02-01-2012, 09:53 AM | #1 |
Let's go Rangers!
SS springs in a V6
Morning All,
I have an opportunity to get a set of stock SS springs that I'd like to install on my V6 and have a couple of questions, # 1 being my priority. 1- Will this drop my car at all, not looking for a major drop, just a bit. 2- Will I feel any handling or comfort changes? 3- Any reason not to do this? 4- Any other benifit to doing this |
02-01-2012, 10:06 AM | #2 |
Drives: 2012 Camaro 2SS 45th Anniversary Ed Join Date: Oct 2011
Curious of the answers.
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
02-01-2012, 11:17 AM | #3 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
You should see a small change in ride height, but the spring rates are likely extremely similar. The difference in handling between the FE2 (V6) and FE3 (V8) packages make paying for used V8 parts pretty tricky. You will see a much larger performance increase with aftermarket components than moving from V6 to V8 parts.
That being said, if you get the parts for free or extremely cheap there is a tangable performance increase by moving from V6 to V8 springs and shocks. The real bang for your buck is definitely in the aftermarket though. Take a look at the small difference between the FE2 and FE3 sway bar packages compared to the large difference with our sway bars. Spring rates and ride height changes should be similar small changes. FRONT REAR |
02-01-2012, 12:03 PM | #4 |
Drives: Camaro Join Date: Jun 2009
Don't be cheap about it, do it right the first time, and not only will you be happier, but in the long run you will be saving money. Please feel free to give us a call with any questions you may have. Thanks Mike Haddad 310-412-8032 |
02-01-2012, 12:09 PM | #5 | |
If you end up with V8 parts for free theres no harm in swapping over, although you will end up needing an alignment afterwards which increases your costs. If given a choice between paying a little for OEM V8 parts or for Aftermarket pieces, I would absolutely choose aftermarket in a heartbeat. |
02-01-2012, 12:20 PM | #6 |
Drives: White M6 1LT RS Join Date: Mar 2010
Pfadt.. I put on pfadt front and rear bars on my V6 and eh..
But after I swapped to a FE3 suspension then I noticed a much bigger difference. Nyrfan.. http://www.camaro5.com/forums/showthread.php?t=199080
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
02-01-2012, 12:28 PM | #7 | |
Banned
02-01-2012, 01:21 PM | #8 | |
Drives: 2010 Camaro IBM 2LT/RS M6 Join Date: Sep 2009
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade. |
02-01-2012, 02:22 PM | #9 | |
Find a picture of a stock SS. That's how it looks. The ride is a little stiffer but no a big deal at all. You gain more with the handling.
Next mod: Done! |
02-01-2012, 03:53 PM | #10 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Follow your heart, Rangers Fan!
Go with SS springs and struts/shocks though. Not sure if the damping in V6 shocks is up to the task. Check E-baymotors-SLP for like new take-offs. Shipping is steep, but they could drop'em out of a plane without damage the way SLP wraps'em up! If you can do it yourself, its still a bargain, and you'd be doing an alignment with aftermarket parts too. SS stuff is firmer, but not jarring. Rear springs are 1.25" shorter than V6's, but don't compress as readily. The back of my V6 sat down 3/4". Front just 1/8th inch. Now she rides level- not butt in the air. Your sway bars do need some attention too. You can check my list of mods for my solution and I'm very pleased with the results! Have fun! |
02-02-2012, 06:24 AM | #11 |
Let's go Rangers!
Thanks guys for the advice! My spring are in route (thanks Stieger), now on the hunt for shocks/struts on ebay!!
Thread Tools | |
Similar Threads | ||||
CAMARO WIKI | Tran | Wiki | 65 | 12-14-2022 07:23 AM |
SS rear springs. | RSKUSTOMZ | Suspension / Brakes / Chassis | 8 | 12-31-2011 09:59 AM |
V6 owner, test drove SS, my thoughts. | AUS10BMX | 5th Gen Camaro SS LS LT General Discussions | 112 | 12-08-2011 08:02 PM |
Lowering Springs for V6 | Inuyashas_Brother | Suspension / Brakes / Chassis | 13 | 06-01-2011 11:33 AM |
Pfadt Springs - V6 vs V8 | fgraciano1980 | Suspension / Brakes / Chassis | 3 | 05-25-2011 02:30 AM |
