HeadlightArmor
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 02-09-2012, 11:08 AM   #1
mstanford.us
Mark Stanford
Drives: Black 2010 SS LS3
Best 20" tires for autocross?
I've got the knock off 20" American Racing (mad in China) torque thrust weels. Fronts are 9" wide, back are 10" wide. This year I'm running Mickey Thompson ET Street II in P305 width on the back. What I'm looking for is front tires for autocross. Michelin Pilot Sport Cup looks good, though 245 width is a little narrow for 9" wide wheels.
Anyone have any other suggestions that Pilot Sport Cups for the front?
(Stock 245 Pzeros on front are pretty worn, and weren't that great for autocross last year.) The cheapest I can find these pilot sport cups is $477 per tire.
Anyone try autocrossing with Nitto or MT drag radials in the back?
Full BMR suspension poly bushings and roll bars will go on the car very soon. Hopefully a Janetty Racing 3.91 LPE gear pumpkin with BMR diff bushings as well.
My best 1/4 mile last season was 12.5@116mph. (60' times in the 2.1 to 2.0 range :-(
Yes, I want to autocross and drag race the same car, and not have to change wheels every weekend.
Mark Stanford
2010 M6
Midwestracing on FB
CAI, Kooks 1 7/8" 3", LG G6X3, Remote tune by Ted Jannetty JRE God of Tuning, ID 8500 injectors, ZL1 Fuel system, BMR, Yellaterra, Lunati Valve train, Street Slayer Carbon Twin. Numbers pending Dyno test.
mstanford.us is offline   Reply With Quote
Old 02-09-2012, 11:39 PM   #2
GMteSSted
000107, 000574 & 699059
GMteSSted's Avatar
Drives: 3 Pre-productions - Obsession!!
Bump - curious on the opinions too???
GMteSSted is offline   Reply With Quote
Old 02-10-2012, 04:10 AM   #3
michael's maro
RAM'S CAMARO
michael's maro's Avatar
Drives: 2010 camaro ss
I haven't ran any autocross events, all road racing events I run Toyo's R888 285/35/20
This a great tire, we are very limited on a 20in tire.
Eriq from TORQ runs these tires also, he has run several autocross events on these tires.
Best of luck....Michael
michael's maro is offline   Reply With Quote
Old 02-10-2012, 06:02 PM   #4
GMteSSted
GMteSSted's Avatar
you run the 285's on the front? Any clearance issues? Is your car lowered?
Old 02-12-2012, 07:52 PM   #5
L99CAMA2011
L99CAMA2011's Avatar
http://www.tirerack.com/tires/TireSe...35&diameter=20
Old 02-12-2012, 09:15 PM   #6
mstanford.us
Mark Stanford
Someone told me I would peel the drag radials off the rims trying to auto cross them. Anyone disagree with this statement, especially based on experience, VS opinion?
Mark Stanford
2010 M6
Midwestracing on FB
Old 02-13-2012, 06:59 PM   #7
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Don't run the drag radials on an autocross course. Drag radials, by design, have a weaker sidewall to allow for flex during hard launches. Autocrossing requires very stiff sidewalls to keep the tire from "rolling over". So, although the drag radials might not "peel" off, you will damage their sidewalls using them for auto-x.
In terms of 20" autocross tires, see my sig for what I'm running. Your best bet is to run as wide a tire as possible front and rear. I'm looking into running 10.5" or even 11" rims up front for my car.
R-compound tires are hard to come by in 20". In fact, I think only the Toyo R888s are 20" R-compound.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 02-15-2012, 09:52 PM   #8
SS_Killer
SS_Killer's Avatar
Drives: 2010LSM6
Mark,
Look at the Michelin Pilot Super Sports. They come in a huge variety of sizes, including 20 inch. From what I have been reading, they ought to be pretty decent auto-x tires. Not to mention a perfectly streetable upgrade from the p-zeros. Interestingly as well, these tires are significantly lighter than other brands in the same size. Like 4 to 5 pounds per tire.
And like I told you, I highly doubt that drag radials will pass tech inspection for auto-x.
K&N Typhoon, Spohn sway bars, Pedders front radius rod bushes, BMR cradle bushing inserts, Enkei Tuning Raijins (20.7 lbs ea.), Dunlop Direzza Z1 Star Specs, -2 front camber, -1 rear.
SS_Killer is offline   Reply With Quote
Old 02-15-2012, 10:48 PM   #9
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
I like the Nitto NT-05's...They work well on the autocross course, 200 treadwear, so pretty good grip and work for drag racing too...
So Cal Camaro is offline   Reply With Quote
Old 02-16-2012, 06:55 AM   #10
SS_Killer
SS_Killer's Avatar
Drives: 2010LSM6
Yes! NT-05s are also going to be very good auto-x tires for any of the street classes based on numerous reviews I have read.
Old 02-16-2012, 03:48 PM   #11
mstanford.us
Mark Stanford
Originally Posted by SS_Killer View Post
Mark,
I saw these on tirerack.com. Good price, and had 9.1 reviews for handling. They seemed to have higher reviews than other, more expensive tires with softer compounds. These Michelin Pilot Super Sports appear to have 300 treadwear, VS 220 for Perelli P Zeros.
Mark Stanford
2010 M6
Midwestracing on FB
Old 02-18-2012, 01:50 AM   #12
cajun1le
The Mechanic
cajun1le's Avatar
Drives: a sports car
Have you ever run any TLAC events in your region? If so, did they ever give you any grief for running 315 on the rears? Like you, I'm leaning towards going with 315's in the rears but I'm not sure if should stick with my original plan (using 285/35-19's). I realize some clubs may be stricter on the rules than others. I'm just trying to gather as much info before going out buying rims and tires for SCCA and NASA events that could potentially disqualify me from regional competitions.
cajun1le is offline   Reply With Quote
Old 02-18-2012, 04:28 AM   #13
michael's maro
RAM'S CAMARO
Yes I run 285's on all 4 corners, the rims I have are Forgeline the offsets are 38mm all 4 corners.
I also have MTI Racing coil overs, there are issues with clearance, what I had to do is change out the front 10in spring to a 8in spring, even with the Phadt coil overs you have to change out the springs.
Old 02-18-2012, 04:45 PM   #14
cajun1le
The Mechanic
cajun1le's Avatar
Are you running on 19's or 20's and what size rims did you go with?
20" TSW Nurburgrings Gunmetal on black w/ 295/40/20 tires (pics) Captain McFunk Wheels and Tires Talk Sponsored by The Tire Rack 70 03-10-2013 12:51 PM
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 11:51 AM
FS - 20" MS SS wheels, tires with sensors (~800 miles) Mint Condition NinoSS Wheels / Tires 5 02-22-2011 03:01 PM
FS: SS 20" Pirelli P Zero Tires Tremek Wheels / Tires 8 01-05-2011 11:41 AM
18, 19, & 20" replacement tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 3 03-29-2009 06:27 PM
