Old 02-02-2012, 09:21 AM   #1
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Add these to your second gear grind
OK Nate (from Tremec) please explain that
IDEALG is offline   Reply With Quote
Old 02-02-2012, 09:46 AM   #2
MIZ-ARO
MIZ-ARO's Avatar
Drives: 2012 Z71 Colorado
Exactly what mine is doing except I try not to force it through the grind, I just go to 3rd. Good find!
**GM Buyback** 2012 2SS/RS Convertible Hurst M6 Black/IOM/Orange Stripes #838
MIZ-ARO is offline   Reply With Quote
Old 02-02-2012, 09:50 AM   #3
IDEALG
IDEALG's Avatar
yeah mine isnt as bad as those but mine does it around 4000 rpm and higher.
disappointing.
Old 02-02-2012, 10:09 AM   #4
MIZ-ARO
MIZ-ARO's Avatar
And another... I shift between 2500 and 3000 and it still does it. That sound makes me cringe!
Old 02-02-2012, 10:23 AM   #5
IDEALG
IDEALG's Avatar
yup the old mighty grind. :(
Old 02-02-2012, 11:04 AM   #6
Russell James
Russell James's Avatar
Drives: '69 Drag, #37 TA Stock Car, '15 ILE
Originally Posted by IDEALG View Post
http://youtu.be/6HGin3Asbl4
http://youtu.be/kRAyvtl3To0
Nate needs to be renamed "Honey Badger".... cause he don't care:
Quote
"And if you own a TR-6060 factory equipped vehicle, you are not our customer"
End Quote
If you do hear from Tremec Nate, he'll blame it on the driver. .5% defect rate and he'll bet you $100 on that.
Old 02-02-2012, 11:11 AM   #7
IDEALG
IDEALG's Avatar
Quote
End Quote
you got that right!
Old 02-02-2012, 11:33 AM   #8
az'rail
Drives: the wife crazy
See the thing is this. Tremec is in this business to make money. Let's look at it this way. Let's say I go to good old Wally mart. I buy myself a nice pretty bike. Im out riding around having a good time and all of a sudden the right peddle snaps off. I'm faced with two options, either go to the store buy a new peddle and fix it myself or I take the bike back to Wally mart and get a new one. Most of us will take it back. I have my new bike and once again the right peddle snaps off again. As I'm walking (pissed at this point) back to Wally mart i notice snapped peddles scattered on the street. This is were the bike company makes money. For every one bike that is returned for a faulty peddle Wally mart has to buy a new one, and is stuck either with a bunch of broken bikes or sells them refurbished at a discount by buying the peddle that only that bike company makes. Either way the bike company (tremec) gets paid for every hunk of junk that goes out their door. So for some tremec lacky to post on a forum that we are not their customers is completely right...but we are the end users and we're the ones having to do all the leg work to get our cars fixed. I'm getting off my soap box now.
az'rail is offline   Reply With Quote
Old 02-02-2012, 12:31 PM   #9
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
...ummm OK? Ahhh huuhhh huhhh ahhhuuuhh
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
Old 02-02-2012, 07:56 PM   #10
kaylew78
Drives: 2011 rs/ss ls3
The cause of the problem: the stock clutch master cylinder simply doesn't flow enough fluid to push the clutch slave cylinder far enough to fully disengage the clutch. This produces extreme heat inside the bellhousing, boiling the fluid inside the hydraulic system (thus introducing air) and causing a faded (or totally dead) clutch pedal. Other side effects include difficulty shifting at high RPMs, difficulty engaging 1st and Reverse while stopped, shortened clutch life and shortened transmission life. We've been seeing this exact issue for years in many applications.via joey at tick performance..search the forum and give feedback.
kaylew78 is offline   Reply With Quote
Old 02-02-2012, 08:03 PM   #11
JoshBobGuptaMarley
Emerald Coast Camaros
JoshBobGuptaMarley's Avatar
Drives: '12 2SS/RS LS3 GBA
Really strange....
Muffler Delete, Cold Air Inductions intake, Technostalgia Sequential LED Tail Lights, Vmax CNC Ported TB, RX Catch Can, AAC LED Interior Lights (Aqua)
JoshBobGuptaMarley is offline   Reply With Quote
Old 02-03-2012, 11:07 AM   #12
Nessal
Drives: Exige, Miata, Ghia
Except that Walmart has an agreement with their suppliers to get back 100% of any returns.
Nessal is offline   Reply With Quote
Old 02-03-2012, 11:15 AM   #13
az'rail
Tremec will loose too much money if they adopted that type of agreement.
Not to mention that tremec will rather blame every one else instead of helping root the cause of the failures. What bugs me is if the transmission isn't the problem, then why is it that the problem spans other makes of cars? I have an M6 and I'm one of lucky ones that doesn't have a problem(shifts at any temp and any RPM). So why am I the lucky one? What makes my car so different from the other cars that have problems?
Old 02-03-2012, 11:26 AM   #14
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
This may very well be true but many of us have not experienced grinding with the Tremec 6spd in the SS cars. Is it possible there are some "weak" stock clutch master cylinders AND real 2nd gear syncro issues ??? In my own case I never had a problem either all stock OR since installing a remote clutch reservoir, installing a quality DOT4 fluid in the brakes and clutch system, properly bleeding the clutch hydraulic system and swapping the trans fluid to Mobil 1 synthetic ATF.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
anyone get their second gear grind fixed at a nj dealer? IDEALG V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 23 02-04-2012 10:35 AM
Another TR6060 with 2nd gear grind DRG BSTN SQUIRREL V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 12-16-2011 04:41 PM
2011 2SS/RS: Engine Squealing, Brake Squealing, 1,2nd Gear Grind, Please Help. qniknam Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 10-14-2011 04:01 PM
MAJOR UPDATE!!!! WE FOUND A CURE FOR SECOND GEAR GRIND!! IDEALG V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 54 10-07-2011 07:04 PM
2nd gear grind??!! 11SynergyGr&Bl Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 06-24-2011 07:28 PM
