| Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires |
Thread Tools |
Prefer to be blown!
Drives: 2010 Silver/Black 2SS/RS 6 Speed Join Date: Mar 2010
Corvette Wheels for a 5th gen Camaro
I'm looking for a set of 18" wheels for my Camaro for use in auto-x events.
My criteria is listed below. 18" wheel is a must due to the availability of a greater range of racing tires. Tire size I'm long for is 285 to 305 all away around. No staggered patterns! Looking for a 40 profile or less. Need to check all the numbers to make sure that I'm not throwing the computer off too much. Facts: The Camaro bolt pattern is 5-120 while the Vette is 5-4.75 or a .65mm difference. They sell spacers\conversion kits for this combination. My car has PFADT coin-overs which are an inverted design, my rear 8" wheels with 275's on them rubbed because of that design so I will need spacers or a different offset anyway. The stock offset for the Camaro is 35mm The stock backspacing for the Camaro is ~6.5" (Need to confirm all of this) My guess is that the rear 9" wheels have a backspacing of 7.662 and the front 8" wheels have a backspace of 6.662. Tires I'm looking at right now are Kumho Exsta V710 or Hoosiers A6. I will be updating this thread as I get more information. Last updated 2-11-12
Prefer to be blown!
Tire Rack sells both of these.
Kumho V710 on the left and the Hoosier A6 (center) and another view of the Kumho on the right.
#3 | |
Quit being a pu$$y
Here are some wheels offsets I picked with stock shocks. http://www.camaro5.com/forums/showthread.php?t=201546
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS BLK IO interior Join Date: Dec 2009
The rear offset is 40mm
2010 BLK 2SS RS IOM
Quit being a pu$$y
#6 |
Prefer to be blown!
So the front is 35 and the rear is 40? I was planning on making all the measurements this weekend and got tied up with other things.
My biggest problem is the darn coil-overs in the front and their design not letting me use the extra 9" rear wheels with 275's on them without a spacer on the front. Thanks for the info folks!
#7 | |
Quit being a pu$$y
#8 |
Prefer to be blown!
I will try and get to it this weekend, thanks for the offer.
#9 |
Prefer to be blown!
Hankook Ventus Z214 C71
275/35ZR-18 95Z BLK This is the tire I'm looking at right now. ~$160 each. I wanted to go with a 285 to 305, the 275 should be a big difference with a 40 tread wear rating. Looking at 18x9.5 wheels right now. I'm shying away from the Vette wheels for now.
#10 |
Prefer to be blown!
Just ordered one 2007 Corvette Z06 wheel from Tire Rack to check for fitting. The size is 18x9.5 with a +40 offset and a 6.81 backspacing. Will report my findings. Things I'm trying to figure out is if the offset works for the front or rear and how the slightly different bolt pattern will work. I may need spacers with bolt pattern converters.
#11 | |
Quit being a pu$$y
The vette wheel you ordered will have 1" LESS inside clearance than your stock front wheel.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 45th Anniversary Edition SS Join Date: Jul 2011
Talk to the shops around us. Many of them have take off Vette wheels you can play with.
I have exceeded the character limitation for mods in a signature...
#13 | |
Prefer to be blown!
#14 |
Prefer to be blown!
Where did you relocate your washer bottle to?
#15 | |
Quit being a pu$$y
If you do use spacers make sure they are hub centric inside and out. Those are the only ones safe enough to use.
#16 |
Prefer to be blown!
The new 9.5" front wheels with 275's give me about 3/8 of and inch of clearance on the inside if I'm lucky. The close gap is caused by the PFADT coil overs and their inverted design. The adjustment ring is what's sticks out the most and was rubbing up against my 9" OEM wheels up front. Beware if you have these coil overs, you need to do your homework to make sure that the wheels you purchase will clear the coil overs. I will take pictures when I get the wheels installed. America's Tire was shipped three black and one polished wheel so I wasted my time driving into work today to get them installed.
#17 | |
Quit being a pu$$y
| Thread Tools | |
| CAMARO WIKI | Tran | Wiki | 42 | 05-18-2013 09:32 AM |
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 138 | 05-09-2013 03:58 PM |
| FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ | JusticePete | Suspension / Chassis / Brakes | 111 | 05-08-2013 10:38 PM |
| PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 449 | 04-24-2013 07:52 AM |
| GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA | irocnroll | 5th Gen Camaro SS LS LT General Discussions | 101 | 02-27-2012 12:25 PM |
