SDTW Custom Wheels & Tires
Old 04-26-2009, 01:24 PM   #1
kanys
kanys's Avatar
Drives: 2010 Camaro
When to upgrade
I am going to get the GMPP intake some time soon for my Camaro, and was wondering if it is best to install it before or after breaking the car in?
kanys is offline   Reply With Quote
Old 04-26-2009, 01:53 PM   #2
SemperFi
U.S. Marine Corps
SemperFi's Avatar
Drives: 2009 Ducati Streetfighter
Interesting question. And I also wonder where the line is for voiding the warranty with mods. I doubt the intake would void it, but still. gotta be careful.
Texas Residents: Join the Texas social group!
Semper Fi!
SemperFi is offline   Reply With Quote
Old 04-26-2009, 04:30 PM   #3
kanys
kanys's Avatar
Drives: 2010 Camaro
Yeah thanks for the warranty warning. I asked about this a while ago and said it wouldn't since it is a GM product and pretty minor but it would be good to double check.
Old 04-26-2009, 05:07 PM   #4
SemperFi
U.S. Marine Corps
SemperFi's Avatar
I just read in another thread that it would clearly void the warranty for the original intake, and if any damage to the engine occurs from the aftermarket intake, it will not be covered. Which you have to be careful about, because I am sure they would be eager to bullshit you and tell you that the intake was the problem.
Anyway, i wish somebody that knows would answer this already.
Semper Fi!
Old 04-26-2009, 05:25 PM   #5
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
thing is, nobody knows because every dealership is different in how they handle these situations.
THE EVIL TW1N is offline   Reply With Quote
Old 04-26-2009, 06:40 PM   #6
SemperFi
U.S. Marine Corps
SemperFi's Avatar
talkin about the original question. not the warranty issue, which was just a side concern of mine.
Semper Fi!
Old 04-26-2009, 10:52 PM   #7
SemperFi
U.S. Marine Corps
SemperFi's Avatar
Originally Posted by Libertyforall1776 View Post
Well, if you add an intake, and removed the MAF screen, you could have a bigger engine damage potential... Don't do stupid things to void your warranty!
MAF screen? English translation.... ?
Semper Fi!
Old 04-26-2009, 11:24 PM   #8
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
MAF = Mass Air Flow sensor. It's one of several sensors used by the ECU to determine the mass of air entering the engine. If the mass of air is known, the engine can determine the proper amount of fuel required to produce a "perfect" combustion, at a ratio of 14.7:1. That means (basically) for one gram of fuel (or one unit of mass), 14.7 grams (or 14.7 times as much air mass) is required for a "perfect" combustion. This is called the stoichiometric ratio.
However, if I'm not mistaken (and I very well could be), I think the LS engine series uses a cold wire MAF sensor. These are different from the old hot wire sensors. The hot wire sensors used a screen, which restricted airflow. The newer cold wire sensors use 3 wires, one of which only goes half way across, which tend to flow better than the old screen styles. So I don't think there's a screen to remove on the LS3/L99. However if I"m wrong, someone PLEASE correct me. I did a quick search for a pic, but couldn't find one. If you look at the aftermarket sensors, you'll notice they all use the coldwire style, because they flow better. GM realized this and I THINK uses this style on all their engines now. Anyone know for sure? Spike, this seems like the kind of question you're good for answering.
UsedTaHaveA68 is offline   Reply With Quote
Old 04-26-2009, 11:29 PM   #9
lnsjr1
Drives: 02'Z28 07'CTS 03'HD Fatboy
English....
The factory chokes them down to make emissions and MPG standards..and oh yeah warranty time frames
lnsjr1 is offline   Reply With Quote
Old 04-26-2009, 11:31 PM   #10
lnsjr1
As long as you do not go internal on the engine, 50 state street legal parts should not void your warranty, unless the dealership are dicks about the repair in question.
Old 04-26-2009, 11:37 PM   #11
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
You don't have to wait for break in. I'm doing this mod as well. Gotta get that ugly intake off this beautiful car. Yes, I am mainly doing it for cosmetic purposes. You won't notice any difference in power at all.
Old 04-27-2009, 01:31 AM   #12
Never2LowChevy
Banned
Drives: bagged 4 door dually on 22s
Its just a cold are intake and wont make much difference. Plus it just bolts on, so its not like you cant put the stock intake back on if something happens and the dealer is a prick.
Never2LowChevy is offline   Reply With Quote
Old 04-27-2009, 09:48 PM   #13
SemperFi
U.S. Marine Corps
SemperFi's Avatar
Good info! thanks for the english ^^. And wont make much difference = 5hp?
Semper Fi!
Old 04-28-2009, 01:15 AM   #14
DevilKnightFalcon
DevilKnightFalcon's Avatar
Drives: 2010 Camaro 2LT/RS
Send a message via AIM to DevilKnightFalcon Send a message via Yahoo to DevilKnightFalcon
If you are going with the GMPP intake and have it installed before you take delivery of the car then it will be covered under your warranty. If you do it later then it will not. Be very wary when using 3rd party mods right away. I would check with your dealer first. Legally you should be able to do them and it would just void the warranty on the part you are replacing. The dealership should have to prove without any doubt that any damage was a result of the 3rd part part if they are going to not cover it.GMPP are way overpriced right now. I hope they will come down soon.
MBRP Catback/Magnaflow Resonated X/Airraid V2 CAI/Dash ABL/Interior LEDs/Custom Paint/Jet Coated American Racing LT Headers/High Flow cats/Trifecta Tune
DevilKnightFalcon is offline   Reply With Quote
GM performance part Air-box upgrade thoughts domano 68 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 11-29-2009 08:39 PM
Audio Upgrade Subwoofer VJCamaro Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 17 08-14-2009 09:09 AM
Need Help with upgrade exhaust and Electric cutoffs Camaro007 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 04-19-2009 10:44 AM
GMPP track pack exhaust upgrade? HP junky Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 37 04-01-2009 11:51 PM
