01-28-2012, 07:28 AM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2011
Help! How the hell I can remove the cabin air filter inlet case?
Hello,
My cabin air filter inlet case (the case holding the filter) got broken, I need to replace it with a new one but how can I get it out of its place? The hole is too small to let it through....I can't believe I need to unscrew the black part in front of it which is also glued to other parts... Help please. Thank you |
02-02-2012, 01:54 PM | #2 |
http://www.camaro5.com/forums/showth...BIN+AIR+FILTER
Here is a bit of help the scheme suggests to unscrew screws number 3..Help!! |
02-12-2012, 06:19 PM | #3 |
remove the dash..
02-13-2012, 01:41 AM | #4 |
Sent you a pm. Tks for the reply!
I have witnessed their capacity for courage, and though we are worlds apart, like us, there's more to them than meets the eye.
02-13-2012, 06:17 AM | #5 |
Let's go Rangers!
How is it broken, did it just unclip?
02-13-2012, 06:33 AM | #6 |
Well..the mechanic didn't know how simple it was to remove the air cabin filter and pulled strongly the whole case breaking two hooks aut of four which go into the chassis holding it in place...it is a bit loose now...
So I need to remove the whole case to replace the part...If you look at the scheme in the link I posted above it seems that there are only two screws holding the black part in front of it, I fear that this part is kind of glued at the edges as well (you see in my pic that there is a kind of sticky rubber along the right edge)...I have not tried yet... Thank you for your help!!
02-13-2012, 08:28 AM | #7 | |
Let's go Rangers!
02-13-2012, 08:47 AM | #8 | |
Yes I am sure..I collected the broken clips myself...
07-04-2012, 04:05 PM | #9 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
if the inlet housing is broken there is no way to replace it without removing the windshield and complete dash and the heaterbox
07-04-2012, 04:48 PM | #10 |
Drives: 2SS/RS Join Date: Sep 2008
Seeing as how this thread is almost 4 months old, I'm pretty sure he already got it fixed.
07-04-2012, 05:02 PM | #11 |
not so sure about that, he just messaged me today about it.
07-05-2012, 01:24 AM | #12 |
That's true Camaro1. I still have to fix it properly.
What?? You have to remove so much stuff?? From a diagram explaining how to replace the air filter, we can see that maybe we just need to remove the black panel in front of the air filter inlet case by unscrewing two screws. Then you pull it away and you should have enough space to get the broken piece out. My only concern is about the rubber/sticky stuff along the edge..(see the right hand side part of the pic I posted). I dont know if I damage it by pulling away the panel...I have done nothing so far to avoid worsening the situation.... At the moment, I can't find the diagram anymore, it was in the link I posted above.. Instead if it is as you say I am not going to bring the car to any mechanic....if they got broken the piece just by trying to replace the air filter can you imagine what they can do while removing all that stuff? In Italy Camaro is an U.F.O. ..... Thank you for your help!!
07-05-2012, 02:09 AM | #13 |
Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
Don't forget to replace your cabin air filter with a AC Delco cabin air filter
after it's fixed.
Mr. Clean
07-05-2012, 12:17 PM | #14 |
The plastic piece that holds the filter can be removed through the opening under the plastic cover. You need to remove the screws that hold the black sheet metal piece, then move it forward, the filter holder then will come out. I have done this on mine.
Similar Threads | ||||
g5cr cai system anybody install or looking at one "pics" | camarossrs2150 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 41 | 07-14-2011 08:26 PM |
\\\\\\K&N INTAKES BLOW OUT SALE +FREE SHIPPING////// | GmPartsDirect.com | V8 Bolt-Ons & Tunes | 2 | 03-29-2011 04:27 PM |
Hot air Intakes -By Kenne bell | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 66 | 02-08-2011 08:33 PM |
List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 02:11 AM |
AirAid Cold Air Intake anyone? | FLYNNZL1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 01-01-2010 09:05 PM |
