Billet Custom
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 02-04-2012, 09:49 AM   #1
BossHogg
Mexican SS
BossHogg's Avatar
Drives: Black 2SS/RS
Weird Ticking for about 5 seconds after startup.....
Not sure what this ticking noise is but happens surely in the morning as soon as i start the car... it also seems to happen after the car has sat for a few hours..... Thought id check here first before bringing it to the dealership here.....
Black 2010 2SS/RS...
HP Tune..
Volant Cold Air Intake..
Smoked Tail Lights-Reverse Lights -Front/ Rear Corner Lenses
Painted Bow Ties front & rear
Pacesetter Long Tube Headers
Magnaflow Competition Cat Back Exhaust....
Eibach Pro Lowering Kit
Painted Heritage Grille
1969 Camaro Emblems
Phoenix Gold I-Amp Sound System
22 inch Replica Wheels:
[I]VMAX Ported Throttle Body [I/]
BossHogg is offline   Reply With Quote
Old 02-04-2012, 09:58 AM   #2
ericgoul
ericgoul's Avatar
Drives: 2010 CAMARO 2SS/RS IBM L99
L99 or LS3 ?
CAI intake, Flowmaster AT axleback, 1 7/8 ARH with Cats, JRE Tune.
ericgoul is offline   Reply With Quote
Old 02-04-2012, 10:06 AM   #3
BossHogg
Mexican SS
BossHogg's Avatar
L99
HP Tune..
1969 Camaro Emblems
Old 02-04-2012, 10:20 AM   #4
ericgoul
ericgoul's Avatar
Check if it come from your lifter. It already happen to my car. I have 16 new lifters now.Ī found this bulletin before i went to my dealer " Default #10-06-01-007B: Active Fuel Management (AFM) Engine, Valve Lifter Tick Noise at Start
#10-06-01-007B: Active Fuel Management (AFM) Engine, Valve Lifter Tick Noise at Start Up When Engine Has Been Off for 2 Hours or More (Evaluate Noise and/or Replace Valve Lifters) - (Nov 17, 2010)
Subject:
Models:
2007 Buick Rainier
2009 Buick LaCrosse Super, Allure Super (Canada Only)
2007 Cadillac Escalade
Built Prior to April 1, 2006 with 6.2L Engine RPO L92 (These engines were built with AFM Hardware but the AFM system was disabled)
2010-2011 Cadillac Escalade
2007 Chevrolet Monte Carlo
2007-2009 Chevrolet Impala
2007-2011 Chevrolet Avalanche, Silverado, Suburban, Tahoe, TrailBlazer
2010-2011 Chevrolet Camaro SS
2007-2011 GMC Envoy, Sierra, Yukon
2007-2008 Pontiac Grand Prix
2008-2009 Pontiac G8
2007-2009 Saab 9-7X
Equipped with AFM (Active Fuel Management) and V8 Engine RPO L76, L94, L99, LC9, LFA, LH6, LMG, LS4, LY5 or LZ1
Attention:
This bulletin only applies to the AFM V8 engines listed above. It DOES NOT apply to Non-AFM Engines. If you are dealing with a Non-AFM engine that is experiencing a similar noise, please refer to Engine Mechanical > Diagnostic Information and Procedures > Symptoms in SI.
This bulletin is being revised to add the 2011 model year. Please discard Corporate Bulletin Number 10-06-01-007A (Section 06 - Engine/Propulsion System).
Condition
Some customers may comment on an engine valve lifter tick noise that occurs after the engine has been shut off for at least two hours. The tick noise may last from two seconds to ten minutes.
Cause
This condition may be caused by any of the following:
Aerated oil in the valve lifter body, resulting in the valve lifter being unable to purge the air quickly.
A low engine oil level or incorrect oil viscosity.
Dirty or contaminated oil.
A low internal valve lifter oil reservoir level.
Debris in the valve lifter.
A high valve lifter leak down rate.
Correction
If the SI diagnostics do not isolate the cause of this valve lifter tick noise and normal oil pressure is noted during the concern, perform the following steps:
Inspect the engine oil condition and level. Refer to Owner Manual > Service and Appearance Care > Checking Things Under the Hood > Description and Operation > Engine Oil in SI. ?If the engine oil is more than one quart low, an incorrect oil viscosity is being used or if poor quality/contamination is observed, change the oil and filter.
Note: Allow at least a two hour soak time between engine OFF and start up when evaluating the tick noise.
Start the engine and evaluate the valve lifter tick noise. ?If the valve lifter tick noise is still present, replace all 16 valve lifters. Refer to Valve Lifter Replacement in SI.
Parts Information
Note: A V8 AFM engine requires 8 AFM lifters and 8 non-AFM lifters for a total of 16 lifters.
Part Number Description Qty
12576400 Non AFM Hydraulic Valve Lifter 8
12632143 AFM Hydraulic Valve Lifter 8
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Š 2010 General Motors. All rights reserved."
Old 02-04-2012, 10:37 AM   #5
BossHogg
Mexican SS
BossHogg's Avatar
Hey bout how long does this process take ? Man the dealership here is so slow but i guess if i gotta go then i gotta go.....
HP Tune..
1969 Camaro Emblems
Old 02-04-2012, 10:53 AM   #6
ericgoul
ericgoul's Avatar
It take : 1 day for all test, it take 2 weeks to receive the lifters, 2 to 3 days to replace the lifters. ( 2 days if your dealership don't forget to order the gaskets !!). I lost my car during 4 days total with the test included. I don't know if it's an illusion but my car run better.
Old 02-04-2012, 11:00 AM   #7
BossHogg
Mexican SS
BossHogg's Avatar
great info thanks buddy..... im calling first thing monday morning.....
HP Tune..
1969 Camaro Emblems
Old 02-04-2012, 11:03 AM   #8
ericgoul
ericgoul's Avatar
Old 02-04-2012, 11:05 AM   #9
BossHogg
Mexican SS
BossHogg's Avatar
before i do this...... there is nothing i can try before i go there..... maybe a small chance , anything.... fingers crossed...
HP Tune..
1969 Camaro Emblems
Old 02-04-2012, 11:11 AM   #10
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
If it's the lifters, then only way to fix it is to replace them.
Stieger's BLACK Build Thread thanks for the sig Russ
Old 02-04-2012, 11:28 AM   #11
BossHogg
Mexican SS
BossHogg's Avatar
Cool kinda figured that i was just hoping and praying for another fix... u know how that is....
HP Tune..
1969 Camaro Emblems
Old 02-04-2012, 12:20 PM   #12
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2011 2SS RS M6 CGM
An exhaust leak can sound like this as well. Check around your exhaust gaskets for any indication.
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 02-04-2012, 12:39 PM   #13
BossHogg
Mexican SS
BossHogg's Avatar
Imma have to take a look at that also..... i really gotta get this shit fixed........Thanks fellas
HP Tune..
1969 Camaro Emblems
Old 02-05-2012, 07:33 AM   #14
L99CAMA2011
L99CAMA2011's Avatar
Drives: 2012 Camaro 1ss LS3 (THE KRAKEN)
My L99 sounded like it had this issue and since I started using Amsoil Extended Life the startup tick went away up till now and that was for the last 29000 miles. But I think the lifters still may need replacing. The only real fix is to have them replaced.
Old 02-05-2012, 04:15 PM   #15
BossHogg
Mexican SS
BossHogg's Avatar
What exactly is Amisol Extended Life?
HP Tune..
1969 Camaro Emblems
Old 02-05-2012, 06:35 PM   #16
Andy@AMSOIL
Drives: 4 wheels
10w30 or 5w30, XL, OE or Premium
We also recommend zrod 10w30, designed specially for big engines
Andy@AMSOIL is offline   Reply With Quote
Old 02-05-2012, 07:12 PM   #17
BossHogg
Mexican SS
BossHogg's Avatar
Oh ok I gotcha.....thanks
HP Tune..
1969 Camaro Emblems
Old 02-06-2012, 01:32 PM   #18
OBSSEST
Drives: 2010 Camaro 2SS RS, Black
I think there is some level of valve tick that is acceptable after a cold startup and can be considered "normal". Mine will do this intermittently but it lasts for only 2-3 seconds.
I think some others have had the tick continue for minutes or even longer. Personally, I don't trust my dealership to crack open the engine and do this repair properly until something really breaks. I've read that some people still have a few second ticking noise AFTER the valve replacement.
So, I'd rather live with it and do nothing for now. I might try Amsoil for my next oil change just to see if it makes a difference.
OBSSEST is offline   Reply With Quote
Old 02-06-2012, 01:40 PM   #19
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
and what would happen if it didn't get fixed? my 2004 GMC Sierra with the 5.3l just started making what I believe to be the ticking lifter noise.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 02-06-2012, 05:48 PM   #20
whitedemon
whitedemon's Avatar
Drives: 2010 Camaro SS
My l99 did the same thing. Bring it to the dealer, this is not uncommon so the dealer should be fairly quick. I am a GM tech and my dealership stocked all the parts, I did my total job in a day. Its not a huge job and it fixed mine and the other dozens we do too. Warranty pays for it so no reason not to get it done. good luck
Sent from my SAMSUNG-SGH-I777 using Tapatalk
2010 Camaro 2SS/RS, L99, OBX Longtube Headers, Magnaflow 3in Comp Cat Back w/ added Dynomax Bullet Race Mufflers, SCT Tuner w/ JRE Tune, CAI Black Intake w/ JRE Race Scoop, Eibach Pro Springs, Custom Sequential Tailights
whitedemon is offline   Reply With Quote
Old 02-07-2012, 11:31 PM   #21
bumblebeecamaro
ZL1 lover-4-life
bumblebeecamaro's Avatar
Drives: 2013 CRT ZL1
my engine has been fine for 17K miles. then, about two days ago, I heard a ticking noise as soon as I started the engine. it scared the crap out of me so I shut it off, restarted it and it was fine.
it hasn't happened again and I'm hoping it was a fluke. (wishful thinking I'm sure).
I'd like to think GM would replace the lifters in my L99 car. but I'm thinking they won't due to the S/Cer on my engine.
what do you guys think?
bumblebeecamaro is offline   Reply With Quote
Old 02-29-2012, 07:33 PM   #22
Doomsday2005
Doomsday2005's Avatar
Drives: SIM 2011 Camaro 2SS/RS
I have a 2011 L99 SS that has made a ticking noise since day one and it does not stop after you start it, it does it as long as it is runing. It is very noticeable so i took it back to the dealer about 2 days after I bought it and they said it was the high pressure fuel injectors. I waited another 3 months or so and took it to another dealership for a second opinion same result, they said it was the high pressure fuel injectors. My car has 1786 miles on it and it's not my daily driver, I have had it since Oct of 2011. This thread kind of has me worried that it's not the injectors. Any advice?
A6,LG Superpro 1 7/8 LT, Rotofab CAI, MSD Wires w/Boots, Eibach Pro Springs, Flowmaster Outlaw AB, TSW Nurburgring, Nitto Invo's, NS-1 Black Carbon Fiber Stripes, Oracle LED Conversion, Jannetty Racing Tune.
Doomsday2005 is offline   Reply With Quote
Old 02-29-2012, 07:50 PM   #23
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
So just wondering...is this lifter issue due to AFM? Is it better if the lifters are working all the time, like with AFM turned off, or would that make matters worse? How many of you who've had AFM tuned out have had this lifter problem?
Solo Mach XL with J-Pipes ˇ Cold Air Inductions Intake w/JRE Scoop ˇ Jannetty SCT Tuneˇ Roto-Fab Washer Bottle ˇ Defenderworx Bowties ˇ Vmax Ported TB ˇ LPE 3.70 Gears ˇ Dynatech SuperMAXX Headers ˇ Elite Engineering Tunnel Brace ˇ CFD Pistol Grip TapShifter ˇ GM Strut Tower Brace
E.T. is offline   Reply With Quote
Old 03-01-2012, 12:01 AM   #24
510SS
510SS's Avatar
Drives: 2010 1SS Silver Ice Metallic
Mine only does the ticking a couple seconds after cold start up. Never thought anything of it.
510SS is offline   Reply With Quote
Old 03-01-2012, 06:55 AM   #25
The SwiftChancelor
The SwiftChancelor's Avatar
Drives: SGM, 2011 2SS/RS, L99
Mine does the same thing. I heard of a few reasons why it could do this, most recently I heard it was the fuel pump. Not sure but like most have stated its just a few seconds on certain mornings.
K&N air intake, Solo w/Jpipes axleback, SP 1 7/8 LT headers
The SwiftChancelor is offline   Reply With Quote
PWA 3: Dark of the Lounge CamaroSpike23 Off-topic Discussions 159906 08-09-2012 03:51 PM
10 seconds of "clicks" after 3 mins 30 seconds of driving shiftz33 5th Gen Camaro SS LS LT General Discussions 57 01-16-2012 06:36 AM
Weird Ticking Noise From 9 to 5 MPH Bowtie Guy Z28 5th Gen Camaro SS LS LT General Discussions 4 05-25-2010 11:15 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
