RDP Motorsport
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Suspension / Chassis / Brakes Suspension, chassis, and brake components
Old 02-03-2012, 09:37 AM   #1
JusticePete
Needs Lowering
JusticePete's Avatar
Drives: Pedders USA Camaro Justice
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ
The ZL1 is now in production. While you are waiting for your ZL1, now is a good time to plan you suspension upgrades and Pedders is ready to help you with that.
You have been carefully building your 5th Gen into your vision of the Ultimate Camaro and now the ZL1 is making claim to that title!?! No worries. You can upgrade your FE3 or FE4 to ZL1 sway bars on steriods and more... with a little help from Pedders.
We'll start with the FE3 to beyond the ZL1 upgrade.
The Camaro SS FE4 suspension moves the rear sway bar endlink / drop link mounting close to the knuckle to increase efficiency. The stock bars are now solid 23mm front and 24mm rear. The ZL1 will have 25mm solid front bars and 28mm solid rear bars. Chevrolet moved from hollow to solid bars for strength and durability. They did well, very well
Pedders exists to take Modern Muscle to the next level and we have a particular affinity for the 5th Gen Camaro. Our FE4 / FE5 sway bars are solid. The front is 27mm and adjustable. The rears are 32mm. Our bar sets are sold with high efficiency OEM quiet front end-links and fixed position drop- links. How do they perform, do you really need to ask? The owner of this Camaro is a law enforcement professional with countless hours of driver training. His professional opinion -- 'Holy shit, man! The front HOOKED not even CLOSE to breaking traction and the back end stayed right with it. I mean....when the car turns, it TURNS.'
Our FE4 / 5 rear sway bars can be retro fit to any 5th Gen Camaro. The new Camaro rear lower control arms have the 'old' style close to the differential endlink mounting tabs and the 'new' close to the knuckle mounting hole. This is a smart choice by Chevrolet as one coomon part number can be used on all versions of the 5th Gen Camaro. The new OE lower rear control arms are inexpensive.
Why did Chevrolet make the change in rear sway bar geometry and size? To make the 5th Gen handle better. From day one of the 5th Gen the bias of the car has been heavy on understeer. This is a function of weight distribution, wheel base, track, wheel and tire size and of course sway bar strength. The FE4 addresses both with improved rear sway bar geometry and sway bar strength. The old bars were hollow. The new bars are solid, the material is stronger. The old bars were almost the same diameter (strength) front and rear. The new FE4 rear bar is 1mm larger than the front. It doesn't sound like much, but coupled with the increase in efficiency of the new outboard mounting position it is a big difference. The FE4 Camaro is far more balanced that the FE3 SS. It is more neutral and handles better in the corners.
The new FE5 ZL1 takes this all on steroids. The front bar goes up in size to 25mm and the rear bar a huge jump to 28mm. Talk about balance from the factory
At Pedders, even great isn't good enough. We have been using a dumbed down rear alignment with a 32mm bar to reduce understeer and improve cornering. We set the rear camber to half the front camber or even less. The on track results were excellent. We feel we had a ZL1 two years ago with our Pedders USA Camaro. Now, there is a ZL1 so we have been hard at work with our partners at Lingenfelter on the L/28. When you next see the L/28 it will be running Pedders new FE4 / FE5 / ZL1 sway bars.
Here is the new rear bar complete with Pedders drop-link. The rear bar is NOT adjustable because the FE5 / FE5 / ZL1 drop link design is most efficient when straight up at rest.
The new 32mm bar takes up space, but there are ZERO clearance issues.
V6 Brake Clearance
V6 Brake and Supercar Clearance
To get the aggressive alignment we wanted Pedders Extended Range Rear Camber and Toe bolts are necessary. They increase the adjustment range by 1 degree or in layman's terms a lot. We achieve this result my moving the eccentric to the outer edge of the bolt. The eccentrics are cut on a water jet, assembled in a jig and welded. This is a time consuming process. To finish the bolts we have them cadmium plated.
Eccentrics have a bad habit of drifting under high loads. We address that with more material. We make our eccentrics out of stock that is much thicker than the OEM bolts. More material means more strength and improved holding power.
We use a thick 'holding' nut and a thin jam nut. Unlike quenched nuts, you can use these again and again.
FE4 / FE5 / ZL1 Track Alignment
Front
Caster: Max it out with Pedders Caster Eccentrics
Camber: -2.3 Do NOT run a strut tower bar, let the car work for you in the turns. If you have one, take it off
Toe: OUT .5
Rear
Camber -2.5
Toe: IN .20
Pedders Full Camaro Alignment Kit is required.
  • The initial production for these made in the USA Pedders FE4 / FE5 / ZL1 27mm adjustable front with high efficiency OEM quiet front endlinks and 32mm rear bar with drop-links kits available on or about March 1st.
  • We have a retro-fit 32mm rear bar and drop links ONLY option for our clients that ready have our front bars.
  • If you have a ZL1 on order, now would be the ideal time to order your Pedders upgraded sway bars.
  • If you drag race, you'll want to upgrade to Pedders FE4 / FE5 / ZL1 32mm rear bar with OEM Drop-links to improve control of the rear wheels and load distribution. Yes we will have a drag race kit.
  • Pedders Extended Range Alignment Bolts are IN Stock.
  • GM FE4 / ZL1 Style Rear Lower Control Arms -- The part numbers for the FE4 / ZL1 Rear Lower Control Arms #20942237 Chevrolet MSRP $53 Each
Heath Bratcher, owner of American Muffler / Pedders in Fredericksburg Texas, Jimmy his lead Pedders Tech, myself and TAG UR IT
2012 ZL1 Sway Bar Upgrade and ZL1 Suspension Packages
Camaro Street Z -- Chevrolet built your ZL1 incredibly well, but not quite Pedders perfect. Adding our sub-frame and radius bush inserts increases the stability of the IRS while reducing dynamic camber changes. The inserts work with your OE bushes. When your ZL1 becomes a classic, removing the inserts will restore it to OEM condition and no one will ever know how much fun you had with them in.
EP1200 Camaro Rear Sub Frame Insert
EP6579 Camaro Front Radius Bush HD Inserts
Retail $349.65 EA Pre-Buy $314.69
Camaro ZL1 Drag -- You want to use all the ZL1 supercharged power you paid for and we are here to help. We'll increase the stability of your IRS with steel jacketed bushZ and full replacement sub-frame bushes. To better distribute the launch mode using all the electronic ZL1 wiZardry we replace your 28mm solid ZL1 bar with Pedders 32mm ZL1 bar. Zmoke'm if you got'm!
ZL1FE4RSWAY Camaro ZL1 FE4 Rear Sway
EP1167HD Zeta Rear HD Diff Mounts
EP1201HD Camaro HD Rear Sub Frame Repl
EP6578 Camaro Fnt Radius Rod Bush Ins
EP7323 Rear Knuckle Bushes
Retail $1,557.55 Pre-Buy $1,401.80
Camaro ZL1 Track I --
The ZL1 has been through the most extenZive Camaro track testing in the history of Camaro production, but enough is never enough. Using Pedders busheZ throughout your ZL1 suspension adds a new level of stability on track. We increase caster to provide a quicker steering wheel return to center. Dial in a Pedders ZL1 tight spec alignment and prepare to be exZited.
EP2112 Zeta Steering Rack/Pinion Mnt
EP6577 Camaro Front Radius Rod Bush
EP7264 Zeta Rear Lower Control Arm In
EP7265Z Camar Rear Trailing Arm Steel
EP7322 Camaro Rear Upper Control Arm
EP7323 Knuckle Bush
PDUSACAMFNT Camaro Front Alignment Kit
Retail $1,780.51 Pre-Buy $1,602.46
Camaro ZL1 Track II --
Your ZL1 delivered with exceptional stability and handling. You would have to be craZy to want more. Welcome to the aZylum and know you aren't alone. Using Pedders busheZ throughout your ZL1 suspension adds a new level of stability on track. We increase caster to provide a quicker steering wheel return to center. The solid 25mm front and 28mm rear Zway barZ are upgraded to solid 27mm adjustable front and 32mm rear barZ. Set the front bar to full soft and align to Pedders road course specification.
CAMARO ZL1 ZWAY Camaro ZL1 Zway Bar Z
EP7323 Knuckle Bush
Retail $2,382.14 Pre-Buy $2,143.93
ZL1 Justice -- What more could you want in a 5th Gen than a ZL1? Control. You want to control your ride height, control your damping rate and control your driving experience. We're not surprised. That is how we like it. Supercar coilovers feature independent coil pre-load and height adjustment with independent bound and rebound adjustment too. Pedders busheZ throughout your ZL1 suspension adds a new level of stability on track. We increase caster to provide a quicker steering wheel return to center. The solid 25mm front and 28mm rear Zway barZ are upgraded to solid 27mm adjustable front and 32mm rear barZ. You have control every every element of setup which is exactly what you wanted. We're here to deliver what you want, when you want it.
164086 Camaro Xa Supercar Coilover
EP7323 Zeta Rear Trailing ArmToe Link
PDUSACAMFULL Camaro Full Alignment Kit
Retail $6,169.90 Pre-Buy $5,552.10
2010 - 2011 to ZL1 Style Zway BarZ
Camaro ZL1 Conversion for Lowered 2010 - 2011 FE2 or FE3
Chevy did it right with the ZL1 and now you can apply ZL1 technology on steroids to your 2010 to 2011 FE3 SS in a turnkey package. The ZL1 outboard rear sway bar mounting points are more efficient than the original inboard mounts. The result in improved vehicle dynamics in a daily driver, at the strip or on a road course. The ZL1 delivers with solid sway bars for improved bar strength. The front bar is 25mm and the rear bar is 28mm. Pedders ZL1 bars are solid 27mm adjustable front and 32mm rear. You won't believe what you feel behind the wheel. The conversion kit includes everything you need to take an FE3 rear to ZL1 on steroids standards. Pedders sway bars, High Efficiency OE Quiet front adjustable endlinks, rear drop links and Chevrolet rear arms. This is a direct bolt in kit. Take off the OE FE3 bits and install your new ZL1 on steroids bits.
428020-27A Camaro Adjustable Front Sway Bar
423201210 High Efficiency OEM Quiet Adjustable Front Endlinks
ZDROPLINKS ZL1 Style Rear Sway Bar Drop Links for Lowered Camaros
Includes New GM ZL1 Arms
Retail $869.99 Pre-Buy $782.99
Camaro ZL1 Sway Conversion for OE Height 2010 - 2011 FE2 or FE3
Chevy did it right with the ZL1 and now you can apply ZL1 technology on steroids to your OE height 2010 to 2011 FE3 SS in a turnkey package. The ZL1 outboard rear sway bar mounting points are more efficient than the original inboard mounts. The result in improved vehicle dynamics in a daily driver, at the strip or on a road course. The ZL1 delivers with solid sway bars for improved bar strength. The front bar is 25mm and the rear bar is 28mm. Pedders ZL1 bars are solid 27mm adjustable front and 32mm rear. You won't believe what you feel behind the wheel. The conversion kit includes everything you need to take an OE Height FE3 rear to ZL1 on steroids standards. Pedders sway bars, High Efficiency OE Quiet front adjustable endlinks, Chevrolet rear drop links and Chevrolet rear arms. This is a direct bolt in kit. Take off the OE FE3 bits and install your new ZL1 on steroids bits.
428020-27A Camaro Front Sway Bar
New GM ZL1 Drop Links for OE Height Camaros
Camaro ZL1Sway Conversion Rear Bar ONLY for Lowered 2010 - 2011 FE2 or FE3
You already have a great set of Pedders sway bars, or a very good set of brand-x bars, on your LOWERED FE3 5th Gen. It drives well, but you know it will be better with the Pedders 32mm rear bar installed. You're spot on with your thinking. Take off your old inboard mount rear bar and bolt in a new ZL1 rear bar on steroids. Good just got BETTER.
Retail $514.04 Pre-Buy $426.64
We have TWO NEW Pace Car Package that use ZL1 Style Rear Sway Bars
FE4 Camaro Pace Car Package
Part #CAMARO PACE FE4
Model Year 2012 - on
The Camaro Pace Car Package has been updated to include Pedders 32mm ZL1 sway bar upgrade and droplinks.
In 2010 the on track NASCAR and Indy Camaro Pace Cars took the track with Pedders Xa coilovers, sway bars, radius and sub-frame bush inserts.GM asked Pedders to help them achieve a lower more aggressive stance for the Pace cars. Being Pedders we delivered a bit more adding some additional function to the GM request for a more aggressive look. In August of 2010 GM added a range of Pedders coilovers and sway bars to the GMPP range of products. You can expect your 5th Gen Pace Car to look and drive exactly as the on track pace cars. Adding a Pace Car Package hones your already sharp Camaro handling to a finely honed razors edge.
GMPP Note: This product is intended for use on racing and / or off road vehicles and is not authorized for use on street vehicles
Retail $2,582.95 Pre-Buy Price $2.324.66
Camaro Pace Car Pkg ZL1 Upgrade
Part #CAMARO PACE ZL1
Model Years 2010-2011 Includes New GM ZL1 Arms
The Camaro Pace Car Package has been updated to include Pedders 32mm ZL1 sway bar upgrade, NEW GM Rear Lower Control Arms and Pedders ZL1 droplinks.
Retail $2,672.95 Pre-Buy Price $2.405.65
Old 02-03-2012, 09:38 AM   #2
JusticePete
Needs Lowering
ZL1 Packages
Camaro Street Z Retail $349.65 EA Pre-Buy $314.69
Camaro ZL1 Drag Retail $1,557.55 Pre-Buy $1,401.80
Camaro ZL1 Track I Retail $1,780.51 Pre-Buy $1,602.46
Camaro ZL1 Track II Retail $2,382.14 Pre-Buy $2,143.93
ZL1 Justice Retail $6,169.90 Pre-Buy $5,552.10
Camaro ZL1 Zway Bar Z UPGRADE
Your ZL1 is so close to where you want it, if you could take out a bit of body lean, some roll and add just a bit more balance. It can't get any easier than this. Replace your solid 25mm front and 28mm rear ZL1 bars with Pedders solid 27mm adjustable front and 32mm rear. These are direct bolt up replacement parts. The adjustable front bar adds six level of fine tuning to get exactly the balance you want. Just when you thought your ZL1 couldn't get better, it did.
Camaro ZL1 Zway Bar Z UPGRADE Your ZL1 is so close to where you want it, if you could take out a bit of body lean, some roll and add just a bit more balance. It can't get any easier than this. Replace your solid 25mm front and 28mm rear ZL1 bars with Pedders solid 27mm adjustable front and 32mm rear. These are direct bolt up replacement parts. The adjustable front bar adds six level of fine tuning to get exactly the balance you want. Just when you thought your ZL1 couldn't get better, it did."]$769.99[/URL]
How to Order with the Pre-Buy
Your Pre-Buy can be executed by calling Pedders USA, LLC between the hours of 9 - 5 Central Time 248.522.8021 or you can email your order request to INFO@PeddersUSA.com Please include your full name, ship to address and daytime phone number. A 25% deposit will be taken at this time. Your parts will deliver to you no later than March 15. Two people called in today, I guess they couldn't wait, and paid in full. We have the best clients
Old 02-03-2012, 10:00 AM   #3
JusticePete
Needs Lowering
Pre-Order Priority Client List
1. MSW444
2. Addiction
3. Dragoneye
4. SSEOD
5. Avalnch
6. 600hp-lpe
7. 2ss-booya
8. sting808 Camaro ZL1Sway Conversion Rear Bar ONLY for Lowered 2010 - 2011 FE2 or FE3 Retail $514.04 Pre-Buy $426.64
9. anonymous Order for Now ZL1Sway Conversion Rear Bar ONLY for Lowered 2010 - 2011 FE2 or FE3 Retail $514.04 Pre-Buy $426.64
10.
11.
234,711,211. GTAHVIT Camaro ZL1Sway Conversion Rear Bar ONLY for Lowered 2010 - 2011 FE2 or FE3 Retail $514.04 Pre-Buy $426.64
Last edited by JusticePete; 02-09-2012 at 06:19 PM. Reason: Updated GTAHVIT Status
Old 02-03-2012, 10:26 AM   #4
garcmol
garcmol's Avatar
211. GTAHVIT
Old 02-03-2012, 10:38 AM   #5
JusticePete
Needs Lowering
Typo. I just fixed it.
Old 02-03-2012, 07:10 PM   #6
JusticePete
Needs Lowering
2010 to 2011 FE2 and FE3 ConverZion are now available for Pre-Order.
ZL1 Zway BarZ and ZuZpenZion PackageZ are now available for Pre-Order.
Old 02-03-2012, 08:22 PM   #7
sting808
Drives: 4 wheels
Pete,
Think you can use a safe, cost-friendly shipper for Hawaii? Please add me to pre-order.
Rear is lowered between 3/4" - 1". If I raise the car in the future, what is the acceptable tolerance before I need the longer drop links?
Also, I won't be able to take delivery during periods in March, can we discuss ship date options?
thanks
sting808 is offline   Reply With Quote
Old 02-03-2012, 08:44 PM   #8
JusticePete
Needs Lowering
Originally Posted by sting808 View Post
Pete,
Think you can use a safe, cost-friendly shipper for Hawaii? Please add me to pre-order. Done
Camaro ZL1Sway Conversion Rear Bar ONLY for Lowered 2010 - 2011 FE2 or FE3 Retail $514.04 Pre-Buy $426.64 10-4
Rear is lowered between 3/4" - 1". If I raise the car in the future, what is the acceptable tolerance before I need the longer drop links? Between 1/2 to 3/4 for ideal geometry. If you need to switch them out, let me know.
Also, I won't be able to take delivery during periods in March, can we discuss ship date options? Of course. Drop me email with your preferred ship dates.
PGB@PeddersUSA.com
thanks
Old 02-06-2012, 04:58 PM   #9
JusticePete
Needs Lowering
This bump is for the anonymous caller that just placed an order. Can we post your screen name?
Old 02-06-2012, 05:17 PM   #10
sting808
Drives: 4 wheels
Anonymous? Deb just returned my call. Ordered.
Old 02-06-2012, 05:47 PM   #11
JusticePete
Needs Lowering
Thank you for Choosing Pedders, AGAIN!
Old 02-06-2012, 06:46 PM   #12
Zman12
Zman12's Avatar
Drives: 2010 Camaro 2SS
Pete,
Quick question would changing out the lower arms call for a new alignment?
You are killing me with coming out with these new parts! I am just trying to get all I have installed now.
Also how big is the difference gonna be between the Ep1167hd I have now getting ready to install and the new Ep1168hdz. Ah this never ends.
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
Zman12 is offline   Reply With Quote
Old 02-06-2012, 06:57 PM   #13
JusticePete
Needs Lowering
Originally Posted by Zman12 View Post
Pete,
Yes the new rear arms will require an alignment because the rear camber bolts are removed in the process. You could mark them and use the witness marks to get the alignment close to where is was, but rear tires are far more expensive than an alignment.
If you already have the EP1167HD bushes, I'll accidentally pack the new EP1167HDZ rear bush with the kit
Old 02-07-2012, 12:18 AM   #14
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: THRSS #2 / CGM#1
Pete....I can't say thanks enough. I LOVE the new feel and ride of my 2010. Totally new feel...and being able to adjust the ride height and comfort with those coil overs?!?! AWESOME!....(not that I am going to change right height, but the ability to do so is pretty d@mn cool). I do, however, like to fiddle with the firmness of the ride.
If I may...
For anyone contemplating, don't just take my word for it. If you are unsure, ask around to the others that have already done suspension upgrades. I don't think you'll find a single person who will say that the upgrades they did were not worth it.... I had the previous Pedders rear sway and Pete helped me to upgrade to the FE4/5 32mm bar with endlinks (and LCA's with inner Pedders bushes) and it made a BIG difference. That, along with the subframe bushes, radius bushes, front sway, XA's....WOAH.
I really can't wait for the next Harris Hills date so I can find out just how far I can push it now. It's going to be a BLAST....not to mention C5FIII Auto-X is going to be SWEET now!!!
The build of THRSS #2
Old 02-07-2012, 07:50 AM   #15
1camaro70
1camaro70's Avatar
Drives: 2010 2SS RS L99
what about a package with Pace Car, Xa coilovers plus the ZL1 bars for 2010?
1camaro70 is offline   Reply With Quote
Old 02-07-2012, 08:11 AM   #16
JusticePete
Needs Lowering
We have already sold two, even thought it isn't officially in the catalog. We'll make it official today and get the price in the catalog.
Old 02-07-2012, 03:08 PM   #17
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Drives: #22 Tom Henry Racing 2010 2SS/RS
1. MSW444
2. Addiction
3. Dragoneye
4. SSEOD
5. Avalnch
6. 600hp-lpe
7. 2ss-booya
10.
11.
1,211. GTAHVIT
DUDE!!!!!
Old 02-07-2012, 03:09 PM   #18
JusticePete
Needs Lowering
DUDE!!!!!
Damn, typo. FIXED
Old 02-07-2012, 03:11 PM   #19
JusticePete
Needs Lowering
Old 02-07-2012, 03:34 PM   #20
2010 Indy Pace
Pace Car 2.0
2010 Indy Pace's Avatar
Drives: 2010 Indy 500 Pace Car - Pedderised
So since I already have the Pace Car package I would need to buy: ZL1Sway Conversion Rear Bar ONLY for Lowered 2010 - 2011?? How about a trade-in, my stuff is like new?
Pace Car 2.0: Mod List & Photo Album
2010 Indy Pace is offline   Reply With Quote
Old 02-07-2012, 03:39 PM   #21
JusticePete
Needs Lowering
Correctamundo!
Your rear bar and state-of-the-art endlinks should sell quickly on the C5 user classifieds
Old 02-07-2012, 04:25 PM   #22
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Damn, typo. FIXED
Old 02-07-2012, 04:27 PM   #23
JusticePete
Needs Lowering
1. MSW444
2. Addiction
3. Dragoneye
4. SSEOD
5. Avalnch
6. 600hp-lpe
7. 2ss-booya
10. GTAHVIT Camaro ZL1Sway Conversion Rear Bar ONLY for Lowered 2010 - 2011 FE2 or FE3 Retail $514.04 Pre-Buy $426.64
11.
11,211.
Fixed
Old 02-07-2012, 04:29 PM   #24
GTAHVIT
One Lucky Guy.
GTAHVIT's Avatar
Fixed
You know.... I can edit your posts...
Maybe we need to slash the prices on your packages?????
Old 02-07-2012, 04:31 PM   #25
JusticePete
Needs Lowering
Fixed
1. MSW444
2. Addiction
3. Dragoneye
4. SSEOD
5. Avalnch
6. 600hp-lpe
7. 2ss-booya
10.
11.
4,711,211. GTAHVIT Camaro ZL1Sway Conversion Rear Bar ONLY for Lowered 2010 - 2011 FE2 or FE3 Retail $1514.04 Pre-Buy $1426.64
