Emblempros
Old 03-07-2012, 05:48 PM   #15
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by yotaman96 View Post
It's a 1 piece aluminum shaft. Nothing wrong with the bolts.
Still has to bolt on to the dampeners on each end???
Old 03-07-2012, 06:08 PM   #16
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Yes, but I've had it off several times trying to figure out the issue. There's nothing wrong with the bolts. I may put the stock driveshaft in and see if I still have issues. I'll have to get some new bolts since I didn't keep mine. Plus, if that's the problem, I'll have to get another driveshaft and swap again. I just want it fixed. I'm tired of messing with it.
2010 IOM Camaro 2SS/RS manual trans (Sold)
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 03-07-2012, 06:22 PM   #17
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
More than likely the Driveshaft itself is not at fault. Something is not lining up in your car like it should.
Sounds like something is flexing.
Check the Diff bushings and the transmission mount and motor mounts.
Also check the cradle bushings.
If the fuel tank has ever been removed it may not be seated all the way. Same with the heat shield.
Good Luck!
Squintz Palladoris is offline   Reply With Quote
Old 03-07-2012, 06:28 PM   #18
PQ
Booooosted.
PQ's Avatar
Well if you took the drive shaft out yourself then you would know.
Hell, other than checking of the mounts and bushings I haven't got a clue.
Before I replaced my drive shaft when the hanger bearing came unpressed I had a similar deal. Only on acceleration would it shake. Replaced the stock shaft (with another stock shaft) and all was good.
BUT, I had a noise AND it was a two piece shaft. Obviously yours isn't doing that with no bearing in the middle.
Old 03-07-2012, 06:34 PM   #19
yotaman96
yotaman96's Avatar
Good Luck!
The fuel tank has been out, but the issue was there before I took it out. I put solid mounts in the cradle when the fuel tank was out. Motor mounts, trans mount, and differential bushings appear to be fine. The problem started after the LS Fest where I autocrossed and took two runs down the drag strip. The driveshaft wasn't assembled properly and when I put some power to it, it crushed some of the aluminum in the driveshaft. I sent the driveshaft back, they rebuilt it and I received the same one back.
Old 03-07-2012, 08:16 PM   #20
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
put stock driveshaft back on and then try it !
Whipped416 is offline   Reply With Quote
Old 05-09-2012, 11:46 AM   #21
jrod_z28
jrod_z28's Avatar
Drives: 2012 VR Camaro ZL1
Did you ever get the issue fixed? I'm getting a heat shield rattle and can't seem to figure out where its hitting.
jrod_z28 is offline   Reply With Quote
Old 05-09-2012, 12:11 PM   #22
PQ
Booooosted.
PQ's Avatar
If you have the stock mufflers it could be that. Sounds like what you'd expect from a heat shield rattle. I had it bad when I had the stock cans on.
These things are so hard to find sometimes.
Old 05-09-2012, 12:11 PM   #23
yotaman96
yotaman96's Avatar
Yes, the driveshaft was not assembled properly from DSS.
Old 05-09-2012, 12:27 PM   #24
PQ
Booooosted.
PQ's Avatar
Well thatnks for the update doo doo head.
That's awesome. Glad to hear it's all good.
I'd like a better DS. I couldn't believe how thin these things are when I replaced my broken one for another stocker.
Old 05-09-2012, 02:29 PM   #25
yotaman96
yotaman96's Avatar
My bad. Been dealing with other issues.
Old 05-09-2012, 02:37 PM   #26
PQ
Booooosted.
PQ's Avatar
Holy crap. What kind of power did THAT?
Old 05-09-2012, 02:49 PM   #27
yotaman96
yotaman96's Avatar
625 at the wheels and some wheel hop. DSS said that driveshaft had a defective weld. It was 2 days old.
Old 05-09-2012, 02:54 PM   #28
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
I had the same issue with my driveshaft hitting the heat shield. We have to bend the shield up so it would stop hitting. I also have a lot of vibration abouve 90mph, rotated the DS a couple time and it temporarily fixes the vibration but it doesn't go away completely.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Driveline Guru's anyone have adjustment specs (driveshaft center bearing adjustment) 55Designs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 09-20-2010 07:38 PM
NSCRA: August 29th, 2010, THE HEAT IS ON! torque solution Dragstrip and Launch Techniques Discussion 0 08-14-2010 10:58 AM
drive shaft/heat shield nicekitty Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 12-18-2009 02:27 PM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 0 09-30-2009 03:03 AM
Heat shield rattle?? Anybody else.. Rallyman6 5th Gen Camaro SS LS LT General Discussions 7 06-16-2009 05:27 PM
