Old 02-10-2012, 10:17 AM   #1
toilets
Drives: 2010 camaro
Cats
Can someone provide me some knowledge about converter removal on this car? I thought I read somewhere that removing the cataylitc converters is a very bad idea on forced induction cars because of the heat?
Can someone confirm or deny this?
Yes, I know its illegal but as people have seen in my previous posts, this will be a track car and will not need to be inspected.
toilets is offline   Reply With Quote
Old 02-10-2012, 10:38 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Cats' need heat to operate correctly. However - there are parameters in the PCM that keep enough fuel in the motor to keep the cats' from over-heating.
If you don't have to worry about smog or inspections, then get some long tubes on that thing!!! Removing cats' won't hurt anything except Mother Earth (if you believe that...), but you might have a problem with warranty, and probably need to have a custom dyno' tune in order to take full advantage of the substiantial flow increase.
Moved to Mod' Section
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 02-10-2012, 10:41 AM   #3
GM4lyfe
A GM nut-swinger!
GM4lyfe's Avatar
Drives: A Car
You'll be fine.
radz28: from Sacramento huh? I'm from there too
2004 GTO Quicksilver
2009 G8 Liquid Red
2005 CTS-V Black Raven
GM4lyfe is offline   Reply With Quote
Old 02-10-2012, 10:43 AM   #4
toilets
Drives: 2010 camaro
Sorry, should have posted in mods. Thanks for moving it for me.
I also heard headers as well was a no go.. Maybe because for me the money you can get power elsewhere for cheaper. May just need to go hf cats instead. Better for environment and won't smell like gas I guess
Old 02-10-2012, 11:04 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by GM4lyfe View Post
You'll be fine.
OH YEAH?! SWEET! Are you serving? How'd you end up in the UK?
WRONG. Long tubes are about the best bolt-on you can do for power without really adding additional stress to the motor. You are actually making it more efficient, so long as there's a good tune to keep the A/F and spark in optimal range. People have actually recorded gains in fuel mileage, too (me included).
High flow cats', IMO, aren't really worth the expense. OEM cats', nowadays, actually flow respectably. If you're environmentally aware, leave the OEM ones on there. High flow cats' don't burn-off the excess emissions as well, so that kinda' goes against your concern.
Having see what you've posted - I'd say leave the OEM cats' alone. If you want some more power, ARH has released CARB-legal shorties that bolt right-up to the OEM cats', give at least 10 RWHP (on a stock SS - ZL1s haven't, obviously, been tested yet) and you'll probably find more on a SC motor. Shoot - you might consider some pulleys to add a little more boost, too.
Just remember - you could be sacrificing warranties by mod'ing, so keep that in mind.
Old 02-10-2012, 11:11 AM   #6
GM4lyfe
A GM nut-swinger!
GM4lyfe's Avatar
Drives: A Car
You want as much flow as you can in a SC car. Engine is an air pump with another one bolted to it. The better it breaths the more power you make.
Yes I am. In the Air Force.
I agree..
2009 G8 Liquid Red
Old 02-10-2012, 11:14 AM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I agree..
Sweet. If I had a regret in my life, it was not serving...
Regardless - thank you for your service and I hope you come home safe
Old 02-10-2012, 11:25 AM   #8
GM4lyfe
A GM nut-swinger!
GM4lyfe's Avatar
Drives: A Car
Thank you! Thanks for the support.
2009 G8 Liquid Red
Old 02-10-2012, 12:03 PM   #9
toilets
Drives: 2010 camaro
Yeah, I'm not too concerned about power as I think I will have my hands full already. So let's talk sound? Stock cats with headers. Am I gonna hear a difference. I want loud.
Old 03-12-2012, 11:31 AM   #10
Mikes SS
Mikes SS's Avatar
Drives: '10 CGM 2SS/RS 6M
so does anybody know if the mid piped are the same on the ZL1 as on the SS's?
Mikes SS is offline   Reply With Quote
Old 03-12-2012, 11:36 AM   #11
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I would say it depends on what your end power goals are. I bet the stock manafolds can support a good bit of horsepower so in that respect, yes, if you don't want the added cost, it may not be needed (depending on what power you are looking to make). Case in point was my 04 cobra, I put high flow cats and magnaflow catback on but kept the stock manafolds. I only did a ported blower so was at about 509rwhp and 520rwtq .. however many with upgraded blowers (whipple / KB) hit 600rwhp with no issues using the stock manafolds. At a point it will be a restriction.
I would say you could run Long Tubes and no cats and not hurt anything as long as you tune for anything you must tune for as well. Just because of the blower doesn't make it unsafe (I would state the above statement for a tune as well for a N/A car).
EDIT: I would like to state though, if you do free the exuast up, you may see the boost pressure go down (while making more power). That is always good for the motor ...
Crowley
Crowley is offline   Reply With Quote
Old 03-12-2012, 11:37 AM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If you're talking after the cats', to the mufflers - they are different. There are no resonators and the pipe angles look different as they pass around the differential and it's cooler lines.
Old 03-12-2012, 11:43 AM   #13
toilets
Drives: 2010 camaro
Cool pic, but actually talking about the catalytic converters themselves. Ie if I decided to go HF cats or just a complete removal.
Old 03-12-2012, 11:46 AM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Ask and thou shall receive (thanks to Dragoneye )
fuse pull/ L99/ cats mgoodbar Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 10-30-2011 09:47 PM
Help with Hi-flow cats vs No Cats Arsenal11 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 10-26-2011 01:19 AM
Those with Headers. Cats or No Cats? Rogan Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 46 10-20-2011 09:58 AM
High Flow Cats with Shorty Headers? Aaron1121 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 07-06-2010 02:56 AM
Ohhhhh C-A-T-S Cats Cats Cats!!!!! acscamarochick06 Off-topic Discussions 1 01-14-2008 03:57 PM
