Solo Performance
Old 02-01-2012, 12:03 AM   #1
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Driveshaft hitting heat shield?
I have a 3.5" one piece driveshaft. I was getting a bad vibration during acceleration and also a horrible noise while driving. I found that the driveshaft was hitting the top heat shield. I contacted the manufacturer and they had me send the shaft in for inspection. Come to find out, a piece was left out during assembly. They refurbished the shaft and sent it back to me. I reinstalled it, but I'm still getting the noise like it's rubbing the heat shield. The manufacturer says they've never had a driveshaft hit that shield, so something must be wrong with my car. What could cause this? Anyone else had this issue? Thanks.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 02-01-2012, 07:54 AM   #2
yotaman96
yotaman96's Avatar
Originally Posted by DietTab View Post
Take the shield off
That doesn't fix the issue. That's the shield that is attached to the gas tank. It shouldn't have to be removed.
Old 02-01-2012, 11:19 AM   #3
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
Can you bend the heat shield to get your clearance?
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 02-01-2012, 11:50 AM   #4
yotaman96
yotaman96's Avatar
Looking at it with the car on a lift, there's plenty of clearance. When driving, it rubs and I get the noise. As soon as I relieve any stress on it by pushing the clutch in or going to neutral, the noise stops. The driveshaft manufacturer says out of the 100's they've sold, I'm the only one that has had this issue. They're convinced something on my car has broken. With the car on the lift, I can't move the driveshaft up and down at all by hand.
Old 02-03-2012, 12:38 PM   #5
kmcd
kmcd's Avatar
One thing to consider: Even though our differential is theoretically stationary because of the independent rear suspension, I still think it will be slightly lower on the lift (relative to the gas tank) because you're subtracting a couple of thousand pounds that would normally push it up and adding several hundred pounds of wheels and suspension that are now pulling it down. I don't know if the difference would be great enough to explain your problem or not.
Of course, I'm making the assumption that you're lifting it by the frame. If it's a drive-up lift, it obviously won't affect your clearance.
Old 02-03-2012, 12:41 PM   #6
kmcd
kmcd's Avatar
The drive shaft will also move slightly as the engine torques, which would explain why it only occurs when it's under a load. If you could modify that shield slightly, it might cure your problem.
Old 02-07-2012, 04:47 PM   #7
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
What about the transmission mounts?
Old 02-07-2012, 05:35 PM   #8
yotaman96
yotaman96's Avatar
No issue that I can find. The marks on the heat shield were due to a part being left off the driveshaft when it was assembled. I had to send the driveshaft back and it was rebuilt. I was still getting the noise, so I assumed it was still hitting. I took the heat shield completely out and went down the road. I could still hear the noise. I noticed one of my aftermarket axles was leaking worse than usual. The axle has started to slide out of the differential. I'm hoping that's the noise I'm now hearing. Wish me luck.
Old 02-07-2012, 06:34 PM   #9
PQ
Booooosted.
PQ's Avatar
Old 02-08-2012, 02:39 PM   #10
kmcd
kmcd's Avatar
Let us know how it turns out.
Old 03-07-2012, 04:53 PM   #11
yotaman96
yotaman96's Avatar
Reinstalling the axle did not fix my problem. I had the car on the dyno yesterday and the operator felt the vibration. He said it felt like a bad u-joint. I'm also wondering if my pinion bearing was damaged when the driveshaft was hitting the heat shield. I'm tired of uninstalling and reinstalling stuff to try an figure this out.
Old 03-07-2012, 05:24 PM   #12
PQ
Booooosted.
PQ's Avatar
Shit.
Maybe the bolts on the drive shaft?
Old 03-07-2012, 05:25 PM   #13
austinjames
Account Suspend...Right
austinjames's Avatar
Drives: Synergy LS & Vulcan 1600cc
thats what she said
austinjames is offline   Reply With Quote
Old 03-07-2012, 05:31 PM   #14
yotaman96
yotaman96's Avatar
Shit.
It's a 1 piece aluminum shaft. Nothing wrong with the bolts.
Driveline Guru's anyone have adjustment specs (driveshaft center bearing adjustment) 55Designs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 09-20-2010 07:38 PM
NSCRA: August 29th, 2010, THE HEAT IS ON! torque solution Dragstrip and Launch Techniques Discussion 0 08-14-2010 10:58 AM
drive shaft/heat shield nicekitty Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 12-18-2009 02:27 PM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 0 09-30-2009 03:03 AM
Heat shield rattle?? Anybody else.. Rallyman6 5th Gen Camaro SS LS LT General Discussions 7 06-16-2009 05:27 PM
