Old 02-01-2012, 09:49 PM   #15
BuddhaSS
BuddhaSS's Avatar
Drives: 2011 Camaro SS
sick wheel setup on that mustang.. wish i had thicker tires on my ss wheels
BuddhaSS is offline   Reply With Quote
Old 02-01-2012, 10:48 PM   #16
Mud
In Mud We Trust
Mud's Avatar
Drives: 2010 Camaro 2SS/RS LS3
Same here. I don't mind an inch or so sticking out. In fact, looks pretty cool.
2010 2SS/RS, LS3
-Hurst Shifter
-American Racing Torq Thrust/Anthracite
-CAI Intake
Mud is offline   Reply With Quote
Old 02-01-2012, 11:37 PM   #17
Overkillphil
Tire Destroyer
Overkillphil's Avatar
Drives: 2011 Camaro 2SS/RS Hurst M6
Waiting patiently for you to get these fitted. I really want to run a tire this size too! Itching to leave 2 big 12 in wide stripes down the street!!
Overkillphil is offline   Reply With Quote
Old 02-01-2012, 11:46 PM   #18
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
Sweet Meat... can't wait to see them on... Your Vert Rocks
Old 02-01-2012, 11:49 PM   #19
can't wait to see them on the car, that is going to look bad azz.
Old 02-02-2012, 12:51 AM   #20
Nessal
Drives: Exige, Miata, Ghia
I actually like bulged tires. I think it looks GREAT!
Nessal is offline   Reply With Quote
Old 02-02-2012, 09:36 AM   #21
micj82
micj82's Avatar
Drives: 2011 white camaro ss
Cool can't wait to see this set up
micj82 is offline   Reply With Quote
Old 02-02-2012, 02:11 PM   #22
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Remember guys these are going on 18x11 wheels and the tires are only 25.9" tall. That's almost 3" shorter than stock. These will will have less clearance problems than a similarly wide tire on a 20" wheel.
SUX2BU is offline   Reply With Quote
Old 02-02-2012, 02:54 PM   #23
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
That depends on what kind of "clearance" issues you're talking about. Just by installing these tires, you're essentially lowering your car 1.5". Add that to whatever amount of lowering you already have, and you could be scraping the bottom of your car over every little pebble. But I suppose if they are going to be for track-only, then do whatever you like. I can totally appreciate the performance advantages you're trying to achieve here, but "the look" is just not for me. They're nice and wide, but I think the height will just make the whole set-up look funny! It's like the opposite of donkin' out your car with the huge 26"+ wheels!!! Either way it's going to look kinda weird in my opinion. But I wish you the best, and hope you achieve your goals with this. Eager to see pics!!!
blazzin1 is online now   Reply With Quote
Old 02-02-2012, 08:47 PM   #24
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Actually if you these aren't track only tires and I'm only lowering an extra .7" from my current street tires. My current street tire set up is 26.7" fronts and 27.3" rears (picture is in my sig), that along with the BMR 1" drop makes my car pretty low right now but I'm used to it and hardly ever scrape anywhere anymore. Actually the lowest part of my car is the front and shorter rears will actually raise the front just a hair.
The 335/30s are supposed to be taller than my 315/30 drag radials but they are actually a little shorter when next to them, maybe mounted and aired up they will be a little taller.
When I first got my 18" Forgestars I had ordered some 28" 255/50 18 for the front, that looked REALLY goofy and handled like an SUV. I only made one trip around the block and took them off.
Here is what my drag radials look like and these 335/30 tires should look very close in height.
Old 02-02-2012, 10:02 PM   #25
Ivan @ Southwest Speed
Scoreboard! Those are completely Legit!
Ivan
Old 02-02-2012, 10:50 PM   #26
blazzin1
blazzin1's Avatar
Yep, you're right, I got this thread somehow mixed up in my head with your thread about your Hoosier's. Well, either way, to each their own. I'm glad you found a set-up that you like. I hope it works out good for you. Like I said, I'm looking forward to seeing the pictures.
Old 02-04-2012, 09:36 PM   #27
DougDanger
Drives: 2011 2SS RS
OK - did the 335 new tires fit yet?
I cant wait to some pics already.
Are people not using 18x12 because they stick out past the wheel well?
Is there an offset that will bring them in enough to fit?
Sux you seem to be man to try to stretch it to the limit.
DougDanger is offline   Reply With Quote
Old 02-04-2012, 11:03 PM   #28
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Still waiting for my current tires to wear out some more.
The offsets on my 18x11s have the face of the wheel sit just inside the fender (I hate wheels that stick a out, almost as much as stretched tires). The only down side is that when lowered the inside of the barrel, barely rubs on the lower control arm. I have ground down the spot that the wheel rubs on. If I do go with 18x12s I will have to remove the lower control arms and notch them to clear. I might have to massage the inner fender well a bit too.
CTS-V spares as front runners on GINGER SUX2BU Wheels and Tires Talk Sponsored by The Tire Rack 27 01-09-2014 09:44 AM
Ginger is sporting the worlds first 5th gen Wind Restrictor! SUX2BU Camaro Convertible Forum 149 01-21-2012 04:37 PM
Wife doesn't like all the attention Ginger gets. SUX2BU 5th Gen Camaro SS LS LT General Discussions 28 06-09-2011 06:28 PM
Top up pictures of Ginger. SUX2BU Camaro Photos | Spyshots | Video | Media Gallery 9 04-29-2011 07:33 PM
Ginger or Mary Anne? PQ Off-topic Discussions 42 03-24-2009 03:29 PM
