Jason 98 TA
Old 02-04-2012, 08:48 AM   #1
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Adding/checking trans fluid with adm trans cooler
Can anyone tell me if i need to add trans fluid when using adm cooler and bypassing stock cooler? And how do i check trans fluid level?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 02-05-2012, 09:21 AM   #2
jsharp
jsharp's Avatar
Help?
Old 02-05-2012, 05:20 PM   #3
stso634
stso634's Avatar
Yes, you will need to add fluid after you install the ADM cooler. You add it directly at the transmission, since there is no other way.
stso634 is offline   Reply With Quote
Old 02-05-2012, 08:37 PM   #4
jsharp
jsharp's Avatar
How much and what kind?
Old 02-06-2012, 08:51 AM   #5
jsharp
jsharp's Avatar
Is there a diy on adding tranny fluid and where to get the oem kind
Old 02-06-2012, 08:56 AM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
What kind should be in the back of the owner's manual - under maintenance. Don't know how much though.
Click to view my build thread
Old 02-06-2012, 10:11 AM   #7
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
jsharp, the tranny takes Dexron VI fluid. There is a filler plug on the passenger side of the case. The fluid has to be pumped into the filler hole. It is important to have the transmission fluid warmed to the proper temperature.I believe it's between 87 F and 125 F. If you service the tranny when the fluid is colder than 87 F, the tranny will be too full and if you service the fluid when the fluid temp is hotter than 125 F, the fluid level will be underserviced. To get the right fluid level you must have the engine running, in park,and the tranny fluid temps in range. Then remove the fluid level check plug on the bottom of the pan. When serviced properly, the fluid will just drip slightly from the hole.
2SSCAMARO is offline   Reply With Quote
Old 02-06-2012, 06:57 PM   #8
jsharp
jsharp's Avatar
sounds fun lol. Thanks! So your saying get under the car while its running to add fluid or just let the engine trans warm up and then shut down and add fluid?
Old 02-06-2012, 08:54 PM   #9
2SSCAMARO
2SSCAMARO's Avatar
LOL Yes the engine has to be running when you remove the check plug on the bottom of the tranny pan.
Old 02-07-2012, 05:13 PM   #10
jwithers2005
Drives: 2010 2SS L99/A6
simply put,, it's a sonofabitch without the right equipment......the process is simple enough, but without a lift and some way to pump fluid into the transmission, it can be a real pain.....
with just a cooler installation, you shouldn't have lost enough fluid (normally) to hurt anything if you wanted to drive it to a shop to have someone with a lift and a fluid pump top off the trans fluid. Totally worth the 25 or 30 bucks it would cost, in my opinion...the fluid level needs to be checked after a new cooler is installed, without a doubt..
2010 2SS L99/A6
jwithers2005 is offline   Reply With Quote
Old 02-09-2012, 09:44 PM   #11
jsharp
jsharp's Avatar
Wat about a shop with a pit?
Old 02-09-2012, 09:47 PM   #12
jsharp
jsharp's Avatar
Anybody got a pic of the check plug i dont want to accidently pull the drain plug!
Old 02-11-2012, 04:40 PM   #13
jwithers2005
The only plug on the bottom of the pan is the fluid level check plug..
2010 2SS L99/A6
Old 02-11-2012, 06:00 PM   #14
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I installed a dip stick in my tranny so it will make it earlier when I do service it.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Over The Hill Gang , Old Farts with Young Cars 68 Z/28 Off-topic Discussions 38013 02-20-2018 08:30 AM
*NEW* StopTech high-performance brake fluid Anthony @ LG Motorsports Suspension / Brakes / Chassis 0 12-20-2011 05:45 PM
FLUID IN MY MAN, TRANS carls2010 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 7 10-05-2011 12:34 PM
ADM Performance "Street" & "Race" intakes in stock and ready to ship! FREE SHIPPING!! Apex Motorsports V8 Bolt-Ons & Tunes 23 05-22-2010 08:14 AM
Aftermarket cooling The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-11-2010 06:40 AM
