BORLA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Southwest > Local Marketplace
Old 02-04-2012, 09:37 PM   #1
Azfalconfixer
Azfalconfixer's Avatar
Drives: 2010 2SS/RS SIM
LSR Short Throw Shifter and MSD Plug Wires
Lightly used LSR Tri-Ax Short Throw Shifter for 2010, 2011 Camaro SS LS3. Only used for about 3000 miles. Works great, easy to install.
$125obo
I also have a set of used red MSD plug wires for SS Camaro, about 3000 miles on them, $45.
LSR's new Camaro Tri-Ax shifter is designed to be fully adjustable in Height and Throw! The main lever is made from Billet Steel and is Nickel plated for smooth operation and durability. Multiple shift knobs are available. Both engraved and non-engraved in several different colors.
Even if you want to keep your stock shift knob we have a kit for you! Height can be adjusted from Stock, with a 20% reduction in throw, to 1" shorter then stock with a 33% reduction in throw. It is infinitively adjustable in height and throw through that range. LSR's shifter also carries a LIFETIME Warranty!!
Product Benefits
20%-33% reduced throw
Durable delrin linkage insert
Long lasting billet steel and aluminum construction
Will not corrode, nickel plated
Made in America
Lifetime warranty - We make it, we guarantee it!
Vehicle Fitment
2011 Chevy Camaro 6.2L V8 LS3
2010 Chevy Camaro 6.2L V8 LS3
USAF Retired
Azfalconfixer is offline   Reply With Quote
