JUICEDMOTORSPORTS
Old 02-09-2012, 01:32 PM   #1
CyberPredator
50 Shades of Prey
Drives: TT/SS
possible sticking clutch solution!!
Over on the vette forum this is being talked about to prevent the sticking clutch issue. http://forums.corvetteforum.com/c6-t...ur-clutch.html
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 02-09-2012, 05:01 PM   #2
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
i wouldnt follow anything this guy says!!!!
Whipped416 is offline   Reply With Quote
Old 02-09-2012, 05:21 PM   #3
scott&keyla
scott&keyla's Avatar
Drives: 2010 ss(scott) 2011 rs(keyla)
Mine stuck alot and then someone told me to check my fluid and see if it was dirty. it looked like coke in it. i flushed it and change it everytime i go to the track and i haven't had a problem yet. good luck with it.
scott&keyla is offline   Reply With Quote
Old 02-09-2012, 08:14 PM   #4
mstanford.us
Mark Stanford
Drives: Black 2010 SS LS3
I had a stock clutch that stuck often on 4K launches. Replaced it with a centerforce dual friction with billet steel fly wheel. No more sticking clutch.
Mark Stanford
2010 M6
Midwestracing on FB
CAI, Kooks 1 7/8" 3", LG G6X3, Remote tune by Ted Jannetty JRE God of Tuning, ID 8500 injectors, ZL1 Fuel system, BMR, Yellaterra, Lunati Valve train, Street Slayer Carbon Twin. Numbers pending Dyno test.
mstanford.us is offline   Reply With Quote
Old 02-10-2012, 11:30 AM   #5
CyberPredator
50 Shades of Prey
Drives: TT/SS
Funny I talked to my tuner and he said the same thing
Old 02-10-2012, 11:45 AM   #6
SC2150
LOL!!! He is correct about the cooked and dirty fluid, but your tuners are also 110% right on. Isuspect they have seen his work before.
The true solution is a oneway self bleeding recirculating valve and additional 1 qt finned cooling resivoir with replaceable filter cartridges. With this system every time the pedal is depressed the special valve allows a small amount (same one NASCAR uses on their brake systems) of fluid to circulate while not affecting pedal travel so the fulid is consantly cooled, refreshed, and filtered before it is routed back to the OEM master.
Old 02-10-2012, 12:01 PM   #7
DandD
DandD's Avatar
Drives: 2010 2SS and 2011 LS
I am going with the separate fluid reservoir and the Tick Performance bleeder line, but what you are saying makes a WHOLE LOT OF SENSE SC2150 ! Is there a package as you describe available to us as I am still open to GOOD ideas for when I do this in a month or so. Thanks
Dan
Around here we like baseball, hot dogs, apple pie, and Chevrolet
DandD is offline   Reply With Quote
Old 02-10-2012, 12:08 PM   #8
CyberPredator
50 Shades of Prey
Drives: TT/SS
Interesting and how might one go about attaining such a thing
Old 05-11-2012, 01:00 PM   #9
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
If ya dont mind, fill me in on the Formato statements. I know Ive seen him around the forums for years and it seems to me he has done a ton of work for a ton of people. He not up to snuff or has he slacked in recent years?
Bo White is online now   Reply With Quote
ACT twin disk clutch install by Mike Norris Motorsports ducatisl V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 34 09-06-2016 07:38 PM
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 8 01-09-2015 04:11 PM
clutch sticking halfway fix? GQ4Life V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 10-13-2010 12:20 AM
deleted post Kubi V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 02-21-2010 05:35 PM
clutch sticking to floor BatmanX Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 11-21-2009 03:39 PM
