Solo Performance
Old 02-22-2012, 05:38 PM   #15
SSKyle
Drives: 2011 SS/RS
What kind of fuel upgrades do you have done? Only injectors?
SSKyle is offline   Reply With Quote
Old 02-22-2012, 05:46 PM   #16
Sean@Phastek
Sean@Phastek's Avatar
Drives: 2010 Camaro X5 Turbo
This kit comes with 8 new injectors.
Pretty soon we will be maxing out the stock fuel pump with the extra upgrades we're doing; so that's next on the list too.
Sean@Phastek is offline   Reply With Quote
Old 02-22-2012, 05:53 PM   #17
SSKyle
Drives: 2011 SS/RS
I'm getting ready to install this same kit an was wondering what my factory pump would handle with FAST 65lb/hr injectors. What was the duty cycle of the injectors at 8psi?
Old 02-22-2012, 06:01 PM   #18
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
Sean, I was comparing both IPS TT and Turbonetics Single Turbo. Both @ 8PSI and stock engine. In fact the IPS kit is using stock manifold. But you can see after 3500 RPM the IPS keeps moving up more rapidly than Turbonetics. Can you comment why? Thanks!
IPS
Turbonetics
Z_Rocks is offline   Reply With Quote
Old 02-22-2012, 07:12 PM   #19
Sean@Phastek
My first guess would be the way the two kits are built and how well they flow. I'm still up in the air on the shorty headers vs stock manifolds. I saw some interesting info on the dynos today; so I may switch back to the stock manifolds.
Was that IPS graph on 93 octane? I'd like to check out some more info on that one if you have a link. The Turbonetics kit should have a few more horsepower in it, closer to 600 rear wheel horsepower (at least), because of the conservative tune we're still running - But, I don't know if I agree with that IPS dyno showing 660 to the wheels on the stock fuel system. Maybe with smaller injectors? And, 750HP at the flywheel on a stock LS3 bottom end Not my cup of tea!
Keep in mind we're doing our setup in stages - so who knows what the final numbers will be!
Old 02-22-2012, 07:22 PM   #20
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
JBA shorties and cat-delete pipes. And the JBA shorties should now be 50 state smog legal too (CARB EO# D-57-25)
Do you have to modify anything to install the headers? Have any video clips of the car? Would love to hear a turbo Camaro with headers.
Crime2 is offline   Reply With Quote
Old 02-22-2012, 07:25 PM   #21
Z_Rocks
Z_Rocks's Avatar
I understand Sean. What caught my curiosity, was that, both cars were getting 8psi air pressure waiting at TB to get in, regardless of how that pressure was made. And that's why I posed the question.
I had actually seen several built from IPS on this forum and they all seem very high power. Here is the link:
http://www.camaro5.com/forums/showthread.php?t=91275
Here is the link
Old 02-22-2012, 07:50 PM   #22
Havnaparty
Havnaparty's Avatar
Drives: 2010 2SS/RS Transformer Edition
I have to say that the work you guys have done and the pics to go with it is really impressive.
Could you tell me what would be a typical final cost if you could,(installation included) for the turbo compared to the magnacharger supercharger and the advantages one over the other?
Thanks
Havnaparty is offline   Reply With Quote
Old 02-22-2012, 08:25 PM   #23
Sean@Phastek
Their kit mentions larger injectors and a boost-a-pump, so that takes care of the fuel issue - I'm not sure where we would be at if we weren't getting close to running out of fuel pump, but we will know soon!
In general, a twin turbo, bottom-mount kit, should have less hot-side pipe volume, which may make a difference in power, but then again A) this is a 50 state legal kit (), and B) I'm not a big fan of remote-mount oil pumps for the turbos, because to me, at the end of the day, it's just more to worry about and something that could go wrong and destroy two turbos. Although.. I'm not here to compare kits
Old 02-22-2012, 08:30 PM   #24
Sean@Phastek
Nope, they went right in. We wrapped some heat tape around the last plug wire though. We did try a set of BBK shorties, and they didn't fit (on the driver side, didn't check passenger side).
I'll get a few video clips of the turbo kit tomorrow, with the dyno runs we filmed, and post that up soon.
Old 02-22-2012, 08:30 PM   #25
Z_Rocks
Z_Rocks's Avatar
Thanks Sean. I wasn't leading you on for comparisons, just wanted to hear your comments. I really like the way you guys do the work/installation and that's all this post was all about.
Looking forward to more findings from you.
Old 02-22-2012, 08:45 PM   #26
Sean@Phastek
I'll check with the tuner tomorrow and let you know on the duty cycles. Any particular reason you want to use those injectors? I believe this kit comes with 60lb injectors..
Old 02-22-2012, 08:49 PM   #27
navyblueSS
Drives: 2002 Camaro SS
Very nice!
2015 1LE - CAI intake, TSP longtubes,
NPP, Futral Motorsports tuned, BMR 1"lowering springs, BMR trailing arms
navyblueSS is offline   Reply With Quote
Old 02-23-2012, 11:57 AM   #28
Sean@Phastek
Originally Posted by navyblueSS View Post
Very nice!
Thanks!! Video is ready
On Nitto 305/35R20 NT555R Drag Radial tires too
phastek turbonetics turbo
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 466 10-14-2017 03:16 PM
SOLO Performance Camaro CONVERTIBLE Cat-Back Exhaust Kit GOINGSOLO2 V8 Bolt-Ons & Tunes 18 12-20-2011 07:17 PM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 05:26 PM
