BORLA
Old 01-22-2012, 07:18 PM   #1
bto131
bto131's Avatar
Drives: 2LT/RS White with orange stripes
orange footwell lighting
i have the orange interior and i was gunna put in footwell lighting and i want to c wat the amber color is cuz i cant tell if it would like good compared to the red... and wat does SMD and CCFL mean as far as the lights go
2011 2LT RS
this is my build plz check it out and give me any ideas and ur opinion
http://www.camaro5.com/forums/showthread.php?t=195089
bto131 is offline   Reply With Quote
Old 01-22-2012, 08:26 PM   #2
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
SMD are surface mount diodes (solid state LEDs) while cold-cathode fluorescent lamps (CCFLs) are just that, tubes. The CCFL requires a converter which bumps the voltage to the tube. The LEDs should theoretically last longer than the car, CCFL will have a shorter life span. I don't know what the life span is of the CCFL.
What I noticed based on the AAC aqua SMDs I bought, they consisted of a mix of colors to get the aqua color. If I ran my hand across the SMD strip, I could see three colors (blue, aqua, and green). I called AAC about this and I'm supposed to get replacements so not sure if the new set will fix this. The CCFL from what I can see is a consistent color throughout.
I can't say if you would have the same issue I have with SMDs in orange, but it takes yellow and red to make orange. Although I have some single LEDs in orange and they are consistent in color.
bannonm is offline   Reply With Quote
Old 01-23-2012, 12:30 PM   #3
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
This is what the amber kit will look like:
We stopped offering CCFL for the Camaro because passengers tended to kick and break the tubes. You can kick the SMD all you want and it will not break
www.AACstyle.com
AACstyle is offline   Reply With Quote
lighting, orange footwell
Anyone have the Footwell Lighting Kit Installed? wildthing001967 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 12 07-03-2011 06:00 PM
AAC Footwell Lighting! CamaroCowboy Cosmetics and Lighting Modification Discussions 35 03-18-2011 02:18 PM
AAC Footwell Lighting! CamaroCowboy USA - Texas 0 02-28-2011 10:33 PM
Footwell Lighting from 2011 Special Editions (SEMA) TripleB Cosmetics and Lighting Modification Discussions 13 02-21-2011 11:33 PM
interior footwell lighting WILDRACER Cosmetics and Lighting Modification Discussions 1 12-25-2010 07:38 PM
