Solo Performance
Old 02-09-2012, 05:02 PM   #1
scott&keyla
scott&keyla's Avatar
Drives: 2010 ss(scott) 2011 rs(keyla)
Question differential seal leak
Just installed 1400 hp axles on my 2010 SS and now both seals are leaking. we tried installing them twice and still leaking. be very careful when installing any axles!!! the seals will leak if you hit them the wrong way. ITS NOT THE AXLE!!! get new seals $9.00 before install.
scott&keyla is offline   Reply With Quote
Old 02-09-2012, 05:15 PM   #2
jrpxxii
jrpxxii's Avatar
This is a common problem when installing new axles. The seals can easily be damage if you arent very careful when inserting them into diff. You will need new diff seals more than likely.
Old 02-09-2012, 05:17 PM   #3
bhall82
Drives: 2011 SS/RS
THIS
bhall82 is offline   Reply With Quote
Old 02-10-2012, 02:02 AM   #4
shines
Originally Posted by scott&keyla View Post
Just installed 1400 hp axles on my 2010 SS and now both seals are leaking. we tried installing them twice and still leaking. the second time the seal leak got worse. somebody out there had this problem? what should i try next?
If your car is lowered it could be that the axles are not penetrating the differential housing far enough to seal.
shines is offline   Reply With Quote
Old 02-10-2012, 02:08 AM   #5
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
The very first thing I would do is contact the DSS, and see what they have to say...I agree with the others on this thread, but before doing anything, I would contact the vendor and let them help/guide you....
Old 02-10-2012, 06:40 AM   #6
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
its more then likely the seals, be careful this is known problem with any axles being installed
Driveshaftshop is offline   Reply With Quote
Old 02-10-2012, 01:34 PM   #7
Zman12
Zman12's Avatar
Drives: 2010 Camaro 2SS
What's best way to avoid this? I will be taking out factory axles to to take diff out to install bushings. Just want to know the best technique if the seals or so fragile.
Thanks
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
Zman12 is offline   Reply With Quote
Old 02-10-2012, 03:02 PM   #8
Driveshaftshop
as the Splined area leaves the diff just be very careful not to catch the splines or the groove for the snap ring, the seal for some reason is very fragile and will rip or dislodge the spring easy. just be careful
Old 02-10-2012, 08:23 PM   #9
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
crap like this happens, not a dss thing , it just happens , frank is def good at getting you fixed up...
mikepage0007 is offline   Reply With Quote
Old 02-10-2012, 09:24 PM   #10
2L82RUN
Drives: ABM SS/RS
+1
2L82RUN is offline   Reply With Quote
Old 02-10-2012, 11:45 PM   #11
lionssfan
drive it like U stold it
lionssfan's Avatar
Drives: 2010 2ss camaro
they do have seal protectors that slid on over the seal and helps keep from nicking the seal. but I never use them if your very carful. the key is not to touch the seal with the end of the spline or snap ring. once the splines catch and starts going in your good from that point from damaging the seal. little grease won't hurt on the seal or mating surface on the axle shaft. the key is having full control as you come up on the seal with the axle end.
lionssfan is offline   Reply With Quote
Old 02-16-2012, 10:42 AM   #12
Zman12
Zman12's Avatar
Thanks!! gonna try new seals. will let you know if they work. two weeks with out my car sucks!!
How did you turn out?
Old 02-23-2012, 11:48 AM   #13
scott&keyla
Update!!! just left rpm after installing new seals. so far so good with the leaking!! no leak!!
Don't be scerd!! Run it!!
Old 03-03-2012, 01:13 PM   #14
scott&keyla
Well just got around to flushing the diff fluid and sure enough soon as it started draining out there went two small springs from my old seals!!! So now no leak and new seals. Ready to hit the track and run it.
