| Mechanical Maintenance: Break-in / Oil & Fluids / Servicing Discussions on mechanical maintenance and servicing of your Camaro |
Thread Tools |
#26 |
![]() Drives: 2010 Camaro 2SS RS, Black Join Date: Sep 2009
You don't have the parts numbers for these do you? I just tried to look them up but got lost in their parts catalog, couldn't find fluids listed anywhere.
#27 |
#28 |
My dealership sells ACDelco 75 90 synthetic gear oil. Is that the GM stuff?
I checked out my rear diff today anticipating doing this job. I found that my exhaust pipe is too close to the drain plug to get a regular 3/8" socket on there. I have a Solo catback and even after removing the hangers I couldn't move it enough to get my tool on there. I am going to need to get a low profile breaker or something. I never checked this out with the stock exhaust so I'm not sure how much room there was before. It seems like every little job requires me to buy some tool I don't have. sheesh |
#29 |
Just Because!
Drives: 2010 SIM 2SSRS Join Date: Jun 2010
Oh yeah. Noticed that when I got my exhaust on.... No room. It was ok with stock exhaust.
Sent from my payphone using carrier pigeons.
#30 |
![]() Drives: 2010 Camaro 2SS/RS M6 Join Date: Apr 2010
Today I picked-up the AC Delco Synthetic Axle Lube #88900401 from the dealer. On the receipt it says that it replaces #89021677. I also picked-up the Limited Slip Axle Lube Additive # 88900330, but it says nothing about being a replacement. I would think that the additive should be fine.
#31 |
Thanks Dr.
#32 |
I just changed the rear end fluid for the first time today on my SS after 2 1/2 years and 17,000 miles. Per the manual I used Mobil 1 75W-90 fluid with 2.6 Oz of additive. I sure wish I had done it sooner.
Both the magnatic fill plug and drain plug were covered with fine metal shavings.
#33 |
![]() ![]() Drives: '10 2SS/RS, MKIII Supras Join Date: May 2010
Im hoping to change mine this weekend. 21,1xx miles on mine right now. I was going to change it a while ago, but found that my exhaust is really close to the drain plug blocking access to it. I have 1 qt of Mobil 1 75W90 and a bottle of GM additive.
#34 | |
I used NO jack or ramps, just backed up to the edge of the garage and used the slope of the driveway for a couple more inches of room. My drain plug literally had a ball of metal sludge stuck to it. I also wish I had done this sooner. BTW: I added 2.5 oz of the GM friction modifier directly to the 1 qt. bottle of GM (AC DELCO) fluid and shook it up before I poured it in the diff. I was able to add 30 oz. before it started leaking out the fill plug. nice easy DIY job. |
#35 | |
FYI - Going back to school at 40 SUX! But that's another story. |
#36 |
RP and zero issues.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir 1989 Silver 5.0 Mustang LX Coupe 1999 Pewter Tahoe LT 2011 Blue Camry SE |
#37 |
Brianskeet
Question for the RP fans. Is anyone suffering from the dreaded one wheel peel? What about our Amsoil users, same question.
#38 | |
So easy to love Camaros
#39 |
Brianskeet
Thank you
#40 | |
![]() Drives: 2010 Camaro 2SS/RS Join Date: Sep 2011
Replacement Part Numbers?
Hello guys, do you confirm that: the factory rear diff. fluid part number 89021677 has been replaced by part number 88900401 and that the friction modifier part number 1052358 has been replaced by part number 88900330? Thank you
I have witnessed their capacity for courage, and though we are worlds apart, like us, there's more to them than meets the eye.
#41 |
GrINned & JUICEd
Drives: EB Expedition, 2SS/RS M6 Join Date: Nov 2009
That's what the service dept at the dealership told me when I got my fluids.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot Coated LTs, JRE SCT Tune, CAI, Rx Catch Can, Gates heater hose relocation, Metco loop, Momentum Tunnel Brace, Autometer wideband, Fesler Pillar Pod, LED strips (interior), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, Plasticoat Bowties, vinyl Bowtie center caps. No holes drilled.
2010 2SS/RS, M6, Blk Rally & Int Ord: Oct 5, 2009 Rec: Nov. 19,2009 drove off lot at 10:30pm 13.17 @ 112.6 Bone stock |
#42 | |
Tampa Gulf Coast Family
Drives: 1977 Z28, 2SSRS 2010 M6 Join Date: Sep 2009
#43 | ||
![]() ![]() Drives: 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
CAI Cold Air Kit. Dynatech Headers. High Flow Cats. Corsa Catback. JRE SCT X3 Tune. OEM Strut Tower Brace.
#44 |
![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Lucas Oil 80w90..........no sweat, no mess, no additives, no figure 8's, no issues......$8.99
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, Halltech cai, Delo 400 15w40, Ebay LED p13w DL, Lucas oil 80w90 gear oil, OBX LT's, Ebay gill decals, Shell Spirax ATF, Mike Norris tuned 413/419
Avenging Orange: 35 years of not buying into the Hype........and damn proud of it!! |
#45 |
GMTool,
Thank you for your info!!
#46 |
![]() Drives: SIM 2010 2SS/RS Join Date: May 2012
#47 |
Camaro for Life
http://www.amazon.com/Mobil-75W-90-S...8247261&sr=8-8
Is that the right stuff for an Auto V6? On a side note, how hard is it to change out the transmission fluid and filter?
Build Thread
Current ride: 2010 CGM 2SS/RS A6 #128349 (his) & 2013 VR 1LT A6 #147344 (hers) Exterior: Cyber Gray Metallic / Interior: Ebony Nickname: Valkyrie Best run: 13.5 stock on Pzero's with barely any tread left How to hug your camaro Buy the car that you would most like to get beat in. The other guy will always be faster. |
| Thread Tools | |
| How much is the rear diff fluid change? | Revenant | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 18 | 04-01-2011 12:04 PM |
| Diff Fluid and Tranny Fluid | jagan323 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 11 | 03-15-2011 06:45 PM |
| Rear Diff Fluid Change | jagan323 | Camaro DIY & HOW-TO instructions & discussions | 5 | 03-08-2011 01:27 AM |
| Changed Tranny & Diff fluid | burntOmaro | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 13 | 01-01-2011 12:41 AM |
| Rear Diff Fluid and my Dealer | Rocklage | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 19 | 12-23-2010 11:56 AM |
