Dynomax Exhaust
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
1st & 2nd Generation Camaros 1967-1969 Camaros / 1970-1981 Camaro
Old 01-22-2012, 12:52 PM   #1
shy68
shy68's Avatar
Drives: 2010 2lt RS,Have 68,69 camaro
How rare is this car? 1969 ss
It is a 1969 ss x11 350 300hp 3:73 grear 4 speed con/w gauges, chrome package, stripe kit on the side,black vin top, houndstooth inter.butter nut yellow. It was used as a race car and alot of things are gone. thanks
shy68 is offline   Reply With Quote
Old 01-22-2012, 01:46 PM   #2
shank0668
shank0668's Avatar
Drives: Pontiac
Send a message via AIM to shank0668
15k?
Condition?
Old 01-22-2012, 01:48 PM   #3
midnighter
midnighter's Avatar
Drives: 2010 Chevrolet Camaro SS 6M
Pics
Old 01-22-2012, 05:39 PM   #4
shy68
shy68's Avatar
Just wanting to know if their was a lot of 69's with the option's listed? Thanks
Old 01-22-2012, 06:18 PM   #5
trz174
Drives: Yes
Suggest you check and verify any info you get with the Camaro Research Group info at camaros.org.
1967 Camaro Bowtie, 327, 4L60E, Bahama Blue
2010 Camaro 2LT, RS, IBM
2012 Camaro ZL1, AGM
trz174 is offline   Reply With Quote
Old 01-22-2012, 06:28 PM   #6
talwell
talwell's Avatar
Drives: 1969 LS1 Camaro
Nothing about it sounds overly rare. Being an X55 small block car they are not nearly as much in demand as big block X22 and X66 cars.
talwell is offline   Reply With Quote
Old 01-22-2012, 09:27 PM   #7
shy68
shy68's Avatar
houndstooth interior?
Old 01-22-2012, 09:35 PM   #8
ron10
Drives: 2010 2SS IOM L99
if it is a matching numbers car it would be rare.
Old 01-24-2012, 11:37 AM   #9
GrnMchin
Not easy being Green
GrnMchin's Avatar
Drives: 67 Nova SS
Some reading will help try the link. Not all X11 car where SS, but if it is a SS then how complete and original is the car? It helps the value if it is a SS and documentation is key (Build Sheet)to find out how rare the car is and what it came with as far as opt. 36k or so Camaro's in 69 where SS and the SS 350 was the base motor for SS car's.
http://www.camaros.org
GrnMchin is offline   Reply With Quote
Old 01-24-2012, 07:45 PM   #10
shy68
shy68's Avatar
It is just a shell, I went and talked to the guy that bought it in 1973.He was telling me some of the things that it had,plus looking up the numbers on line. Just woundering if houndstooth and butter nut yellow was rare? On a 69 ss.
Old 01-24-2012, 10:09 PM   #11
shank0668
shank0668's Avatar
Drives: Pontiac
Ebay what a shell goes for. Id say 8k if its real nice?
Old 01-24-2012, 10:54 PM   #12
Gramps69Z
Still waiting on the Z
Gramps69Z's Avatar
Drives: 69 Z/28, 06 Denali, 09 CTS
Send a message via AIM to Gramps69Z Send a message via Yahoo to Gramps69Z
Butternut Yellow was code 40. Is that on the trim tag?
Look at the link GrnMchin gave. http://www.camaros.org
2 years 7 months to go!
1969 Chevrolet Camaro Z/28
2006 Denali
2009 Cadillac CTS
The Six Old Guys
The last thing we want is to ship something that isn't right.
Gramps69Z is offline   Reply With Quote
Old 01-25-2012, 12:15 AM   #13
GrnMchin
GrnMchin's Avatar
Drives: 67 Nova SS
Houndstooth and butter nut yellow are not rare by themselves, but as far as how many 69 ss car came w/ that is hard to say. The houndstooth is readily available and easy to convert. The build sheet is key to bring back a car and have the proof. GM did not do a great job in the early days of tracking all the options and # of car produced w/ those option and is why the build sheet is key. As a shell it's only worth that (a shell)
Old 01-26-2012, 12:18 PM   #14
FosterSS
Guardians Of The Night
FosterSS's Avatar
Drives: 2011 2SS/RS Black M6 1968 SS 396
Originally Posted by GrnMchin View Post
Houndstooth and butter nut yellow are not rare by themselves, but as far as how many 69 ss car came w/ that is hard to say. The houndstooth is readily available and easy to convert. The build sheet is key to bring back a car and have the proof. GM did not a great job in the early days of tracking all the options and # of car produced w/ those option and is why the build sheet is key. As a shell it's only worth that (a shell)
^^This is what im starting to realize...Makes it tough to match the numbers on the Fisher production bodies. I was looking at a 69, that was made out of the Norwood plant, but its hard to actually know if its an SS or not. The X11 codes like stated above could still be a V8, but a 327. The base SS was a 350. Correct me if im wrong?
LS3 - Comp Cam Stage 2 custom, LG LT's/full 3" exhaust w/HF cats/2" drop springs/sways/endlinks, K&N intake, VMax ported TB and intake manifold, RX catch can, SLP UD pulley, Melling H/V, ADM scoop w/relocator kit, LSR short shifter, AAC tinted markers/red halos/Afterburners, blacked out with custom flat black vinyl stripes, custom dyno tune...471rwhp/429rwtq (without UD pulley and ported IM, so give or take a few HP)
1968 SS 396- awaiting to be resurrected...
FosterSS is offline   Reply With Quote
Old 01-26-2012, 05:44 PM   #15
shy68
shy68's Avatar
The ss had disk brakes. 350 300hp
Old 01-27-2012, 11:08 AM   #16
GrnMchin
GrnMchin's Avatar
Drives: 67 Nova SS
Correct.
Old 01-27-2012, 06:20 PM   #17
FosterSS
FosterSS's Avatar
Correct.
How does it work for the 68's then? On the Fisher stamps there are no "X" codes. How would you know if a 68 SS 396bb is true? VIN?
Old 01-27-2012, 08:54 PM   #18
GrnMchin
GrnMchin's Avatar
Drives: 67 Nova SS
In 67/68 look at the engine code section of the protect o plate. Engine codes in 68 for 396 car's are as follows. All 396 cars if equiped from the factory where SS.
MQ 396/375 all
MT 396/375 w/alum head
MX 396/350 Man trans
MR 396/350 Auto trans
MW 396/325 Man trans
MY 396/325 Auto trans
Old 02-05-2012, 09:49 AM   #19
Shu71
Drives: 2011 Camaro RS M6
x-11 code on the cowl tag alone does not make it an SS. That code was nothing more than a 'dressup' code which included the chrome trim along the rockers, around the wheel wells, the gills, around headlights and taillights and the roof drip edge. Be careful there are a lot of claimed SS350 cars out there with only the X11 code that were in fact just plain jane 327 or 307 cars. Check further; rest of the codes on the cowl and drivetrain codes.
On the cowl tag you will find the interior and exterior codes. If it were butternut yellow it woud have a 40 right before the PNT. It would also include a B or E for the vinyl top. This is on the seond line right side under BDY which is the partial VIN number. If it had houndstood, it would have either a 713 or 729 code in the TR (trim) area left side under ST69 124379. SS350's have the X55 code under the PNT section. Under the TRM section you will find the build date code. If it were built after the second week of December (12B) it would have that X55 code. Prior to that build date and it may not. If not you need to find the protect-o-plate or build sheet. The 350SS engine would have a HA code on the engine pad stamp if it were a 4 speed car.
As far as how rare it is that would be difficult to determine but you may be able to call Classic Industries and see if they can give a rough estimate on how many were built like that.
Shu71 is offline   Reply With Quote
Old 03-01-2012, 01:32 AM   #20
BURNT ORANGE SS
BURNT ORANGE SS's Avatar
Drives: 2011 IOM Camaro 2SS LS3
If it doesn't have the original motor, then it could be nearly impossible to tell if It's an SS without documentation. I say this because an X11 car could be a plain Camaro or an SS. Drop the gas tank and look above it to find the original build sheet. You might get lucky and it could be still there.
BURNT ORANGE SS is offline   Reply With Quote
Old 03-01-2012, 12:52 PM   #21
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Drives: 2010 SS M6, Each Gen Camaro
For 68, if there is no build sheet, no protect o plate and it does not have the numbers matching motor there is no definate way to tell if it is a true SS, the only thing you can really tell is if it was a V6 or V8 car without those. That being said when I purchase a first gen camaro I don't consider it an SS without one of those to prove it.
Case in point I have bought 2 68's the first one was a really beat up SS/RS, but had both the build sheet and the protect o plate. The second was a V8 car with indicators that it may be an SS such as the floor mounted auto shifter without a console and a few other little things, this car was in alot better condition than the SS/RS, but I paid less b/c there was no documentation.
K1SSRSS is offline   Reply With Quote
White Lightning....The Story Begins CamaroKid300 Member Car Journals 345 05-04-2013 07:44 PM
Blue Rush - Mindz' Supercharged 2SS [COTW 3/22/10] Mindz Member Car Journals 1135 05-02-2013 01:40 PM
Beautiful 1969 Camaro SS Big Block 4-speed for sale babaron Autos For Sale / Wanted 7 01-14-2012 01:06 PM
A Car Love Affair - My Story Dr. Love Member Car Journals 3 01-03-2012 07:04 AM
Humbled 1969 on floor w/GM's American Pride L36L72LS3 1st & 2nd Generation Camaros 5 10-11-2011 09:53 AM
