BORLA
Old 02-11-2012, 10:10 PM   #1
Nessal
Drives: Exige, Miata, Ghia
Lost a shifter clip!!!
I was installing my short shifter today and manage to lose one of the clips that hold the rod running through the transmission to the stick shift. GM apparently doesn't even stock these or something. I went to the dealer and no luck. Does anyone know where I can find spare ones? I'm afraid to drive the car with only one clip! Please help!!!
Nessal is offline   Reply With Quote
Old 02-11-2012, 10:12 PM   #2
IROCanSS
Drives: 89 IROC 350
That sucks! Good luck.
Sent as a message in a bottle.
Old 02-11-2012, 10:13 PM   #3
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
I wouldn't drive it with one clip. Maybe put a bolt in place of the pin until you find the clip. Try Patrick at Gmpartshouse. He has found some hard to find things for me.
bajamoon is offline   Reply With Quote
Old 02-11-2012, 10:28 PM   #4
Nessal
Yeah I checked GM partshouse but they don't have much selection as far as transmission part goes.
Old 02-11-2012, 10:29 PM   #5
Nessal
Good idea, I'll try that if I can't get it. Would it be ok to drive with the bolt for a while until I find a clip?
Old 02-11-2012, 10:29 PM   #6
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Take the chassis brace off, take off the two nuts holding on the heat shield..The clip you seek is on top of the heat shield somewhere!!!!!
90503 is online now   Reply With Quote
Old 02-11-2012, 10:31 PM   #7
Nessal
Was it the heat shield behind the brace or the one closer to the engine? I had to take the one behind the brace off as well because I dropped a bolt in there but saw no clip.
Old 02-11-2012, 10:34 PM   #8
90503
90503's Avatar
Get a magnet on a rod type thing, and poke around with it...it just might turn up..
Don't drive it without both clips...it will jam, you won't be able to shift, and may damage to other parts..
Old 02-11-2012, 10:36 PM   #9
Nessal
Thanks I will try it again tomorrow when the sun is out. If worse comes to worse I'll go to the hardware store to get a bolt to hold me off. The install was quick and easy until I lost that damn clip. I looked for 2 hours and couldn't find it. I felt all over for it and no dice. Hopefully tomorrow will be a better day. Thanks!
Old 02-11-2012, 10:38 PM   #10
90503
90503's Avatar
Instead of going to a bolt , if you cant get another one gm clip...take your pin and one good clip to the hardware store and get the right sized "c=clip"...
Old 02-11-2012, 10:40 PM   #11
bajamoon
bajamoon's Avatar
The heat shield that is in the middle of the car, the front heat shield doesn't come off easy and goes under the tranny. The grey chassis brace with 4 bolts( 2 on each side) and the 2 cheap nuts closer to the shifter area. Once loose shake it around and hope it comes out.
If you still can't find it email Patrick, I don't even look anymore just email. Good luck
Old 02-11-2012, 10:40 PM   #12
Drew10
Enjoys a good train wreck
Drew10's Avatar
Drives: 2010 IBM Camaro 2SS/RS
You could try blowing it off the top or wherever it is with compressed air. As long as you know about where it is.
Drew10 is offline   Reply With Quote
Old 02-11-2012, 10:41 PM   #13
bajamoon
bajamoon's Avatar
You mean "E" clip? Or are they the same thing?
Old 02-11-2012, 10:42 PM   #14
90503
90503's Avatar
that one you've got pictured...
... PRESS RELEASE ... The new design MTI Racing Sport shifter! ... MTI Racing V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 01-26-2012 11:52 AM
wtb oem shifter bag clip ddavis Transmission / Driveline 2 11-25-2010 10:52 AM
The New and Improved Hurst Shifter alfie43 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 29 08-11-2010 11:47 PM
MGW SHIFTER COMPLETE FIRST RUN OF 25 TO SHIP SOON...FULL SPECS AND PICS MGW V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 59 12-26-2009 01:49 PM
MTI Racings new 2010 Camaro short shifter MTI Racing V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 24 08-23-2009 09:07 PM
