02-06-2012, 09:27 PM | #1 |
Drives: 2010 SS Join Date: Nov 2011
how hard is it to change out rear diff?
i have a L99 with those 3:27 gears, and am wanting to change out to a M6 Rear diff with the 3:45 gears, like many have done on here
how hard is it? is there a DIY post? i looked and couldnt find any been wanting to do this for awhile to give the car more "oomph" you dont have to do a re tune to change this out do you?
2010 2SS Flowmaster catback, K&N CAI, hurst shifter, 5k miles!
02-06-2012, 11:26 PM | #2 |
Drives: 2010 SS, 06 SRT10 Ram Join Date: Nov 2011
When I broke my stock differential I put in a upgraded jre one with 3.45 gears.
I'm guessing you mean the whole case. It's not very hard. Lift the car, take wheels and all off, take off pipes, unscrew bolts lower it, replace with new case. It's extremely simple. Yes you need a re tune because you will be changing gears. Your shift points, speedometer, everything will need to be re-tuned. |
02-07-2012, 06:03 AM | #3 | |
i was hoping thats all there was too it....was just worried that maybe some sensor might be different and not re-plug in, or something technical like that thanks for the response
02-07-2012, 09:10 AM | #4 |
Drives: CGM,twin turbo, cam 2010 SS/RS Join Date: Mar 2011
rather simple really.
02-07-2012, 10:03 AM | #5 |
Just a car guy
Drives: 2016 Durango R/T AWD Join Date: Oct 2011
Just to clarify, are you referring to the Diff Cover/Girdle, or the Entire Differential?
As I recall, there is not a lot of room to change anything, so you will have to drop your rear-end. That means pulling the exhaust off, etc.
2014 5.0 - Ported CobraJet Manifold - SCJ Mono-Blade TB - Kooks 1-3/4" LT Headers - Kooks O/R H-pipe - Custom Intake - McLeod clutch line - Borla S-Type Axle Backs - AED Tuned - 443 RWHP / 388 RWTQ - GONE 05 GT - Sold 03 Cobra - Gone (Never Forgotten) |
02-07-2012, 10:10 AM | #6 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
with a buddy to help, it shouldn't be too hard....remove exhaust, axles, driveshaft and diff.
You'll need the right (big) socket for the axle nut (I think it's 32mm, but I'd confirm that first) and a torque wrench (and proper specs) to put it all back together correctly (unless you're just a "tighten the heck out of everything and go" type of guy). Use lock-tite on the driveshaft bolts...shouldn't really be any other surprises. And yes, tweak your tune to calibrate your speedometer.
NY5thgen.com
02-08-2012, 10:53 AM | #7 | |
just wanted to make sure it was a direct swap over....nothing like sensors that dont swap over, etc... thanks guys
Thread Tools | |
Similar Threads | ||||
Rear end "popping" noise, need help and opinions | Fiftydriver | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 35 | 09-19-2013 08:47 PM |
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ | JusticePete | Suspension / Chassis / Brakes | 111 | 05-08-2013 10:38 PM |
Rear Diff oil w/pics | maxhunter | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 19 | 08-06-2010 10:35 PM |
Rear Gear Change - Buddy System | Roger Ramjet | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 6 | 05-11-2010 07:33 PM |
Rear Diff and Tranny Fluid Change Meet? | Infern0 | USA - Mid-Atlantic | 5 | 04-08-2010 10:34 PM |
