Old 02-06-2012, 08:32 PM   #1
GraySS2011
GraySS2011's Avatar
Drives: 2011 Cyber Gray 2SS 6 speed
Question on TR-6060 Transmission
I read on the Camaro wiki page that the T6 is good for a maximum gearbox torque of 430 lb-ft ( 580 Nm )
So right now the stock LS3 MN6 claims 420 lb-ft ...
With folks adding intakes and exhausts etc I don't imagine it would be hard to reach the max of 430 lb-ft of torque or over that...
Has anyone who has added perfromance upgrades run into issues with their T6 transmissions?
Here is that link if some folks here have not seen it..good readabout these cars:
http://www.camaro5.com/forums/wiki.p...le=CAMARO+WIKI
Thanks,
Bob
2011 2SS RSS , MN6, CGM
http://www.angelfire.com/hi/nicecorvette <----- My Cars and Trucks
GraySS2011 is offline   Reply With Quote
Old 02-06-2012, 09:09 PM   #2
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
My motor puts out about 700 FT-Lbs tq. It dyno'd 611 Tq to the rear wheels. No problems yet
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 02-07-2012, 12:11 AM   #3
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I'm over 800 ft/lbs and nothing other than the synchros causing the second gear grind which were occurring before the build... and then the same thing with 4th gear after the build... but no structural damage so far... though I did just upgrade to the 9310 output shaft with the support bearing and a new input shaft/4th gear, because of the shifting problem...
With a few minor upgrades, the transmission will handle pretty much whatever you throw at it...
Old 02-08-2012, 08:28 AM   #4
RPM Transmissions
RPM Transmissions's Avatar
Drives: 2010 SS
The torque rating of a manual transmission is at the transmissions weakest link. So the 430ftlb rating is in 6th gear. 1st gear is capable of handling much more torque than 430ftlbs.
RPM Transmissions is offline   Reply With Quote
Old 02-08-2012, 10:49 AM   #5
Grabber
Just a car guy
Grabber's Avatar
Drives: 2016 Durango R/T AWD
TR6060 transmissions have proven to handle over 800 Ft. Lbs in many applications.
If something goes out, you can get a rebuild kit for failry cheap. However, if you are between 400-500 ft. lbs, you should have zero issue.
2014 5.0 - Ported CobraJet Manifold - SCJ Mono-Blade TB - Kooks 1-3/4" LT Headers - Kooks O/R H-pipe - Custom Intake - McLeod clutch line - Borla S-Type Axle Backs - AED Tuned - 443 RWHP / 388 RWTQ - GONE
05 GT - Sold
03 Cobra - Gone (Never Forgotten)
Grabber is offline   Reply With Quote
Old 02-08-2012, 12:06 PM   #6
CyberPredator
50 Shades of Prey
Drives: TT/SS
708 wtq only issue is second gear grind that was there when it was stock. 26XXX miles. Hope that helps.
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
*/ *\ * FREE SHIPPING ON ALL 2011 CAMARO'S - PREFERRED PRICING FOR EVERYONE * / * \ * CamaroScotty Dealer Camaros for Sale 1 11-06-2010 11:27 PM
