Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 01-25-2012, 06:41 PM   #1
Drives: 2010 camaro
To all you dragsters
For fun, now that the numbers are out, what will it take to hit a 10.9? I know theres lots of ways to get there so lets say the cheapest and easiest way?
toilets is offline   Reply With Quote
Old 01-26-2012, 12:32 PM   #2
Russell James
Russell James's Avatar
Drives: '15 1LE SS
Cheapest and easiest would be a big shot of nitrous. That's not doing it the right way, just the cheapest and easiest. It may or may not last more than a couple of runs.
Old 01-26-2012, 04:10 PM   #3
This is a dragster:
On the subject spray with some suspension upgrades and tires is the easiest & cheapest way to accomplish this, depends on your trans type, etc. also. A stock L99 w/maggie and dragradials should run low 11's. The car is heavy so it needs a bit more power and suspension set-up is critical as well.
Old 01-26-2012, 08:25 PM   #4
radz28's Avatar
Drives: Ultra-Grin
Lower 9.5" pulley, full exhaust, tuning, converter, and you're money. If you're good enough, and have a great tune, you might not even need that much. All that's probably going to run about $5k and would be something I really don't think you'd have to ever worry about.
Like others have already said - N20 is about the cheapest way. 150-shot with DRs anf for probably less than $1500 and you could be there. That's not the direction I want to go though.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 01-28-2012, 06:52 AM   #5
Drives: 2016 CAMARO SS
About 650 rwhp and good D/A for the day and this car will go into the 10's.
Gene Griffins ADM Powered CTSV 4 Door went a best of 10.56 at 132 last year at the LSX SHOOTOUT with 660 rwhp and drag radials,Of course a good driver.
Cost was alittle over 10k.
ADM PERFORMANCE is offline   Reply With Quote
Old 02-23-2012, 03:09 PM   #6
Truck Norris
Thread Mover
Truck Norris's Avatar
Drives: a Monte Carlo
Just a set of stickies should do the trick.
I say this because EVERYONE is saying the ZL1 will smoke the old GT500's and the quickest stock powered GT500 is running 11.1's @ 124mph
In the market for something fast
Truck Norris is offline   Reply With Quote
Old 02-28-2012, 02:37 PM   #7
hognutz's Avatar
Drives: 2013 ZL1
if you want to run DR or slicks I don't think it will take a ton. I would not run NOS on this car with the hypereutectic pistons but that is just me I am kind of a don't push limits kind of person. I would just up the boost a tad.
sticky tires, pulley and tune would almost have to do it on a good day. depending on temps maybe a meth kit to keep IAT in line. I don't have any experience with the LSA yet to know what it is like on a hot day.
headers and CAI would make it a no brainer I would think.
I am not sure the ZL-1 will smoke just smoke an old GT500 once you remove the traction problem. they are 550hp and wieghs less. the GT500's issue has always been traction once you remove that issue it moves out pretty good.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 02-28-2012, 03:01 PM   #8
Drives: Fast
Slicks a tune and good weather should be low 11s.
New and improved non-violation sig vid!!
Nmbr1gmfan is offline   Reply With Quote
Drag Racing..."Real Street Cars" Steve Dallas Dragstrip and Launch Techniques Discussion 40 09-04-2011 11:02 AM
Super Chevy Show April 8-10 tribone USA - Southeast 10 04-28-2011 01:08 PM
