Rick@Livernois
Old 01-30-2012, 09:08 PM   #1
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
Suspension Upgraded - Still have wheelhop
Last spring I upgraded my suspension. Overall I am very happy with the result. The car tracks like on rails and the understeer is completely gone. I have had my SS to the race track and it made a hero out of me with only a few hours of practice.
But I still have wheel hop. With TC off if I launch it with some spin or even punch it moving in first I get the bounce as the tires break loose. It is definitely not as bad as stock, but still there.
I have the stock alignment, tires and wheels, and no lowering springs.
From BMR I installed:
  • Cradle and differential Pro bushing kit
  • Trailing Arms
  • Toe rods
  • End link mounting braces
  • Front and rear sway bars with end links
A local reputable shop performed the installation
I am not knocking the BMR hardware as many others have cured their wheel-hop with less BMR parts.
What's missing? Or?
Old 01-30-2012, 09:31 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
did you install their trailing arm bushings and their toe rod bushings?
Click to view my build thread
Old 01-30-2012, 10:00 PM   #3
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
I think they came with them. But you know, I did not check. Will do tomorrow.
Old 01-30-2012, 10:33 PM   #4
Synner
Drives: not stock
Stock alignment as in not redone since installation or redone to factory specs? Copy of it?
Old 01-30-2012, 11:24 PM   #5
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
  • Trailing Arms
  • Toe rods
What's missing? Or?
Your alignment sheet is missing. Please post the alignment specifications after all these parts were installed.
Old 01-31-2012, 08:27 AM   #6
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
I would make sure that you did the rear trailing arm bushings and if not, definitely replace those. These are the bushings that install in the aluminum upright (spindle) out at the wheel. It is a relatively cheap mod but it makes a big difference. Also, as mentioned above, alignment is important as well. If you lowered the cradle to install Cradle bushings plus had the toe rods and trailing arms off the car without getting an alignment, chances are that your toe is probably out of spec. I would put a good performance street alignment on it, replace those outer trailing arm bushings, then play a little with tire pressure until you get the hop out of the car. You have the majority of it covered, just a few more tweaks and you'll be there!
HERE is a link to our spring instructions which has our recommended alignment specs included. And just in case you need them, the part number for the outer trailing arm bushings is BK006.
BMR guy is offline   Reply With Quote
Old 01-31-2012, 06:50 PM   #7
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
Redone to factory specs.
Old 01-31-2012, 06:51 PM   #8
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
realigned to factory specs.
Old 01-31-2012, 06:56 PM   #9
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
I thought the trailing arms and toe rods came with poly bushings. I did not do the install. I did get a stock alignment.
If not can I do these bushings myself? Are the toe rod bushings needed?
Any tips on finding a good alignment shop that can handle a custom alignment?
Old 01-31-2012, 07:03 PM   #10
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The BMR rear trailing arms do not include the outer bushings.
Old 01-31-2012, 07:09 PM   #11
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
News! Maybe that explains it. What about inners?
Old 01-31-2012, 08:32 PM   #12
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
Been looking at the BMR site. I see now what I am missing. So I will get BK006 outer training arm bushings. Is it also worth doing the BK017 upper control Arm bushings? I will follow this up with a performance alignment.
Old 01-31-2012, 08:45 PM   #13
Synner
Drives: not stock
"stock" alignment is a rather wide range and inconsistent from side to side on the car. Upper control arm isn't really necessary and would require dropping the cradle for install just as an FYI.
Old 01-31-2012, 08:51 PM   #14
JusticePete
Synner is right. The OEM alignment specs are loose. We need to know what the rear cambers and toes are set to before we through parts at the problem. Not that I mind people throwing parts at the problem, we make money when we sell parts for throwing
Please get your alignment sheet and post it up.
Save $$$ with Pfadt suspension packages from Apex Motorsports Apex Motorsports Suspension / Chassis / Brakes 75 12-13-2010 09:29 AM
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 02:28 PM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 04:21 PM
Newest Camaro Ugrade at a Seriously Knowledgable Pedders Suspension Export in Mt. Vie Info@PeddersUSA.com Suspension / Brakes / Chassis 8 04-21-2010 11:15 PM
Pedders suspension already for the Camaro Info@PeddersUSA.com Suspension / Brakes / Chassis 75 10-21-2009 07:25 PM
