| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#26 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Drives a 2010 2SS/RS Camaro Join Date: Aug 2010
Very smart fellow, to have something to be able to observe that nothing is getting pulled through into the intake.
#27 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
I just had some work done on my car by a builder that's been doing LS engines for a long time. I saw an old catch can sitting on his table which looked like a Mike Norris one. When I asked about it he didn't know the brand. However, this piqued my curiousity as to his thoughts on a catch can. For the LS engines he recommended the use of one.
She is only memory now. |
#28 |
In Mud We Trust
Drives: 2010 Camaro 2SS/RS LS3 Join Date: Mar 2011
It was only 67 today. I better check mine.
2010 2SS/RS, LS3 -Hurst Shifter -American Racing Torq Thrust/Anthracite -CAI Intake |
#29 |
I drained my catch can last night only to find that it is looking like warm weather oil again. Since I started this thread, the temps here have for the most part been well above freezing.
#30 |
ZL1 lover-4-life
very interesting stuff. I also have one of Tracy's cans. I'm gonna try this test.
#31 |
I leave my inline site glass in all of the time now, because I just like knowing. Tracy is supposed to be sending me a different style bracket and once that happens I may finally go without.
#32 |
ZL1 lover-4-life
I have the same can that you do. could u maybe post some pics as to which hose you have plugged in to where? I may have some confusion as to if I have my hoses hooked up properly.
#33 |
Waiting to Drive
Drives: 2011 Camaro 2SS/RS IBM w/SIM Join Date: Feb 2011
This is simply eye opening...I need to order a catchcan!
2011 Camaro 2ss/rs IBM 6M with SIM stripes
#34 | |
It will take me a while to get a picture, but if you have an LS3, the center fitting goes to the valley cover (low and behind the passenger side of the throttle body. The fitting near the edge goes to the intake manifold which is just above and slightly to the rear of the other hose.
#35 |
POWER TECH
![]() Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
RX cans are the best. we use them on all the High HP FI builds and never have to worry about dirty air going back into the engine
#36 |
Why would you take it of,it's good to have it there to see if oil is getting pass the catch can into the intake.Wouldn't you think.
#37 | |
. My catch can testing days are over, unless I see some completely new design that makes me curious again. So far there aren't any.
#38 | |
Are you using the valve or the plain fitting, the reason I ask is that a couple c5 member experienced the valve freezing up and had to switch back to the plain fitting.
#39 |
I have the plain fitting. I suppose an engine with a supercharger or turbo may need the valve, but the RX works perfect without, in my testing. I initially had the check valve but after a while it started to chatter. Tracy sent me the plain fitting and it worked out great.
#40 | |
Thanks Bud, appreciate the info. and advise.
#41 |
![]() Drives: 2012 AGM Camaro LS / Team LFX Join Date: Feb 2012
I learn so much on this forum in such a small amount of time. Had no idea what catch can or breather was before I joined this forum I am now enlighten
#42 | |
I forgot to ask you where is this valve that they experience chattering noise and have frozen up on occasions, can you tell me where this is located or if you have a picture.I looked to see if it was in the photos showing the glass in-line filter, but didn't see it.
#43 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2001 Camaro SS Join Date: Dec 2009
On the top of the can, you have two connections. The center one is a plain fitting that is the cans inlet, and the outer connection is the valve. To change it, pull straight up and wiggle (it is a push-on style) the center fitting and it will pull off. Then unscrew the outer valve. That easy.
www.RevXtreme.com
941-721-1826 Turbo & Supercharging specialist VMax porting development from the begining RX Super Chiller |
#44 |
![]() Drives: 2012 camaro 2lt white Join Date: Dec 2011
Have any of you ever heard any negative things about the oil catch cans on eBay? i found some going for $20 shipped....i am considering
#45 |
If you do the testing, you'll likely find that an ebay one will catch some oil, but allows some to pull through the can and inot the intake. The better designed cans will be way more efficient at preventing pull through.
#46 |
Here are a few pics or Ebay cans:
![]() ![]() ![]() ![]() As you can see, most are no different than an empty beer can with 2 fittings in. Below shows one of the billet Ebay cans that the top is in the pictures above, and then a few other good and marginal cans. You can see the Moroso style (many branded by same manufacturer) unit with the media on both sides in the top section:
www.RevXtreme.com
#47 |
This is a bit over 5000 miles. Next update should be more precise as the beginning mileage being noted here is 33005. This will help me to keep better track of things.
#48 |
I emptied my catch can on Saturday and got about 1/2 oz after 2000 miles. I'm pretty pleased with that as I've been driving the car really hard and there was 7 dyno pulls in those 2000 miles. Starting miles was 33005 and ending 35016. I started a new container with this 2000 mile catch and will keep adding to it for a few thousand more miles.
#49 |
BLOWNSS
Drives: 2011 SUPERCHARGED Camero SS Join Date: Dec 2010
After 2000 miles mine was 3/4 full
2011 LS3 SS/RS, M6, Maggie TVS2300 - cog drive, CAI, BEHE Performance tune
#50 |
Your can was 3/4 full? What catch can?
| Thread Tools | |
| RX PCV Oil Catch Cans and Breathers| In stock | Free Shipping! | JDP Motorsports | V8 Bolt-Ons & Tunes | 46 | 04-29-2013 03:43 PM |
| RX PCV Oil Catch Cans and Breathers| In stock | Free Shipping! | JDP Motorsports | V6 Bolt-Ons & Tunes | 116 | 04-29-2013 11:16 AM |
| catch can install and hosing | hapisok | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 12 | 12-04-2011 11:35 AM |
| A different catch can question | Three of Swords | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 2 | 11-30-2011 04:09 PM |
