Old 02-05-2012, 08:41 PM   #1
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
M6 Rpm level 6 build
I was wondering who has had the level 6 build by RPM done.. i had mine done and it is going in this week with the rest of the goodies... i am just trying to see what to expect.
Whipped416 is offline   Reply With Quote
Old 02-05-2012, 08:57 PM   #2
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
I will be watching this intently. The last part of my drivetrain to be upgraded will be the tr6060. I was adivsed that if all else is setup properly, and with a centri blower, the tremec is plenty stout to deal with gobs of HP. We will see as my clutch, diff, DS and axles are all being upgraded with GForce Engineering components this month. So, the last parts of the equation will be the tranny and the stroker motor. Lots of very reputable guys/gals on this site said the tr6060 is very stout and doesnt need any attention...we will see...
subscribed
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 02-05-2012, 09:11 PM   #3
1stGM
1stGM's Avatar
Drives: IOM 2SS/RS M6
Not hijacking, but I just had a Tick level 2 build done.... I just installed it and will be installing my 9" kit this week... I will be giving a thorough review of this trans build once I get some miles on it... This should give people a couple reviews of what is out there are far these 6060s go...
1stGM is offline   Reply With Quote
Old 02-05-2012, 09:34 PM   #4
BullF-16
BullF-16's Avatar
Again, waiting for options on this M6. will be munching some popcorn in the mean time
Old 02-05-2012, 11:55 PM   #5
Whipped416
Whipped416's Avatar
wont be long and i will give u a good review on my Rpm Level 6... will be back pushing 850 rwtq through it ... i had 600 rwhp with my whipple for about 2 k miles and when i seent the tranny to Rpm they said it looks great with no damage to any hard parts.. but the whipple was installed on the car new so it only had a total on 2 k miles... but very spirited driving..
Old 02-06-2012, 09:53 PM   #6
Whipped416
Whipped416's Avatar
so noone here has the Level 6 from rpm??
Old 02-06-2012, 09:56 PM   #7
1stGM
1stGM's Avatar
I am pretty sure ACOWHERD on here had one.... he has since gone with a 4l80... I also seem to think he broke the output shaft on the level 6... he was leaving on a 2 step though...
Old 02-07-2012, 08:44 PM   #8
ams450r
Drives: 2007 Chevy HD LTZ
Ya we broke the output shaft at Indy leaving of of Two-Step set at 5300 on 20" nittos nt05r. I would suggest going with a slick to give you some sidewall to handle the shock of leaving off of the two- step and 4-10 gears to help get the car moving with less rpm. Yes we are changing to RPM 4L80 tranny and brake and hopefully some slicks to handle the winter power upgrades. Good luck with your build and RPM will be the best tranny you can buy. And thing you can do to to help from shocking the drive train is your best bet. We did cut a 1.60 60 foot time the pass before output failure. I would stay away from drag radials if at all possible.
ams450r is offline   Reply With Quote
Old 02-07-2012, 09:19 PM   #9
Whipped416
Whipped416's Avatar
so u launched at 5300 and had 410 gear? also how did she shift just for street racing compared to stock ?
thanks for all the help ams450
Old 02-08-2012, 01:04 AM   #10
ams450r
No we had 3-70 thur a DSS 9 inch. Shift just fine we had the ZR1 clutch set up which after every pass the clutch would go to the floor just like other have gone thur. But street use was no problems. I see you have a whipple supercharger so you make low end power where we are procharged so leaving will not be problem with your set up. But like said before you will need a slick to help will the drivetrain shock. With 20's there is not sideway to flex so the weak spot is the output shaft. Lingenfelter camaro has 4-10 and Rpm level 6 with face plated gear set. Call RPM and talk with them on your plans and they help you out.
Old 02-08-2012, 08:06 PM   #11
Whipped416
Whipped416's Avatar
yeah i went with there level six with a hendrix streetslayer triple (rps)
so im hoping this combo works out well and i am going to order a set of slicks for track days as well. i think i will be fine for spirted driving around town.. until my slicks get here... also were u able to shit over 6000k without any grind or hesitation?
Old 02-18-2012, 05:00 PM   #12
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
I shifted around 6500 mark, and it shifted great most of the time. After around 9-10 moths of track and street driving, second started to grind under WOT. I could granny shift second and still ran 11.6@12x! I was just going to send it in for freshening up over the winter, but broke. Now going with RPM 4L80!
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 06-27-2012, 03:24 PM   #13
fcu678
5Th Gen (Craig)
fcu678's Avatar
Drives: 2014 C7
Hey Whipped any updates on your level 6?? I broke the output shaft on my stock tranny at the F-body gathering in Atlanta for memorial day and went with the RPM Level 6. Car is still in Atlanta and should be shipped this week so. I'm sure it'll be fine for my type of driving, I haven't taken it to the track yet and may only do it once or twice but I do my share of spirited street driving which is how the output shaft broke
550 miles and 8.5 hours from home isn't a good feeling.
2014 C7
fcu678 is offline   Reply With Quote
Old 06-27-2012, 06:04 PM   #14
BullF-16
BullF-16's Avatar
Yes, i am interested also Blake. The TR6060 is the only thing in my car that has not been worked. Im more of an overall street/road course performance as my goal, well balance etc. Something that can do everything well albeit not great. Looking for a low to mid 10s with my drag wheel/tires setup then running down the Z06s on the road course with my Pedders Camaro wheel and tire setup and Justice/ZL1 sway upgrades.
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 11:34 AM
Ultimate Bolt-On Project or Racers Wet Dream? JusticePete Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 04-27-2010 05:01 PM
ProTorque Converters - FREE Shipping! tbyrne Transmission / Driveline 0 01-07-2010 01:36 PM
Will The Z28 Be as Powerful as The SS? Oracle646 Camaro ZL1 Forum - ZL1 Specific Topics 43 07-04-2009 03:16 PM
Gear Ratio/RPM/MPH Spreadsheet in MS Excel ... dougmac 5th Gen Camaro SS LS LT General Discussions 8 04-20-2009 07:19 PM
