Jason 98 TA
Old 02-06-2012, 10:21 PM   #1
ztsmith86
ztsmith86's Avatar
Drives: 2010 Camaro 2SS/RS
Short Throw Shifter
I'm looking to purchase a short throw shifter kit. I plan on keeping my stock grip and boot. Can anybody recommend one that they have really liked? Thanks
2010 Camaro 2SS/RS LS3 Inferno Metallic
TSP 1 7/8" Long Tube Headers 304 SS MagnaFlow 2.5 Street Series Catback Exhaust K&N Cold Air Intake Comp Cams Camshaft227/235 .639"/.646"114LSA+2.5 REV 2.165 Hollow Stem Stainless Steel Valves Manley1.59 Stainless Steel Exhaust Valves GM LS7 Hydraulic Lifter Kit Katech CR-5 Timing Chain Manley Hardened Pushrods Comp Cams LSX Rocker Arm Trunion Kit A.I.R. Ported Cylinder Heads Catalytic Converter Delete
ztsmith86 is offline   Reply With Quote
Old 02-07-2012, 09:00 AM   #2
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
I bought the MGW because it replaces the whole shifter not just the shaft like most . Its very well made and they even give you noise reduction pads that you wont see with other shifter companies. The MGW accepts the stock shift knob and they also sell the adapter if you want to use a different shift knob down the road. I love it, they are very nice and helpful with questions and concerns too. good luck with your choice.
IDEALG is offline   Reply With Quote
Old 03-11-2012, 11:00 AM   #3
pistolgripcopo1
pistolgripcopo1
pistolgripcopo1's Avatar
Drives: 2010 SS Camaro Carbon fiber gray
You really doin't need the entire assembly unit. The GM assembly unit is strong enough. Why spend the extry m$$$$.
pistolgripcopo1 is offline   Reply With Quote
Old 03-11-2012, 12:13 PM   #4
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
In my opinion the GM unit may be strong enough, but that is not why I changed mine out to MGW, I could not stand the soft squishy rubber shift feeling of the stock shifter base. Not to mention the weak centering spring that does nothing to help get faster 2-3 shifts. The only reason GM made it that way was to accommodate the general car buying public and keep the shifter quiet. Changing out just the stick is not going to change that feeling, it will shorten the throw, but not the squishy shift feeling. I like a nice solid shift. Not being harsh here just giving my 2 cents.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 03-11-2012, 02:41 PM   #5
IDEALG
IDEALG's Avatar
Yes the stock shifter is sloppy, my mgw is firm and you feel control
Old 03-12-2012, 10:50 AM   #6
99articfrc
99articfrc's Avatar
Drives: 2011 1SS RS summit white M6
im very happy with the slp shifter. not too short of a throw but very solid feel, no noise and $116.00 from gmpartshouse.com
2014 1ss rs summit white m6, npp
99articfrc is offline   Reply With Quote
Old 03-12-2012, 12:09 PM   #7
ElektraSS
Elektra SS
ElektraSS's Avatar
Drives: 2010 Camaro SS
I have a Findaza Short Throw Shifter and Flywheel. I have been very pleased.
2010 Aqua Blue, K&N CAI, RK Side skirts, hood, and spoiler. Borla Exhaust/CATS, 22 TSW Wheels, Fidanza Short Shifter and Flywheel, performance chip, Halo's. Twin Turbo in progress!
ElektraSS is offline   Reply With Quote
Old 03-12-2012, 12:56 PM   #8
IronToss
Corporate Lackey
IronToss's Avatar
Drives: 2010 2SS/RS
The Hurst STS allows you to use either the classic chrome shaft/shifter ball or the stock OEM shifter knob and bag. I haven't installed mine yet (sitting in the trunk) but have been in a Camaro that had it and was very impressed with it.
2010 Camaro 2SS / LS3
-- Exterior: Black w/ IOM Stripes \\ Interior: IOM w/ Sunroof
-- RS Package / OEM Ground Effects / Volant Intake
-- Flowmaster AMT 3" Catback / Hurst Billet-Plus 2 Shifter
IronToss is offline   Reply With Quote
Old 03-12-2012, 03:58 PM   #9
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Hurst
Old 03-12-2012, 04:03 PM   #10
Camaro21
Drives: SOLD - 2013 M6 ZL1
I also have the MGW Shifter and Love it...
Camaro21 is offline   Reply With Quote
Old 03-12-2012, 05:51 PM   #11
pistolgripcopo1
pistolgripcopo1
Yea but why spend the extra m$$$$, with the extra money you save, you could get a cold air intke and gan 15 more HP. at the rear wheels
Old 03-12-2012, 05:59 PM   #12
pistolgripcopo1
pistolgripcopo1
THE way the HURST unit is put together looks flimz to me, The way the shift lever connects to the upper stick attachment with two hex screws, could lead to wobbeling from left to right, and its expensive
Old 05-03-2012, 09:38 AM   #13
lawman007
Panama-Gulf War Vet
lawman007's Avatar
Drives: '11 SW 1LT/RS 6M
You guys obviously wouldn't know a "long throw shift" if it bit you on the beehind!
I can tell you I drove a '72 Chevy Nova with a 307 V8 and Muncie 3spd Tranny. I can tell you that was fun to drive and never had a problem with it. This was a long throw transmission. But like every car you drive daily, you get used to it.
I have also driven the '64 Corvair, with a 6cyl(not a V6) which was air-cooled. This one had a 4spd transmission or gearbox. Now this was much trickier to drive and was prone to "missing" gears. I mean you shift from first to second and sometimes you made it, sometimes you would proceed to grind gears.
I would say this was a longer throw than the Muncie in that Nova.
Now these m6 transmissions in the Camaros are not "long throw" transmissions by any means. On the contrary, what you have here is a transmission that is very responsive and very quick on the draw. Very much a "short throw" transmission.
I would venture to say that most of you are not used to driving manual transmissions much less a "long throw" transmission, or you would know what you were talking about. I know because I have driven both. You're talking about getting an after market "short throw" shifter, which is fine. Your transmission is a "short throw" transmission and you are looking to get a "shorter throw" after market shifter. That's all. You're just looking to cut down your shifting time in the long run. As long as we know what you're talking about. How often are you going to take your Camaro from 0-60mph in the least amount of time? Unless you own a track, not very. Unless you're a track guy or racer all you're looking at is a daily commute. And that Hurst shifter looks really cool. I know. Have fun and stay safe!
lawman007 is offline   Reply With Quote
Old 05-03-2012, 10:14 AM   #14
pcrdude
pcrdude's Avatar
Drives: 2012 2SS/RS LS3 M6
MGW FTW
http://i331.photobucket.com/albums/l473/pcrdude/FJR.jpgMy other ride.
pcrdude is offline   Reply With Quote
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 11:08 AM
-LG Motorsports- Short throw Shifter for manuals *CAMARO5 Pricing* Anthony @ LG Motorsports Transmission / Driveline 7 03-08-2012 03:53 PM
"NEED" a Aftermarket Short Throw Shifter. 2012 Camaro Hellfighter V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 68 12-26-2011 03:46 AM
