Old 02-23-2012, 12:00 PM   #29
2010 4 DW
Drives: White 2010 RS/SS
Very Nice!
2010 4 DW is offline   Reply With Quote
Old 02-23-2012, 12:31 PM   #30
bumblebeecamaro
Car Lover By Nature
Drives: Mini Cooper S
I like everything 'cept for the rear pipes. I don't know why but the two pipes in the middle looks ricey to me.
bumblebeecamaro is offline   Reply With Quote
Old 02-23-2012, 12:39 PM   #31
SSKyle
Drives: 2011 SS/RS
I bought a tuner kit an I knew the complete kit came with 63lb/hr I believe so I went with 65's. I hoping that I will be ok with a bap and those injectors... I plan on running no more than 9 psi.
SSKyle is offline   Reply With Quote
Old 02-23-2012, 01:12 PM   #32
bumblebeecamaro
Car Lover By Nature
why not get a ZL1 pump and forget about the BAP?
Old 02-23-2012, 01:26 PM   #33
Sean@Phastek
Sean@Phastek's Avatar
Drives: 2010 Camaro X5 Turbo
The ZL1 fuel pump should only be good for about 600-650 horsepower at the flywheel by itself... so he will need that and a boost-a-pump. Or a new twin pump kit like Lingenfelter offers, which is what we will probably be using.
Sean@Phastek is offline   Reply With Quote
Old 02-23-2012, 04:56 PM   #34
TurboneticsSL
TurboneticsSL's Avatar
Drives: Turbocharged
Wow, that centered exhaust actually look pretty good. Good job!
TurboneticsSL is offline   Reply With Quote
Old 02-24-2012, 10:35 AM   #35
crankpin
Drives: 2010 Camaro
Originally Posted by Z_Rocks View Post
Sean, I was comparing both IPS TT and Turbonetics Single Turbo. Both @ 8PSI and stock engine. In fact the IPS kit is using stock manifold. But you can see after 3500 RPM the IPS keeps moving up more rapidly than Turbonetics. Can you comment why? Thanks!
It seems like different dynos put out way different numbers. I ran 145mph at 3300# and another guy on a forum ran 145mph at 3400#. You'd think very close dyno numbers, but I made 590whp and he made 750whp. Both 6.0 engines and 75mm turbo. Pretty ridiculous difference when the cars had to make almost the exact same amount of power to go the same speed at the same weights.
crankpin is offline   Reply With Quote
Old 02-25-2012, 08:28 AM   #36
ParkerB57
COTW 11/12/12
Drives: 1SS RS IBM
So how was the install, everything fairly straight forward no big issues? What guages are you running?
ParkerB57 is offline   Reply With Quote
Old 02-25-2012, 10:16 AM   #37
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
these are by far the best pictures of the kit posted I have seen, I made the same numbers basically with a canned tune, Im looking foward to a " real tune " still not sure of deleting the cats @ Sean did you get a smell from the cat deletes ? Im probably adding ARH shortys soon and debating weather to catless or get the PI catalytic cats for boosted cars
adding a ZL1 fuel pump next im not looking to go over 600 right now
1969to2010 is offline   Reply With Quote
Old 02-26-2012, 01:01 PM   #38
Sean@Phastek
1/4 mile update: 11.50 @ 126 mph
Thanks, right now there are no mufflers, so it's a little raspy around 2k rpms with no cats. We'll be putting mufflers on there soon tho, and pulling the tips in a little more, I think they are sticking out a little too far right now..
Install was great, all bolt on stuff. The kit comes with step by step instructions and detailed pictures. Right now I have the a temporary AEM wideband set on the dash for tuning. Auto Meter Elite gauges are on order (the gauges that change colors at high/low thresholds), they should be here next week and those are going in the Auto Meter dual gauge pod on the pillar. I will be using Vac/Boost and Fuel Pressure gauges for now.
Keep us updated on how yours turns out. No smell from the cat-delete pipes, other than the initial burn off from the residue inside. That was gone in a minute or two though. Let me if the ARH shorties fit this kit.
We did some 1/4 mile testing on Saturday. With an easy 3,200 rpm launch on the Nitto NT555R drag radials, we got an 11.50 @ 126 mph with a 1.91 60'.
Not bad for cruising down the track. Picked up 1.5 seconds and 15 mph over the 13.0@111 mph we initially ran in this car when it was stock.
Old 02-27-2012, 08:09 AM   #39
ParkerB57
COTW 11/12/12
Drives: 1SS RS IBM
Thats really awsome, I love in car videos, keep em coming.
THANKS!!
Ben
Old 03-29-2012, 01:14 PM   #40
Sean@Phastek
anti-lag / launch control update
We now have the Lingenfelter fuel pump upgrade installed, as well as a nice catch can, and more importantly, the Lingenfelter Launch Control box installed. We have it set at -5* timing pulled, with a .4 second delay, and 4,500 RPM rev limiter. Right now it's making about 4 lbs of boost at the line. Should be a huge improvement in the 60' times at the track to say the least! (we use a Hurst short shifter and shift knob with a button on it to control both the anti-lag/launch control box, and the line lock for burnouts) 1,000 HP axles/half-shafts coming soon as well!
Old 03-30-2012, 08:53 AM   #41
stangkilr
stangkilr's Avatar
Drives: 2017 Camaro ZL1
Thanks for sharing the pictures and info. I am really looking into doing this kit on mine just because its strait bolt-on. Just got done with a custom kit for my 2002 and man I had a lot of bugs to work out.
2017 ZL1
2014 Corvette
2002 Camaro
stangkilr is offline   Reply With Quote
Old 04-02-2012, 10:41 PM   #42
rms-man
Drives: '98 Corvette 408/PT80
Let us know how well the Lingenfelter Launch Control box helps at the track...
I installed the same one on my rear mount vette and went from a 1.85 60ft to 1.55 60ft cause I was able to leave the line with 5-6# boost.
rms-man is offline   Reply With Quote
phastek turbonetics turbo
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 466 10-14-2017 03:16 PM
SOLO Performance Camaro CONVERTIBLE Cat-Back Exhaust Kit GOINGSOLO2 V8 Bolt-Ons & Tunes 18 12-20-2011 07:17 PM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 05:26 PM
