Jason 98 TA
Old 02-14-2012, 04:22 PM   #1
simes007us
Drives: Black 2SS/RS Camaro
5 20 Fuse Pull
Hi Folks,
Either I've been driving like a grandma or doing the 5-20 fuse pull with 91 octane results in less power...
My car didn't seem to be as hostile as it normally is.
and of course I have no way to test this.
Anyone have some info on 91 octane?
simes007us is offline   Reply With Quote
Old 02-14-2012, 05:23 PM   #2
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
Thats all i run and after pull i did notice quite a difference. Throttle response was much better.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 02-14-2012, 05:37 PM   #3
Earl
Drives: Camaro
I don't follow.
Earl is offline   Reply With Quote
Old 02-14-2012, 05:42 PM   #4
M3NTA7
Drives: 2012 Camaro 2SS Transformer Edition
Did you fill it up with High Octane before the pull?
You need to make sure that the tank has been depleted of most of the Low Octane first, then fill it up with High, then do the fuse pull.
I did the fuse pull and it worked out great for me.
M3NTA7 is offline   Reply With Quote
Old 02-14-2012, 05:53 PM   #5
swizlstik
swizlstik's Avatar
Drives: 2018 Garnet ZL1 on order (VGXM1J)
Me too!!
swizlstik is offline   Reply With Quote
Old 02-14-2012, 05:57 PM   #6
simes007us
I'm guessing it had some small amount of 87 in it from the dealer >.>
I shall attempt this after my next fill up with 91 and see what happens...
Thanks for the help
Old 02-14-2012, 06:13 PM   #7
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
Did you put the fuses back in?
Project MantaRay...Underway
GunnyG is offline   Reply With Quote
Old 02-14-2012, 06:18 PM   #8
blackflag
blackflag's Avatar
Drives: 2012 2SS 45th
So my understanding of the Low/Octane tables in based on knock. This is how is works with EFI live on my 98 LS car.
You would think that the ECM would switch back to the high spark/octane tables if no knock was detected after a certain amount of time and load without having to reset the fuse.
So the fuse pull is just a instant way to reset the ECM so it will use the high spark/octane tables vs letting it correct on its own?
Havent tried it yet on my car, but was gonna log some with EFIlive to see whats its doing.
#1 2012 NMCA/LSX Challenge Series
2012 2SS 45th A6
Thanks to our Sponsors:
coldairinductions.com (Cold Air Inductions)
loughengines.com (Mike Lough Race Engines)
granatellimotorsports.com (Granatelli Motorsports)
blackflag is offline   Reply With Quote
Old 02-15-2012, 09:44 AM   #9
nitrorcr1787
nitrorcr1787's Avatar
Drives: 2012 2SS
Had a problem with my 2012, and posted, was told about the 5 20 fuse pull, and it worked great. Just remember to WAIT at least 2 hours before you put them back in...
nitrorcr1787 is offline   Reply With Quote
Old 02-15-2012, 11:27 AM   #10
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Unfortunately the V8 will not automatically switch back to the high octane table so you'll have to pull the fuses if you want to reset it.
Old 02-15-2012, 11:32 AM   #11
platinum ss
Brandon Gilpin
platinum ss's Avatar
Drives: 2011 Camaro SS / 2014 Fiesta ST
will this fuse pull work with a tuned car?
2011 Camaro 1SS Platinum ed. ls3 k&n CAI, BBK LT's, MBRP Cat Back, Vengeance Racing Kaotic Camshaft, Melling oil pump, Norris Catch Can, dyno tuned By AGP Speed & Custom, msd coils, taylor cables, Vmax ported throttle body, strut brace, eibach springs, hurst ST shifter.
Black on black, Private forged wheels, Oracle side marker lights, black tail light bezels, 3D Carbon body kit
platinum ss is offline   Reply With Quote
Old 02-15-2012, 11:44 AM   #12
garcmol
garcmol's Avatar
Thanks for the help
And remember, the car needs to sit for a while with the fuses out. Best time to do this is when you come home for the night, then install them the next morning. The longer they're out, the better!
Old 02-15-2012, 11:50 AM   #13
Nessal
Drives: Exige, Miata, Ghia
When I got my car from the dealer, I knew for sure they filled up with 87. So what I did was fill it up with 91 for TWO tanks without doing the fuse pull. Then on my third fill up, I did the fuse pull. The car pulls much harder than off the lot.
Nessal is offline   Reply With Quote
Old 02-15-2012, 11:51 AM   #14
Nessal
Dude....NOOOO WAYYYY.....
2012 SS L99 fuse pull 95birdible 5th Gen Camaro SS LS LT General Discussions 18 08-18-2011 04:30 PM
Need to know..help me clear the air...fuse pull BaddSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 07-21-2011 11:50 PM
Fuse Pull on LS3 Still Necessary? TheHorse13 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 07-20-2011 09:41 PM
FUSE PULL NUMBER montreal2010yellow Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 9 04-10-2011 04:13 PM
FUSE PULL CJ Offshoredude Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 11-26-2009 02:59 PM
