autoguy
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 04-23-2009, 06:09 PM   #1
SSCamaro2010
SSCamaro2010's Avatar
Drives: 2010 Camaro 1ss/rs
Aftermarket Cold air intake
Does anybody know of any other cold air intake other than the one that GM offers, IF so what?? Also is the one that GM offers, is that one just good enough???
SSCamaro2010 is offline   Reply With Quote
Old 04-23-2009, 06:16 PM   #2
ShnOmac
ShnOmac's Avatar
Here ya go..... Doesnt look like any CAI out there yet....
Originally Posted by Milk 1027 View Post
I want to get all the known performance products for V8 in one thread to keep organized and make them easier to find.
V8 (LS3, L99)
Headers:
GMPP shorty headers:
http://www.gmperformanceparts.com/se...o_sitelet.html
$1000
part number: 92213295 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
Borla T-304 steel headers:
http://www.jegs.com/i/Borla/157/17249/10002/-1, http://store.summitracing.com/partde...5&autoview=sku
$915.99
Catback exhaust:
GMPP catback exhaust system:
with tips $950 part number: 92206992
without tips $750 part number: 92225672 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
GMPP Track Pack (off-road only):
part number: 92231570
Borla GM catback exhaust system + X pipe:
http://www.borla.com/applications/lo...X_pipe/140280/
part #140280
$1,449.99
http://www.borla.com/applications/lo...X_pipe/140281/
part #140281
$1486.99
Magnaflow Street Series:
http://www.magnaflow.com/02product/s...one=all&id=121 2.5 in. system, Dual Split Rear Exit.
part number: 16579
http://www.magnaflow.com/02product/s...one=all&id=123 2.5 in system, Axle-back, Dual split rear exit.
part number: 16581
Magnaflow Competition Series:
http://www.magnaflow.com/02product/s...one=all&id=122 2.5 in. system, Dual split rear exit.
part number: 16580
http://www.magnaflow.com/02product/s...one=all&id=124 2.5 in. system, Axle-back, Dual split reaer exit. part number: 16582
Air Intakes:
GMPP Air Intake:
$450 part number: 92212302 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
Suspension:
Pedders Suspension:
http://www.peddersusa.com/products/21
Camaro Street I
Camaro Front Radius Rod Bush, Item code: EP6577
Zeta Differential Mounts, Item code: EP1167
Zeta Rear eXtreme Sub-Frame Co, Item code: EP1169
price: $349.99 with package, $545.95 indidvidually
https://secure.merlinsoftware.com.au...&Level2=CAMARO
Sport Package
Zeta eXtreme Adjustable Sway Bar Kit, Item code: 429006ADJKIT
price: $699.99 with package, $891.15 individually
Camaro Street II
Zeta Front Left GSR Strut, Item code: 9464L
Zeta Front Right GSR Strut, Item code: 9464R
Zeta Front Sport Coil 634mm, X2, Item code: 2954
Zeta Rear GSR Shock, X2, Item code: 9295
Zeta Rear OE HD Rear, X2, Item code: 2957
price: $1,299.99 with package, $1582.42 individually
Camaro Track II
Zeta Front Control Arm Inner, Item code: EP6561
Zeta Rear Control Arm Lwr Out, Item code: EP7266
Zeta Rear eXtreme Sub-Frame Co, X2, Item code: EP1169
Zeta Rear Sport Coil 643mm, X2, Item code: 2955
Zeta Rear Toe Link Inner/outer, Item code: EP7267
Zeta Rear Trailing arm Inner, Item code: EP7265
Zeta Steering Rack/Pinion Mnt, Item code: EP2112
Zeta Upper Control Arm Rearwar, Item code: EP7263
price: $2,999.99 with package, $3,372.56 indidvidually
Eibach Springs:
http://eibach.com/cgi-bin/start.exe/eibach/index.html
Pro-Kit (performance lowering springs):
part number: 38144.140 http://eibach.com/cgi-bin/htmlos.exe...72939200009395
Sportline Kit (extreme lowering springs):
part number: 4.14438 http://eibach.com/cgi-bin/htmlos.exe...72939200009395
Anti-Roll-Kit (Both Front & Rear Bars):
part number: 38144.320 http://eibach.com/cgi-bin/htmlos.exe...72939200009395
Shifter
Hurst Short Throw Shifter: http://www.gmperformanceparts.com/se...o_sitelet.html
$300 part number: 92214388 http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
Brake Systems
*1Baer Complete System (Pro-Plus):
http://www.baer.com/products/complete/pro-plus.php
6 piston calipers and 13” or 14” slotted, drilled and zinc washed, 2 piece rotors.
*Will fit under 18 inch wheels.
Price: $1820.95 for complete front system, same for rear system.
Tune
*5Tune Time Performance:
http://www.tunetimeperformance.com/z...ain_page=index
Costum dyno tunes
Packages
*5MAST Motor Sports 2010 Camaro Track Packages:
http://www.mastmotorsports.com/page....ackages&id=117
Fast - Stage I Stage Strip Package
"525 Flywheel HP"
• Mast L99 VVT Phaser series cam for auto trans. Camaro SS
• Mast LS3 Single Bolt series cam for manual trans. Camaro SS
• Mast premium nitrided valve springs
• Brings your Camaro alive with a nice noticeable lopey idle
Options and Upgrades
• EFI Live AutoCal Module with Mast Motorsports Calibration
• Muscle Rods long tube headers
• Muscle Rods exhaust systems
• Mast Black Label high flow fuel rails
• Mast Black Label roller rocker arms
Mast Motorsports recommends that every cam install using stock controller is accompanied by a calibration tune using HP Tuners, EFI Live, or equivalent software. Calibration is available from Mast Motorsports.
http://www.mastmotorsports.com/page....ackages&id=114
FASTER - Stage II Track Package
"545 Flywheel HP"
• Provides a more aggressive idle and the power to get you down the track quicker
Options & Upgrades
http://www.mastmotorsports.com/page....ackages&id=115
FASTEST - Stage III 12 Deg Competition
• Mast Black Label LS3/L99/L92 cylinder heads (rocker arms not included)
• The same gains as Stage II with the addition of Mast Motorsports Black Label LS3/L99/L92 cylinder heads for the ultimate in 2010 Camaro performance (cylinder head flow data and horsepower ratings coming soon)
Options & Upgrades
http://www.mastmotorsports.com/page....ackages&id=116
Forced Induction
Turbo
*7Aerocharger:
http://hiperturbo.readyhosting.com/store/product24.html
coming soon.....
more to come..............
Coming soon!!:
*3Kenne Bell Superchargers
SLP Performance parts
LPE Performance parts
Harrop Superchargers........ performance parts?
Pfadt suspension parts
*3Magnuson/magnacharger
Kooks headers
American Racing headers
STS Turbo??
Procharger
Corsa Exhaust
*4Varam
*4MGW
*4Spin Tech
*2SSBC
Vortech
K&N
ADM Performance
*6AEM intakes
WARNING: Prices are subject to change. Check here for dealer prices on GMP parts. http://www.gm.oeaccessories.com/Home/
P.S. If anyone finds other upgrades for the Camaro please post the link and I'll edit this post.
P.P.S.: Now adding info for superchargers and turbochargers.
I NEED HELP FROM MORE KNOWLEDGABLE PEOPLE ON THIS SUBJECT!!!
Credit:
*1: XanthosV6
*2: FoxMarketingCars
*3: blackedout010
*4: POWERFREAK
*5: Matt TuneTime
*6: Ken AEM
*7: VictoryRed08
ShnOmac is offline   Reply With Quote
Old 04-23-2009, 06:26 PM   #3
SSCamaro2010
okay, is the one GM offers, is that one just good enough?
Old 04-23-2009, 07:10 PM   #4
Gary B
Gary B's Avatar
Drives: 12 SS 45th
Be a TON of them on the market soon enough!
Got the itch for a Camaro again....Itch is now scratched...2012 45th SS LS3
Gary B is offline   Reply With Quote
Old 04-23-2009, 07:25 PM   #5
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
I would say wait..There will be plenty of them out there very soon, and they will out perform the GMPP
ZZcamaro is offline   Reply With Quote
Old 04-23-2009, 09:36 PM   #6
SemperFi
U.S. Marine Corps
SemperFi's Avatar
Drives: 2009 Ducati Streetfighter
Yup. Give it a few months at least. or look at G8 intakes.
Texas Residents: Join the Texas social group!
Semper Fi!
SemperFi is offline   Reply With Quote
Old 04-23-2009, 09:39 PM   #7
dodson914
Drives: 2008 2500 HD; 2008 G8 GT #199
I'm hoping roto-fab has one made up quickly. They made a good one for the G8.
dodson914 is offline   Reply With Quote
Old 04-23-2009, 09:49 PM   #8
ZZcamaro
Look at the G8 over the radiator intakes...especially from New Era. wink wink
Old 04-23-2009, 09:56 PM   #9
dodson914
I was wondering about those. My first intake was from New Era for the G8. Wasn't too happy, but they did a great job customer service wise.
Old 04-23-2009, 10:36 PM   #10
ZZcamaro
I think you will see some real nice stuff in just a month or so...so EVERYBODY should wait and see what comes out.
Old 04-23-2009, 10:51 PM   #11
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
zz u gotta let me know when u get somethin real nice
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 04-23-2009, 11:58 PM   #12
beausbriggs
2G1FT1EW3A9113560
beausbriggs's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to beausbriggs
Will after markets void the warranty?
2SS/RS LS3 CGM/Black
2G1FT1EW3A9113560
1000, Dealer Order (4.06.09)
1100, Preliminary order accepted (04.09.09)
2000, Order accepted by GM (4.16.09)
3000, Order accepted by production control (4.21.09)
3100, Order available to sequence (5.14.09)
3300, Order scheduled for production (5.14.09)
3400, Order broadcast (5.21.09)
3800, Order produced (5.29.09)
4000, Available to ship (5.29.09)
4200, Shipped (5.29.09)
4800, Rail Ramp Unload (5.30.09)
5000, Delivered to the dealer (6.10.09)
6000, Delivered to the customer (6.11.09)
beausbriggs is offline   Reply With Quote
Old 04-24-2009, 09:15 AM   #13
TBM
Drives: '01 Z71, '10 Camaro SS
*bump* Good question.
TBM is offline   Reply With Quote
Old 04-24-2009, 09:19 AM   #14
ZZcamaro
You know I will. But they will probably be just as expensive as the GMPP....howver, they will greatly outperform the GMPP!!!
Old 04-24-2009, 09:21 AM   #15
dodson914
There a LOT of threads on this already. If you replace the CAI, the intake is no longer under warranty. Any problems that result from the CAI being on there will also not be warrantied. Your entire warranty will not be voided because of the CAI. Some dealers may try to tell you this but that is NOT true. So if that's what your dealer tells you find another dealer. If you don't have another dealer around you, it's your call what to do. They can make it a real headache for you if they want to. It's been my experience that they don't care about CAI and exhaust mods.
Old 04-24-2009, 09:45 AM   #16
TBM
Gracias.
Old 04-24-2009, 01:15 PM   #17
tones2SS
tones2SS's Avatar
Drives: 13 Roush S3 05 Dodge Ram Daytona
Thumbs up
Good post.
This should be a sticky!!
As far as I know, changing out the CAI/headers or what not, it definitely will not be covered by your GM warranty UNLESS you use the GM Performance parts.
Old 04-24-2009, 01:24 PM   #18
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: 2010 1SS/RS IBM
Originally Posted by tones2SS View Post
Good post.
why?
My thread with all the info shnomac posted is already a sticky.
click the links in my signature.
Old 04-24-2009, 01:25 PM   #19
dodson914
Good post.
I've heard a few others say that as well. I am not sure that is the case. Can someone who works for a dealer or GM verify that?
Old 04-24-2009, 01:29 PM   #20
tones2SS
tones2SS's Avatar
Red face
why?
Just saw it.
SORRY!!!
Old 04-27-2009, 09:40 PM   #21
Late Model Racecraft
Drives: 98 Camaro and 05 Corvette
We are currently researching and developing the best cold air intake system for the new 2010 camaro. We will be living on the dyno and the track the next few weeks to make sure we have the best kit on the market.
As for the warranty issues, the aftermarket cold air system and header system will only void your current induction and exhaust warranty.
If any of you have any further questions or wish to get in on our initial group buy rate please feel free to shoot me a pm or just give me a call at the shop. For those of you around the country who have not heard of my company please feel free to just google our name or pick up any of the latest magazines. Our track results speak for themselves.
Late Model Racecraft is offline   Reply With Quote
Old 04-27-2009, 09:47 PM   #22
ZZcamaro
Keep in touch with me on this one. I will have access to much more info on a new intake around the middle of may. I will have pictures and all details at that time!!!
Old 05-06-2009, 04:59 PM   #23
Testing on the dyno as I type this. Should have dyno and track results come Saturday. Anyone interested in our Cold Air system please feel free to shoot me a pm/ or just give me a call at the shop. They should be ready to go by next week!
Old 05-06-2009, 10:10 PM   #24
ColeJJones
Drives: Cobalt SS/SC
AEM is developing one right now. they need a test car though, which usually means a free intake
ColeJJones is offline   Reply With Quote
Old 05-06-2009, 10:30 PM   #25
stangvert
Drives: stang vert
call K&N they have one with no tune required. Minimal HP.
stangvert is offline   Reply With Quote
Air intake chambers/baffles MikeZ28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 03-20-2009 12:17 PM
Intake/ Air Cleaner observations and thoughts... (?V6/V8?) radz28 5th Gen Camaro SS LS LT General Discussions 27 01-23-2009 08:14 PM
Saturn Sky Red Line GMPP cold air intake question 496BIGBLOCK General Automotive + Other Cars Discussion 8 12-29-2008 01:50 AM
Which cold air intake should I buy? VictoryRed08 General Automotive + Other Cars Discussion 8 12-14-2008 08:36 PM
What Cold Air Intake should I buy? VictoryRed08 5th Gen Camaro SS LS LT General Discussions 2 12-14-2008 11:47 AM
