HeadlightArmor
Old 02-07-2012, 11:24 PM   #1
import_killa
import_killa's Avatar
Drives: 2SS IBM
Part 2 of my build
Here for suggestions on what others have done and what they foresee on things I may have missed heres a quick run down of what I have right now and whats is about to be done.
Mods as of now:
1 7/8 AR headers
custom cam
upgraded fuel system with 85lb injectors
under drive pulley
TVS 2300 S/C 10lbs of boost
muffler delete
That's 659.9 RWHP 611.9RWTQ
mods coming next month:
21st CMC Forced Induction Shortblock (417 cubic inches)
-Brand New GM LS3 Bare Block
-Clevite main and rod bearings
-Hellfire rings
-Custom Diamond Low Compression Dish Pistons
-Callies Crankshaft
-Callies Rods
-Complete Balance and Blueprinted Assembly
Mast Motorsports 12 degree LS3 Black Label Cylinder Heads
-Hollow stem intake valves
-Inconnel Exhaust Valves
-.675 lift dual valve springs with titanium retainers, sping seats, locks, guide seals
-Custom rocker arm stands for factory rocker arm
-Custom Length Pushrods
-ARP Head Studs, 3 piece metal head gaskets
McLeod RXT Twin Disc Clutch assembly with Steel Flywheel
GM Slave Cylinder and Throwout Bearing
Drive Shaft Shop 1400 HP axles
Innovators West 10-rib drivesystem (21st CMC idler bracket and pulley)
Magnuson Products rear overdrive COG system
14lbs of boost
1 7/8 AR headers, roto-fab CAI with radiator, fuse box, and valve cover, cam, upgraded fuel system with 85lb injectors, under drive pulley, TVS 2300 S/C, muffler delete, aftermarket wheels, AAC headlights fogs sidemarkers footwell dome and trunk lights.....That's 659.9 RWHP 611.9RWTQ
T
import_killa is offline   Reply With Quote
Old 02-07-2012, 11:25 PM   #2
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
WOW how Much Spent so far ???
skipinminn is offline   Reply With Quote
Old 02-07-2012, 11:28 PM   #3
import_killa
Drives: 2SS IBM
to damn much...lol i could have already bought and paid for another 2SS
T
Old 02-08-2012, 12:21 AM   #4
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
WooHoo...
Subscribed and following along...
Old 02-08-2012, 12:36 AM   #5
import_killa
Drives: 2SS IBM
WooHoo...
Rob did I miss anything that I may need that you can think of?
T
Old 02-08-2012, 01:02 AM   #6
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
I don't see a cam shaft listed, unless I missed it...I know you already had a cam, are you going to reuse it...
In addition to the axles from DSS, are you going to do anything to the Diff...
You might check into the Janetty bigger diff caps and clutch fix for those one wheels burnouts...
Are you going to change the oil pump....Melling high volume???
I'm supposing that since the short block is assembled, and you already have a cam, that the gears and chains all match... and are you going to use a new timing chain...
Plugs, wires etc...
Looks like you have most of it covered....
While you have it apart, take a close look at the center carrier on the drive shaft... You've had some power to yours for a while...Mine was showing signs of wear... My new DSS 3.5 inch one piece is going in this week, along with the 9" kit...
Replace the bolts for the drive shaft while it's out... There have been enough problems that it's good insurance... and I don't ever recommend reusing them...in fact, I think GM list them as a one time use bolt...
Go ahead and order a drive shaft loop while you're under there...
Order a remote bleeder line for the trans slave cylinder...Mine is about three feet long and allows for clutch bleeding without ever getting under the car... It screws onto the fitting at the bell housing and tucks in behind the master cylinder... It is so convenient, I'm surprised GM doesn't do this from the factory...
These are a few things I can think of off hand... If I come up with any others I'll let you know...
ohh, are you going with the factory harmonic balancer or are you going with a performance piece... I still need to order one... just haven't done it yet...
If you have any concerns about the output shaft/support bearing on the transmission, let me know, and I'll put you in touch with the guys I ordered mine from...You might also change to all carbon fiber synchros and upgraded blockers if you have any trouble with gear grinding...
Old 02-08-2012, 08:47 AM   #7
Kyle.Gilmour
Charter Circle Member
Kyle.Gilmour's Avatar
Drives: 427 LSX- with TWINS
pretty amazing buddy. cannot wait to see why this goes together.
when do you plan on doing the 1400hp axels.... I have a set for you.... once I get the DSS 9in this summer.
SlowSS's Build Thread SlowSS Member Car Journals 47 03-01-2014 12:20 PM
Eric Berry's National Speed Super NZ1200 Camaro Build JusticePete 5th Gen Camaro SS LS LT General Discussions 259 10-03-2013 10:10 AM
JDP Motorsports 2011 1SS/RS LS3 "Silver Shark" Build! JDP Motorsports Member Car Journals 34 09-20-2012 04:53 PM
"Lyssa," the build of my tribute Camaro exflirt Member Car Journals 10 12-10-2011 01:08 AM
DSV Customs Real Carbon Fiber 4 Gauge Pack Finished!!! (Pictures Inside) dsvcustoms Cosmetics and Lighting Modification Discussions 23 10-15-2009 10:43 PM
