tandtperformance.com
Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions
Old 02-10-2012, 10:08 PM   #1
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2012 Camaro ZL1
Positive Displacement Blowers vs NA at Altitude...
What I'm talking about here is a recent magazine article pitting the Boss LS Mustang against the ZL1 at Inde Motorsports Ranch...approximately 4000 ft above sea level.
This post is less about the cars, and more about the effects altitude has on different form of induction.
It's always been my understanding that Positive Displacement supercharged engines have no more advantage at a higher altitude than a Naturally-Aspirated engine does. Whereas Turbocharged engines are virtually immune to altitude changes (to a point).
I've long thought that the blowers rotors, being belt-driven, cannot spin faster to compensate for reduced ambient pressure, so the engine would experience the same percentage of power loss as a NA motor.
Have I understood wrong this whole time?
"Keep the faith." - - Read Before You Post.
Old 02-10-2012, 10:15 PM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Yes.
SUX2BU is offline   Reply With Quote
Old 02-10-2012, 11:47 PM   #3
Jessika
Drives: Anything Blown
I don't know the answers, but a PD blower will lose approx 1lb of boost for every 3,000 ft of altitude.
Jessika is offline   Reply With Quote
Old 02-10-2012, 11:50 PM   #4
PQ
Drives a Maro
PQ's Avatar
Drives: Hybrid SS Camaro
2 words.......................
Pulley
Down
PQ is online now   Reply With Quote
Old 02-26-2012, 11:10 PM   #5
RSBAD454
RSBAD454's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via Yahoo to RSBAD454
Ask all the air planes that ran superchargers at much higher altitudes for many years.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=23393&dateline=127333  4105
2010 ABM RS/SS with a Procharged LS3, Flowmaster exhaust.
RSBAD454 is offline   Reply With Quote
Old 02-27-2012, 02:43 PM   #6
izaks
Drives: Chev Lumina 402
Correct.
If your "key on" map is 100kpa at sea level, and 85kpa at 6000ft (like we are) than you have "lost" .15kpa (2.175lb) in boost.
We have to run our Mp1900's (on the L76/L98) with the 2.8" pulley to compensate for the loss of boost due to altitude
izaks is offline   Reply With Quote
Old 02-27-2012, 03:12 PM   #7
old motorhead
Drives: Maggie blown LS3 vette
Both S/C and N/A will lose power as altitude increases. The difference is that you can spin the blower faster to make up for the loss. N/A, you don't have any options to get the power back. As long as you have plenty of turbo along with some type of boost control, the turbo will compensate for altitude increases without much adjustment.
old motorhead is offline   Reply With Quote
Old 02-27-2012, 03:43 PM   #8
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
Bingo, as someone that lives at high altitude the difference between here and sea level is pretty ridiculous. I could pulley down/up to compensate. A turbo wouldn't need a physical change just turn it up.
My car runs on acorns, the tears of ricers and these other slightly less important things...
2.9 Polished Whipple, Kooks LT 1 7/8 headers, HiFlow Cats, Kooks Sleeper catback, Cooling Mist Methanol Injection, PFADT Sport Sways, PFADT Springs, PFADT rear trailing arms, ADM intake, JDP stainless brake lines, Jegs Catch can, Stock SS wheels widened to 10 3/4, Hawks HPS Pads, Pedders Rear Subframe Bushing Inserts, BMR Center Brace, MSD BAP, AAC side markers, Emblem Pro's Custom Lighted Door Sills, Dash-Floor-Cupholder ABL lighting and other stuff....
bigsquirrel is offline   Reply With Quote
Old 02-27-2012, 03:46 PM   #9
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You guys aren't understanding his question.
What I think he means is let's say you have two cars, one NA and one with a PD blower, run the EXACT same time in the 1/4 mile and make the exact same rwhp at sea level. The OP thinks that at 4,000 ft DA the two exact performing cars will still perform almost exactly alike. Both will run about the same slower 1/4 mile time and both make about the same amount less rwhp.
I say that the while both cars will obviously be affected by the DA, the NA car will be much more affected by the change.
Old 02-27-2012, 04:12 PM   #10
asrautox
Drives: 2010 SS
Yes, it's vacuum versus boost, and it's pretty much all about manifold pressure.
NA MAP goes from say 14psi to say 12psi (-14%)
SC MAP goes from say 22psi to say 20psi (-9%)
NA loses 5% more power.
asrautox is offline   Reply With Quote
Old 02-27-2012, 10:22 PM   #11
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2010 2SS and 2004 WRX
Turbocharged engines are NOT immune to altitude, that much I know for sure.
I don't know of any CAR manufacturers that tune their turbos like AIRPLANE manufacturers do. In the turbo airplanes that I've flown, the general idea is that you can take an engine that makes 235hp at sea level N/A, and make that 235hp up to something like 14,000' and then slowly drop off in power at even higher altitudes, but generally not as much as if it was N/A.
This means the turbo is essentially doing nothing at sea level (just making up for slight losses in tubing and induction bends, leaks, spinning turbines, etc, at something only marginally above ambient pressure).
These engines are designed to operate continuously high altitude and at full power with the turbo running to produce it's "max rated horsepower", that is what it's designed for. So at high altitude, the turbo is spinning and so on. It's also real cold up there by the way.
A car's turbo is usually designed to be working hardest during maximum engine output, at sea level. If this weren't the case, you'd see turbos having a much shorter lifespan in places like Denver and others as they'd be working harder, but this is not the case. My turbo made maximum pressure at sea level (guage) and as I got higher and higher, it bled off gradually. I live at high altitude, so I saw the effects every day. The other issue is that it takes longer to "build up" the boost at higher altitude, so even if you can tune it for higher pressure, it lags more in getting there, but as far as I know, no car manufacturer actually designs and tunes their engines like aircraft manufacturers do. If anything, the turbo engine doesn't "drop off" as rapidly as the N/A engine, but the turbo's efficiency max is reached rather quickly if you are just going up in altitude and it may be spinning super fast, but not making all that much pressure anymore.
In any case, a simple way to think of it is turbo aircraft engines use turbos to maintain displacement as altitude increases. Car manufactuers use it to increase displacement at SL. Lot of people think that in a car it works like an airplane. It doesn't.
JamesNoBrakes is offline   Reply With Quote
Edelbrock SC vs Whipple? Rocky918 Forced Induction - V8 121 08-19-2011 09:59 PM
If You Live At High Altitude...Go With FI Prochargedchevyi Forced Induction - V8 6 08-22-2010 02:34 PM
Interesting Reading BlownChevy Forced Induction - V8 84 03-19-2010 06:04 PM
What is the displacement of an LS3? UCI CamaroFan Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 08-23-2009 09:47 PM
Positive Battery Cable issue (not near starter) shiftz33 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-12-2009 04:20 PM
