Jason 98 TA
Old 01-26-2012, 08:22 PM   #1
Mikes SS
Mikes SS's Avatar
Drives: '10 CGM 2SS/RS 6M
constant 12v for cigarette lighter socket
Had some members ask me about my mod for the cigarette lighter so here are some picture that partly show the simple fix. There is a 12v constant wire already in the wire bundle if you just remove the shift plate/gauge cluster plate from around the shifter. It easily removes by pulling up. The 12v constant wire is the red wire with the white stripe. Just remove about 1/4 inch of the wire coating on the red/white wire and remove the green wire and red/white wire from the plug harness. Strip back the green wire and wrap it around the exposed part of the red/white wire. Put heat shrink tubing over both wires and heat. Insert the red/white wire back into the original spot in the plug. Wrap the whole thing back up as it was and enjoy!!
Mikes SS is offline   Reply With Quote
Old 11-03-2012, 04:13 PM   #2
jqram35
jqram35's Avatar
Drives: 2011 SS/RS
What wire/circuit is that tapping into? When it blows what will it take with it.
Jeff
2011 SS/RS L99.A6, Stainless Works LTs, Pypes Ex, Haltech CAI, NTo5 DRs,JRE Tune.
2012 Concours 14
jqram35 is offline   Reply With Quote
Old 11-10-2012, 10:43 PM   #3
Mikes SS
Mikes SS's Avatar
It's on it's own I have tried to trace it but it seems like nothing is there..it has worked for 3 years with no issues..really simple mod too!!
Old 11-11-2012, 10:03 AM   #4
sjmautoprod
sjmautoprod's Avatar
Drives: '10 1LT
Note that the red/wht wire is not in all cars (UMQ option).
sjmautoprod is offline   Reply With Quote
Old 11-11-2012, 06:06 PM   #5
Mikes SS
Mikes SS's Avatar
Gotcha
Old 11-18-2012, 08:38 PM   #6
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
Awesome works. Left some of the Green wire for remote turn on power to future accessories (capped off of course).
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
Old 11-27-2012, 08:44 PM   #7
ewynn9
ewynn9's Avatar
Drives: IOM 1LT/RS
Just to clarify, contant 12v means that my 12v socket with work with the car off?
If so I'll see if my car has that wire and get it working while I have that cover off.
ewynn9 is offline   Reply With Quote
Old 11-27-2012, 11:26 PM   #8
CyberPunk223
Drives: 2012 LS Camaro
what's the UMQ option?
CyberPunk223 is offline   Reply With Quote
Old 11-28-2012, 08:14 AM   #9
sjmautoprod
Drives: '10 1LT
Four-pack gauges.
Old 11-28-2012, 09:05 AM   #10
jqram35
jqram35's Avatar
Drives: 2011 SS/RS
Just knocked that out. Very easy. Thanks for the info!!
Jeff
2012 Concours 14
Old 11-28-2012, 09:11 AM   #11
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
correct, with car off you can still use the plug
lupe
overhaulengines is offline   Reply With Quote
Old 11-29-2014, 09:35 PM   #12
if6was9
if6was9's Avatar
Drives: '10 LT1 RS (ABM), '69 Firebird 400
That has to be one of the most annoying factory features.
Thanks for digging into this for the fix!
“I read somewhere that 77 percent of all the mentally ill live in poverty. Actually, I'm more intrigued by the 23 percent who are apparently doing quite well for themselves.” - Jerry Garcia
if6was9 is offline   Reply With Quote
Old 06-07-2015, 07:10 PM   #13
BC 2010
BC 2010
Drives: 2010 Camaro SIM 2SS/RS M6 GFX SR
I assume this will make the rear lighter plug hot in back of console
BC 2010 is offline   Reply With Quote
Old 01-11-2016, 11:19 AM   #14
adamx
Drives: 2010 camaro
yes does this affect both plugs or just one?
adamx is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 290 02-10-2018 10:11 AM
An extra lighter socket? =Stephens= Cosmetics and Lighting Modification Discussions 5 08-01-2011 12:05 AM
In cabin 12v constant jjjaroscak Cosmetics and Lighting Modification Discussions 7 05-04-2011 11:14 PM
Constant 12v power source? 13lade Cosmetics and Lighting Modification Discussions 8 06-12-2010 12:51 PM
