Old 02-10-2012, 01:15 PM   #29
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Swapping tires today! i was going to wait until my 295/40 18 tires are trash, but then I thought, what if my 335 don't fit at all! i would be SOL. So I'm gonna swap now and keep my old 295s around just in case I have to swap back.
SUX2BU is offline   Reply With Quote
Old 02-10-2012, 03:03 PM   #30
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Patiently waiting for pics.
Orville Redenbacher
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 02-10-2012, 03:13 PM   #31
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
I don't think MY V6 could even turn them over LOL
skipinminn is offline   Reply With Quote
Old 02-10-2012, 03:32 PM   #32
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Originally Posted by SUX2BU View Post
Still waiting for my current tires to wear out some more.
The offsets on my 18x11s have the face of the wheel sit just inside the fender (I hate wheels that stick a out, almost as much as stretched tires). The only down side is that when lowered the inside of the barrel, barely rubs on the lower control arm. I have ground down the spot that the wheel rubs on. If I do go with 18x12s I will have to remove the lower control arms and notch them to clear. I might have to massage the inner fender well a bit too.
May I ask, just out of curiosity, why you want such wide tires on your car? Not that its a bad thing but it seems overkill to go up to a 335 on an 18x12? a 315 should handle much more than you're gonna throw at it and should require mods.
Obzen is offline   Reply With Quote
Old 02-10-2012, 03:35 PM   #33
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Teaser pic!
Old 02-10-2012, 03:52 PM   #34
Camaro21
Drives: SOLD - 2013 M6 ZL1
Let's see the rest of the pics already !!!
Camaro21 is offline   Reply With Quote
Old 02-10-2012, 04:04 PM   #35
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
woooooow more pics please!!!
Old 02-10-2012, 04:59 PM   #36
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
would love to see some suspension clearance pics with all that rubber under there
2011 Camaro 1SS/RS
Cammed, Sprayed, and Beaten Daily.
Aries240SS is offline   Reply With Quote
Old 02-10-2012, 07:48 PM   #37
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Read my first post.
Old 02-10-2012, 07:51 PM   #38
DougDanger
Drives: 2011 2SS RS
You're the man, now let see the rest of those monsters...
DougDanger is offline   Reply With Quote
Old 02-10-2012, 09:22 PM   #39
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Ok here is the "skinny" on the tires, LOL. They fit ALMOST perfect. Mounted on the 18x11 they bulge quite a bit, but not too much that I feel i should upgrade to 18x12, so 18x12 probably won't happen, sorry guys. Just like I thought the tires sucked in over 1/2" in width after they were mounted on the 11" wheels. The narrowest wheel BFG recommends for this tire is a 11.5" wheels, so if you do this DO IT AT YOUR OWN RISK. Here is some width pics compared to my 315/30 18 Hoosier drag radials. Over all width they are only 5/8" wider than the drag radials.
The first thing I did when I bolted them to the car was check to make sure they didn't rub anywhere, they didn't! I checked the inner clearance and the closest place i could find still have about 1/2" clearance from the edge of the tire to the plastic fender liner.
Then I unbolted one side of the rear sway bar and did a FULL compression clearance test (I basically compressed the shock/spring all the way) and this resulted an inner clearance of about 1/4". I left the sway bar disconnected and went for a test drive, this way whenever I did some test swerves it would let the tires go up individually and they would go up in the wheel well farther than they would with the sway bar connected. I did some highway swerve tests, empty parking lot figure eights, slalom tests, ect. I did everything I could think of to try and get the wheels to rub. I got home took the tires off an NO RUB MARKS!!!! WOO HOO! Here is some pics of the full compression test.
I measured it and the tire sticks out exactly 1/8" past the fender. Pictures aren't great because in some pics the tires look flush with the fender, in others they look like they tucked under the fenders and in others they looked like they stuck out 1/2". I tried to only post the pictures that really represent how the tires actually look in person. I don't like tires sticking out at all and if you have read some of my threads, I modded my upper control arms in the rear to be able to get the camber where I wanted it after lowering (http://www.camaro5.com/forums/showthread.php?t=139136). This worked great but resulted in pushing each tire out about 1/8". So Monday I will be undoing what I did in that post and modding the lower control arms in hopes of sucking in the tires 1/8" putting the tires exactly flush with the fenders.
The tires are a little shorter than I would like. Thankfully, they did grow to the size of my drag radials after mounting them, I was scared that they would be shorter than my drag radials. I can tell that I will have more problems scrapping the "vert only" under trunk bracing bolts, but I figure I can swap these out with new ones after they get worn down, LOL.
All in all I'm quite happy how these came out. Until someone makes a 315/35 18 street tire, it looks like these will be my rear tires from now on.
Here is the rest of the pics. I will post pics of my LCA mods when I do it Monday.
Old 02-10-2012, 09:27 PM   #40
grocerygetter
instigator
grocerygetter's Avatar
I think that junk looks awesome.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 02-10-2012, 09:35 PM   #41
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
Very nice! Can't believe no rubbing at all!!
SlowSS is offline   Reply With Quote
Old 02-10-2012, 09:44 PM   #42
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
The ONLY reasons it works are:
1. The offset I chose for my 18x11 are dead nuts perfect.
2. The 335 tire tucks in to fit the 11" wheel making the tire over 1/2" narrower than normal. It's not recommended, but it works.
3. The tire is ONLY 26" tall. I doubt this would work with a taller 335.
CTS-V spares as front runners on GINGER SUX2BU Wheels and Tires Talk Sponsored by The Tire Rack 27 01-09-2014 09:44 AM
Ginger is sporting the worlds first 5th gen Wind Restrictor! SUX2BU Camaro Convertible Forum 149 01-21-2012 04:37 PM
Wife doesn't like all the attention Ginger gets. SUX2BU 5th Gen Camaro SS LS LT General Discussions 28 06-09-2011 06:28 PM
Top up pictures of Ginger. SUX2BU Camaro Photos | Spyshots | Video | Media Gallery 9 04-29-2011 07:33 PM
Ginger or Mary Anne? PQ Off-topic Discussions 42 03-24-2009 03:29 PM
