02-12-2012, 11:16 AM | #1 |
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS ) Join Date: Nov 2009
Cammed SS goes into "limp mode".
Does anyone have a cammed SS with a tune go into the "reduced engine power' mode? It happens to mine fairly often, usually once every couple of days to several times in a single day. When it occurs one needs to pull over, turn it off and then wait at least twenty minutes for the computer to re-set before attempting to start it up again. If one tries to start it before the "rest period" has run its course, the car won't start at all, not even in "limp mode".
02-12-2012, 11:18 AM | #2 |
Drives: 2011 white camaro 6 speed Join Date: Jan 2011
probably need to check the blinker fluid
02-12-2012, 11:18 AM | #3 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
tuning problem?
NY5thgen.com
02-12-2012, 11:19 AM | #4 |
Look up the code that you pull when it goes into limp mode and start from there.. I can be a bunch of different things. Also, doesn't hurt to invest in a cheap scanner. They can also delete the code and remove limp mode without any wait....just pull over and erase the code and you're good to go until it pops back up. I would talk to whoever you had tune the car though.
02-12-2012, 11:23 AM | #5 |
CamaroFans.com
Tune is jacked... they probably just forgot to turn something off. Limp mode is a good thing... I wouldn't turn that off..
02-12-2012, 11:25 AM | #6 | |
el Ruco
02-12-2012, 11:28 AM | #7 |
Drives: nothing Join Date: Nov 2010
Son chingaderas!
02-12-2012, 11:30 AM | #8 |
Drives: '86 Monte Carlo SS Join Date: Nov 2010
02-12-2012, 11:32 AM | #9 | |
02-12-2012, 11:39 AM | #10 |
el Ruco
02-12-2012, 12:21 PM | #11 |
Drives: Camaro Join Date: Dec 2011
Maybe your car needs a Viagra.
02-12-2012, 12:30 PM | #12 |
Drives: 2011 Camaro 2ssRS Ls3 Join Date: Aug 2010
Tune problem. I've been cammed for 3 months no problem
02-12-2012, 12:53 PM | #13 |
el Ruco
02-12-2012, 01:04 PM | #14 |
Drives: 10 IBM SS RS/14 1500 Z71 Join Date: Jan 2010
Your tuner sucks. Contact someone from the boards, like Ted Jannetty. Problem solved, he's a tuning genius.
Thread Tools | |
Similar Threads | ||||
Inside Line Burnout Contest: SS, R/T, GT | DGthe3 | Chevy Camaro vs... | 133 | 05-27-2010 03:20 PM |
Livernois Head/Stage 2R Max Cammed SS Idle/Dyno Video | Chris@Livernois | Camaro Photos | Spyshots | Video | Media Gallery | 1 | 03-05-2010 05:09 PM |
Another Blown, Cammed 2010 Camaro SS Video | Chris@Livernois | Forced Induction - V8 | 26 | 01-17-2010 06:15 PM |
Blown, Cammed 2010 Camaro SS - Specs, Pics, Vid | Chris@Livernois | Forced Induction - V8 | 23 | 01-12-2010 07:08 AM |
Ricks SS...Cammed, Exhaust, & tuned Beast!! | Qwkss | Camaro Photos | Spyshots | Video | Media Gallery | 6 | 12-12-2009 12:47 PM |
