Old 02-13-2012, 01:54 AM   #1
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
Acouple gears questions
I'm ordering from Phastek Performance, do I need the full or half kit to come with the 4.10 gears that I am ordering?
Also, is anyone from northern virginia that can recommend a great mechanic that can install them? From everything that I've heard about gears, a small mess up or a missed detail can cost you greatly, so I want to make sure that I go to the right guy. Apologies if this has already been covered.
Cornflakes'Camaro is offline   Reply With Quote
Old 02-14-2012, 07:41 AM   #2
Jason@Phastek Performance
Jason@Phastek Performance's Avatar
Drives: 2010 Camaro
Send a message via AIM to Jason@Phastek Performance
Check with your installer first. He may already have the shims you will need to do the install. Most installers can get their own bearings if they need to be replaced. If he has access to the shims and bearings then you will only need to get the Half Kit. If not get the full kit and you will get everything you need to do a fresh build.
Jason@Phastek Performance is offline   Reply With Quote
Old 02-15-2012, 03:13 AM   #3
Cornflakes'Camaro
Roger that. Thank you Jason.
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
LS3 with 3.70 gears input? caverman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 33 07-02-2013 08:12 PM
questions questions questions ron8879 Suspension / Brakes / Chassis 12 07-02-2011 11:30 AM
Detailing questions answered here! Moose Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 636 06-04-2011 01:27 PM
Getting gears... QUESTIONS 10camaross V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 05-18-2011 03:28 AM
