Thread Tools |
"mild to wild" ZL1 modification??
Does anyone know if there is a mild to wild kit for the ZL1? Does anyone know if there is easily accessible fuse as on the ZR1 to pull so exhaust is always "open". This will be my first mod so I want to be prepared.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Oct 2011
I think 99.9 percent it will be the same. I hope it makes more of a difference than it did on my Z06 or it is borla hear I come for my first mod.
2013 ZL1
2013 Dart 2004.5 Ram cummins |
#3 | |
Lock and Load
Drives: 2012 ZL1 #141 Join Date: Nov 2011
Aggressive ZL1 Driver
Drives: 2012 AGM ZL1 Join Date: Oct 2011
The ZL1 should include a mild to wild setting in my opinion. Its a great setting for the exhaust system.
Young ZL1 owner eating Mustangs, Challengers, and Chargers daily for nutritious value.
Owner of Star, The Grey War Eagle |
#5 | |
Lock and Load
#6 |
![]() Drives: 12 ZL1,ZR1, 57, 60, 67 vette Harley Join Date: Jan 2012
I have a Sunset Creations Exhaust Commander in my ZR1 - it links with the garage door opener so you can open or close the exhaust with the push of a button and don't have to carry a remote - it is the best thing I did for enjoying the car because even at 638HP, it sounds pittiful at idle with the exhaust closed. I think that they have done the ZL1 right - the exhaust is open at idle and open when you are on it (over 3,000 rpm if I remember), but quiet when crusing on the highway. That may be just the perfect mix - if not, I will be pettitioning Sunset Creations to jump on the ZL1 bandwagon and program one.
#7 |
Mid-Florida Camaro Club
Drives: 2013 ZL1 #2303 Join Date: Jan 2011
I'm not sure that the Mild to Wild will be as simple on the ZL1 as it is on the Corvette's as the system has been slightly changed.
The following is the information that has been mentioned on the exhaust so far, and I have bolded the part that leads me to believe it will not be as straightfoward on the ZL1 as it is on the Corvette. Thankfully they have also changed it to be open at idle to 1,000rpm - so the need for the Mild to Wild is probably less so in any case.. The dual-mode exhaust of the ZL1 provides refined tuning (optimal noise and vibration characteristics) at low engine speeds and a low-restriction exhaust (enabling peak horsepower performance) at high engine speeds in one exhaust system. It utilizes a vacuum system similar to Corvette, coupled with twin valves located at the exhaust tailpipes. Although both Corvette and Camaro use vacuum actuated exhaust valves, there are differences. In the Camaro, the control software resides in the chassis control module that contains other software, to reduce the number of modules in the vehicle. The Corvette is calibrated to open the exhaust valves only during aggressive driving, when engine rpm and throttle position exceed certain values. The Camaro is also calibrated to be open during aggressive driving. In addition, it is calibrated to open the valves at engine idle and up to 1,000 rpm. |
#8 |
It does appear to be different and more involved than the corvette that is done simply by relpacing the fuse with a module that sends a signal to keep it open all the time. From the sounds of it, there will really be no need for a modification on the ZL1 since it is open at idle and with acceleration. I think Chevy learned their lesson (and listened to customers) and realized that people with high performance engines don't want them to sound like a 6 cyl at idle!
#9 |
![]() Drives: '12 ZL1 #1609 Join Date: Feb 2010
The fuse is F8 in the fuse box in the trunk according to page 10-53 in the owners manual. although what Modern07 is true, pulling the fuse should keep it open regardless of your RPMs...
Life is too short to drive cars that suck.
My build Thread In or around Savannah GA on the first Sunday of the month? Come meet with us here around 11 am! |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: still saving! Join Date: Feb 2010
We are currently working closely with Leea customs (nakid parts) the creators of the origional mild to wild on the Corvettes to develop one for the ZL1's and also for anyone who wants to retrofit thier standard SS to the ZL1 setup. I will keep you all posted
Patrick Trageser GM Parts House Our prices will NOT be beat! Find a cheaper price shipped and I will make sure we destroy it! ![]() Specailizing in all GM parts and Lloyd floor mats! 1-484-949-2099 |
#11 |
yes you can and we have instock
#12 |
![]() Drives: 2012 ZL1 Victory Red !!!!!!! Join Date: Nov 2010
ZL1 Current Status:6000 #1251
1000 Initial Order 11/28/2011 - 1100 Order accepted at dealer: 11/28/2011 - QBDTB8 2000 Order accepted by GM: 04/23/2012 2500 Order preferenced. Pulled to the production system 4/24/2012 3000 Accepted By Production Control: 04/25/2012 - TPW 05/07/2011 3100 Sequenced: 05/03/2012 3300 Scheduled For Production:5/4/2012 3400 Broadcast: 5/5/2012 3800 Produced: 5/11/2012 4B00 Available To Ship car is bayed: 5/13/2012 4200 Shipped: 5/30/2012 5000 Delivered To The Dealer: 6/5/2012 6000 Delivered To Customer: 6/6/2012 |
#13 |
for the best price on the mild to wild kit please email me at patrick@gmpartshouse.com
#14 |
This says it will work with visor mounted home link, but not other visor mounted remotes. My remotes are not visor mounted. They are on the right side of the reading lights. Buttons are actually a pain compared to other Chevy products. Anyone know if there are different remotes on ZL1 And if this works on the type I describe?
#15 | |
H-Town Camaro Club
Not sure what visor mouted remote you could be talking about other than garage door opener and those don't have a learn function. For the ZL1 it's open a great deal of the time anyway and the wild side isn't as noticeable as what you've probably heard on the vettes... |
#16 |
Are your remotes on the visor or to the right of the light? I would assume they are all the same. I have the sunset orange version on my zr1 vette and it just uses one button and toggles back and forth. It works great, but they don't have a ZL1 version yet. I don't want to remove my fuse or use hand held remote, but would like to be able to open at will although I agree will not make as much difference as it does no the vette.
#17 | |
H-Town Camaro Club
#18 |
Wehn they talk of the visor buttons that only applies to the vettes which actually had 2 different versions, a homelink which works with the m2w and one by lear which does not. The Camaros roof console usues the homelink system so it will work for you
#19 | |
![]() Drives: 12 ZL1 & 08 Suzuki Boulevard C50 Join Date: Oct 2011
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
#20 |
CaRaHoLiC
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp Join Date: Aug 2011
I don't see anywhere on the site the mild to wild is listed. The Camaro listings only go to 2011, and there is no ZL1.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams stage 3 cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, Tuning by Jannetty, install by me. |
#21 | |
http://store.gmpartshouse.com/partlo...catalogid=8669 If you are looking for the kit to add the exhaust you would have to email me as they are not on the site yet
| Thread Tools | |
| FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ | JusticePete | Suspension / Chassis / Brakes | 111 | 05-08-2013 10:38 PM |
| More Camaro ZL1 info!!! | MS3DALE | Camaro ZL1 Forum - ZL1 Specific Topics | 94 | 06-24-2012 09:44 AM |
| Need help with order please | zfuzz | Camaro ZL1 Forum - ZL1 Specific Topics | 7 | 11-22-2011 06:40 AM |
| ZL1 vs Corvette- Why do people insist this doesnt exist? Impacts on pricing/perf? | Arachnyd | Camaro ZL1 Forum - ZL1 Specific Topics | 60 | 09-19-2011 04:13 PM |
