HeadlightArmor
Old 01-21-2012, 09:24 PM   #1
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
WTB: OEM TPMS
PM if you have !
Paypal ready to go
Thanks !
BronxxBombers213 is offline   Reply With Quote
Old 01-25-2012, 08:51 PM   #2
BronxxBombers213
bump !
Old 01-26-2012, 02:00 PM   #3
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I have 2 TPMS sensors that were taken from new take off wheels along with 3 new OEM in the package valve stems for the TPMS sensors. Make me an offer.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 01-28-2012, 05:25 PM   #4
BronxxBombers213
nevermind... i just read up about all the issues with TPMS and the change in part numbers... going to wait until I actually get a camaro so i know which ones i will need
Old 02-03-2012, 11:02 PM   #5
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Ed M.
Will these work on a 2010 2ss?
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 02-04-2012, 05:46 AM   #6
flht99b
flht99b's Avatar
Yes.
Old 02-07-2012, 10:54 AM   #7
DaILLestWun
Drives: 2006 Dodge Magnum
How do you know which ones work for which? I have a set but they are still mounted to the 18" LS wheels. Would those only work for LS wheels or would they also work for the others??
DaILLestWun is offline   Reply With Quote
Old 02-09-2012, 04:06 PM   #8
Kwik
Drives: car
Here is what you need. Follow the link.
http://www.customwheelsexpress.com/2...-of-p-796.html
Upgrades to suspension, brakes, motor and appearance. 482.7 RWHP- 434.2 RWT - All motor.
Kwik is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
WTB OEM WHEELS 20in or 21in arod41 Wheels / Tires 4 01-03-2012 09:00 PM
WTB set of OEM Lug Nuts rjp2010 Wheels / Tires 1 09-18-2011 12:41 PM
WTB : Stock 20" Pirelli PZero Takeoffs. Also OEM brake pads. USIRON Wheels / Tires 0 08-31-2011 12:02 PM
