Old 04-28-2009, 08:31 AM   #1
Edrock
Edrock's Avatar
Drives: '10 Camaro 2SS LS3
OK...What exactly is involved with a "tune"
Hi all,
I've been reading so much in the performance section of this site about all the bolt-ons and other stuff you can do to squeeze out more HP and in just about ever case, each discussion usually ends with "...and a good tune" as the final step in performance enhancements or add-ons. Can someone explain exactly was is involved with a tune? Do you take your car somewhere and have it hooked up to a computer or something for some mechanic to make fine adjustments to timing, fuel/air mixture, etc.? What is a "tune" these days?
DT Shorties, Solo hi-flow Cats, X-pipe, resonator delete, Flowmaster Super-44s, VMAX TB, Stronger MAF, C.A.I. Intake with race scoop, and JRE Tune!
WOT is my happy place!!
Edrock is offline   Reply With Quote
Old 04-28-2009, 08:35 AM   #2
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
Originally Posted by Edrock View Post
Hi all,
You can do it yourself, but if you are unfamiliar with the practice it is better to take it to a professional. It involves hooking the car up to a little computer and adjusting the computerized controls. This can be to adjust for add-ons (like an exhaust system or CAI, etc) or can just to be adjust ignition control on a stock car. The factory tunes the car to get the maximum efficiency (usually gas mileage in these CAFE days). You can have it adjusted to get more performance (in the way of HP), but you will generally sacrifice some fuel economy. Make sense?
Inspector 17 is offline   Reply With Quote
Old 04-28-2009, 08:35 AM   #3
dodson914
Drives: 2008 2500 HD; 2008 G8 GT #199
The best thing to do is go to a reputable shop and have them do it on a dyno. Like you said, they fine tune different things on the ECM like A/F ratio, timing, etc. The dyno helps them make sure they get the most HP while still be safe to drive. There are other tunes that are the plug and play kind. But, each car is going to be a little different and everyone will have different mods so it really is best to get a custom tune from a reputable shop.
dodson914 is offline   Reply With Quote
Old 04-28-2009, 08:37 AM   #4
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
A laptop and brains.
Hylton is offline   Reply With Quote
Old 04-28-2009, 08:39 AM   #5
TXInfernoSS
Drives: 2010 Inferno SS
best way is laptop/programmer and do it at the track. unless you just want to be a dyno queen
TXInfernoSS is offline   Reply With Quote
Old 04-28-2009, 08:39 AM   #6
dodson914
Unfortunately I am missing the latter. That's why I go to a shop.
Old 04-28-2009, 08:45 AM   #7
Edrock
Edrock's Avatar
Ok...so I wasn't too far off. Now the next challenge would be to find a reputable shop around here that does that sort of thing. I'm sure there is but I haven't had a chance to look around. Thanks for the explanation all.
Old 04-28-2009, 08:45 AM   #8
Hylton
Hylton's Avatar
Seriously though, going to a shop won't necessarily get you the most efficient results. The best thing is to spend a Saturday at the local dragstrip and keep playing with the fuel/air/timing parameters until you get optimal results.
If you are going to a shop to get a tune, they MUST have a floor dyno and get them to take a reading before the tune so you can compare before and after results.
Old 04-28-2009, 08:48 AM   #9
dodson914
I have a few shops around me that do really good work. So I am not too worried about that. I don't really plan on going to the track all that often. So I just want to squeeze a few extra ponies out of my mods and make sure that it's not running too rich or lean. I thought about reading up on HPTuners forums to try and learn it myself. But, I think that will take me years of reading before I truly understand it all. LOL
Old 04-28-2009, 09:38 AM   #10
The_Blur
Rock Chalk
The_Blur's Avatar
Drives: Demon Super Sport
I've been in the same boat. I think I'm going to save up for some professional work backed by R&D from a known performance company rather than slapping on mods and hoping that I can figure out the software. I'd rather know that my car is fast and reliable than worry that each stomp on the pedal is bringing my beast closer to detonation.
Old 04-28-2009, 10:08 AM   #11
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
Here we go......
Motors are a big pump. Every mod you do allows the motor to breath better. Now the stock pcm has a series of tables which control fuel delivery and spark based on various sensor readings, like air flow, intake air, oxygen, what have you. When you allow the motor to flow better, like with headers or more seriously a cam or blower, you have to compensate by adding and evening out the fuel and spark for the new airflow. This way the car runs well/smooth/safe.
That's it in the most basic way I can explain.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 04-28-2009, 11:06 AM   #12
Late Model Racecraft
Late Model Racecraft's Avatar
Drives: 98 Camaro Race Car 3.96 @ 202 MPH
Exactly, we probably tune on average 3 cars a day. Its best to leave it up to the professionals. I know we are a little far from you but if you are interested in one of our packages you will not be dissapointed with our custom dyno tune once we are finished!
FIRST C7 Corvette in the 9's
LMR1200HP Twin Turbo C7 Package-9.35@155mph
2 TIME OUTLAW DRAG RADIAL LSX SHOOTOUT CHAMPION 2008/2010
9.47 ZR1 Corvette
FIRST 2010 CAMARO in the 9's
HOME OF THE FASTEST LSx'S IN THE WORLD!!
713-466-9900
WWW.LATEMODELRACECRAFT.COM
Too many PMs, please call or email instead, thanks!
Late Model Racecraft is offline   Reply With Quote
Old 04-28-2009, 11:17 AM   #13
vladkgb
Drives: 2000 Camaro SS Pewter
best tune is a "protune", thats when you take it to a dyno and have a dude with a laptop tune ur car and test the settings on the dyno. Every car is different, so you cant just buy a chip and get the best performance for your car.
Pro-tunes are expensive, but their well worth the money, for example after i installed my blower on my ls1 at 5psi i dynoed in at 410 rwhp with 390 torque, so i got it protuned, and after 3 runs on the dyno with my tuner experimenting with his laptop I was putting down 455rwhp and 420tq, thats a gain of 45 HP for only $400, best mod i ever did.
vladkgb is offline   Reply With Quote
Old 04-28-2009, 11:21 AM   #14
dodson914
Yeah, I will probably be hitting you guys up mid summer. What software do y'all use to tune?
L99 Delete Whats involved? jsharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 59 05-26-2009 10:54 PM
Saleen to get more involved with the new Camaro? OverAnxious 5th Gen Camaro SS LS LT General Discussions 104 01-15-2009 04:39 PM
