GM Parts House
Old 02-10-2012, 12:46 AM   #1
shines
Drives: 2010 Camaro SS/RS
One-piece DSS aluminum drive shaft limits
While on the phone with LPE to discuss oil leaking issues I'm having with their 9.5" differential, they asked what top speeds I run the car and said not to take a 1 piece drive shaft beyond 150 with 4.10 gears as it will eventually suffer a catastrophic failure. Can anyone else confirm this?
I've got an email into DSS. Hope it's rumor as I just bought the one piece shaft to match my LPE differential.
shines is offline   Reply With Quote
Old 02-10-2012, 12:53 AM   #2
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Originally Posted by shines View Post
While on the phone with LPE to discuss oil leaking issues I'm having with their 9.5" differential, they asked what top speeds I run the car. I told them 160-170 and they said not to take a 1 piece drive shaft beyond 150 with 4.10 gears as it will eventually suffer a catastrophic failure. Can anyone else confirm this?
How tall are your rear tires... 29.something... That's what I think the factory tire is...
Old 02-10-2012, 12:54 AM   #3
shines
315/35 20's. So I think they're just under 29"
Old 02-10-2012, 01:01 AM   #4
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
ok, then ask Frank if the shaft will handle roughly 8000 rpm.... Drive shaft rpm....They offer the high speed balancing for a bit more to my knowledge... up to or just over 9000 shaft rpm....
The formula is top speed * 336 * gear ratio /tire height....
In your case, I used 29.0"... so, 170*336*4.10 / 29.0
=8075 shaft RPM's...
This is from the DSS website... Ask Frank about it...
We will need to know the following:
  1. HP/Torque of the motor
  2. Transmission
  3. Rear ratio
  4. Rear tire size and height
  5. Top MPH the car will see
  6. Weight of the car with driver
With this info we will be able to check for overall strength, critical speed and durability needed. All shafts are hand made in our Carolina facility and carefully packed for shipping within days. If you’re looking for a racing shaft give is a call and let us make you a custom shaft for your application.
To check for critical speed, calculate this equation:
Top speed x 336 (a constant) x rear ratio (like 4.10), then divide it by the tire height (28” tall tire).
Hope this helps
Old 02-10-2012, 01:04 AM   #5
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
actually, 8165 is the critical shaft rpm for 170 mph.... based on a 28.68 inch tire height...and 4.10 gears
I looked it up just to be sure....
Old 02-10-2012, 06:11 AM   #6
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
I haven't received an email but i can help out, is the car auto or Stick ?
Driveshaftshop is offline   Reply With Quote
recommendations with my budget mikeSS Suspension / Brakes / Chassis 22 03-11-2012 06:08 PM
Marking drive shaft. 94ChevyCamaroV6 Camaro DIY & HOW-TO instructions & discussions 5 10-21-2011 07:13 PM
How much room to take out a drive shaft. 94ChevyCamaroV6 Camaro DIY & HOW-TO instructions & discussions 0 10-18-2011 05:58 PM
Drive Shaft Tunnel Bridge Halo2 Wheels and Tires Talk Sponsored by The Tire Rack 13 08-12-2009 10:40 PM
5th gen drive shaft area of concern. 13F20 5th Gen Camaro SS LS LT General Discussions 2 09-17-2008 07:44 PM
