01-31-2012, 02:32 PM | #57 | |
Drives: Drives a 2012 IOM 2SS/RS 6M Join Date: Nov 2008
Will these bars fit a 2012 2SS/RS and what is the cost........................................
CAMARO 2SS/RS 6M
01-31-2012, 02:49 PM | #58 |
Drives: Camaro Justice Join Date: Jun 2007
01-31-2012, 02:59 PM | #59 | |
If you installed Pedders sub-frame and radius bush inserts, the new FE4 / ZL1 sway bars with a Pedders tight spec alignment you will be amazed at the difference in your 5th Gen. The ZL1 that GM took to the ring ran much closer to the high end Vettes than most expected. It is my opinion that the same ZL1, with our sway bars, 19x10.5 wheels with Bridgestone RE-11 305/30/19/XL rubber would have been several seconds faster. Lower the ZL1 40mm front and 60mm rear, install our bushes and Supercars and the ZL1 is seconds faster again bringing it very close to the Vette at the toughest track in the world. The Supercar coilovers are pricey, but they deliver a ride quality equal to or better than OE and with the right adjustments have you dialed in for track duty. We can make your 5th Gen close to your Vette at a price. The bushes and bars are a HUGE step forward and may be all you need. If you determine you need more, the foundation will have been set in place for additional upgrades. |
01-31-2012, 10:17 PM | #60 | |
I just googled the part number, not a bad upgrade for $150.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
01-31-2012, 10:35 PM | #61 |
02-01-2012, 02:43 AM | #62 | |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Pete, please put me down for your turn-key rear FE4/ZL1 package as I already have your eccentrics installed, but can't turn up my rear camber (as you've noted). I'd like to be one of the first to try it out. Tom
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
02-01-2012, 09:29 AM | #63 |
I would never put you down, but I will add you to the list
02-01-2012, 09:34 AM | #64 |
FYI production of the FE4 / ZL1 bars is on schedule.
02-01-2012, 11:16 AM | #65 |
I used to be Dragoneye...
ExxZellent!!
02-01-2012, 01:31 PM | #66 |
Drives: 2010 Camaro IBM 2LT/RS M6 Join Date: Sep 2009
Curious, I have a single part number for both the FE4/FE5 left and right lower control arms on the parts sheet that I have. Part #20942237. Parts #22786033 and #22786034 show as upper left and right control arms.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade. |
02-01-2012, 01:33 PM | #67 |
Damn.... Double checking with a GM Dealer right now!!!!
02-01-2012, 02:58 PM | #68 |
Thanks & thanks, Pete!
Will you be offering them in black powder coat too? Yellow & Red is not on my list of color combos.
02-01-2012, 04:00 PM | #69 |
02-01-2012, 04:14 PM | #70 | |
I double checked and some where along the line we got our part numbers and prices crossed. UPPER Left and Right Rear Lower Control Arms #22786033 and #22786034 Rear Lower Control Arms #20942237 Chevrolet MSRP $53 Each |
Similar Threads | ||||
CAMARO WIKI | Tran | Wiki | 66 | 04-22-2024 11:41 AM |
New Camaro ZL1 Video Feature - Phase Four: Aerodynamic Testing | 1BADZL1 | Camaro ZL1 Forum - ZL1 Specific Topics | 104 | 11-13-2011 03:24 PM |
Doug Thorley Catback installed on 2010 Camaro SS L99 | erk5000 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 02-14-2011 02:29 PM |
1968 SS hood grills installed on 2010 SS. | jamesfl | Camaro Photos | Spyshots | Video | Media Gallery | 86 | 02-03-2010 10:44 AM |
