add their swaybars and motormounts for a great package!
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles. Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump. 907rwhp. |
01-24-2012, 10:38 AM | #13 | |
01-24-2012, 11:39 AM | #14 |
Supercharged LSX
They work great and look like they mean business!
Thread Tools | |
Similar Threads | ||||
Suspension and adjustment coil overs (help) | qtr-camaro ss | Suspension / Brakes / Chassis | 35 | 08-15-2011 06:16 PM |
Pfadt lowering springs | Blk11SS | Suspension / Chassis / Brakes | 8 | 06-28-2011 04:40 PM |
Camaro Pfadt Race Engineering Coil Overs | PfadtRacing | Wheels and Tires Talk Sponsored by The Tire Rack | 16 | 03-29-2011 09:10 PM |
Pfadt lowering springs...help | toonlovescheryl | Suspension / Brakes / Chassis | 10 | 09-30-2010 02:14 AM |
BMR Lowering Springs - How It's Made | BMR Suspension | Suspension / Brakes / Chassis | 40 | 06-22-2010 10:32 AM |
