Old 02-08-2012, 07:25 PM   #1
cjon9657
cjon9657's Avatar
Drives: 2010 Camaro LS
Send a message via MSN to cjon9657
silly question
i own a v6 camaro but before i purchase a used SS differential, i need to know if i need to pay attention to if it came from a automatic or manual SS? or does it even matter? Thanks.
cjon9657 is offline   Reply With Quote
Old 02-08-2012, 08:06 PM   #2
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
yes it matters
Whipped416 is offline   Reply With Quote
Old 03-08-2012, 09:57 PM   #3
DennisfromIowa
DennisfromIowa's Avatar
Drives: 2012 2LS silver ice metallic V6
Originally Posted by Whipped416 View Post
yes it matters
A simple "yes it matters" isn't a answer but more like an opinion. If it truly matters share your reasons.
DennisfromIowa is offline   Reply With Quote
Old 03-08-2012, 10:08 PM   #4
RxDoc08
Jason
RxDoc08's Avatar
Drives: 2011 2SS/RS M6
I believe the only difference is that the SS auto comes with 3.27 gears and the manual comes with 3.45
RxDoc08 is offline   Reply With Quote
Old 03-09-2012, 01:18 AM   #5
DennisfromIowa
I'd like to do this swap too. Now going from a 2:92 rear gear to either SS readend would be a step up but what all is really involved? If going from a LS to a SS do I need the axles and hubs from the SS too or will the LS axles work with the SS differential?
Old 03-09-2012, 06:00 AM   #6
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
if your need help with the Driveshaft we can help
Driveshaftshop is offline   Reply With Quote
Old 03-09-2012, 09:58 AM   #7
RxDoc08
Jason
RxDoc08's Avatar
From reading another thread, it seems you will need the SS differential, axles, and new wheel bearing hubs. You may also need an SS driveshaft as well. You'll also need a tune to correct your speedometer for the different ratio gears. http://www.camaro5.com/forums/showthread.php?t=169341
Check out that thread, it may be of some help.
Old 03-09-2012, 09:00 PM   #8
DennisfromIowa
Thanks you. I'll give you a call when I decide.
Thank you very much. It answered many question I had.
A long response to fbodfather's question... Ravirn 5th Gen Camaro SS LS LT General Discussions 57 06-19-2010 07:19 PM
Pardon silly question - Does Camaro Have Suit Coat Hook? Patriot0290 5th Gen Camaro SS LS LT General Discussions 2 05-29-2010 08:15 PM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
Maybe a silly question about CAI St33lsinger Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 02-25-2010 05:09 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 07:53 AM
