Gen5DIY
View Poll Results: Do you have 2nd Gear Grind, what's your shifter?
OEM 75 28.96%
OEM Hurst 75 28.96%
Aftermarket 49 18.92%
No 60 23.17%
Voters: 259. You may not vote on this poll
Old 02-16-2012, 10:01 AM   #15
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Mine was doing it bad at high RPM, I changed the break fluid with freash dot4 and put royal P syncro mesh in the trans... My trans works awsome now, I havent had problem since the day I did it.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 02-16-2012, 10:34 AM   #16
PIPE
Hating prius's since 1997
PIPE's Avatar
Drives: 2010 Camaro 2SS/RS (JENNA)
Mine ground with stock and continues with aftermarket . Mostly when trans is cold. When oil is hot it doesnt do as often
PIPE
PIPE is offline   Reply With Quote
Old 02-16-2012, 03:02 PM   #17
marticus24
Drives: 2012 ZL1
Oem and mgw
marticus24 is offline   Reply With Quote
Old 02-16-2012, 03:11 PM   #18
mattphp1
Little Rock
mattphp1's Avatar
Drives: 2011 2SS/RS IOM M6 & '02 Silverado
Oem and MGM both grind 2nd every now and then
2011 IOM 2SS/RS
Defenderworx black billet bowties & gas door
Roto-fab CAI
MGW short throw shifter
mattphp1 is offline   Reply With Quote
Old 02-16-2012, 08:55 PM   #19
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS 05 Jag S type R
Yes, aftermarket Hurst. Only when shifting rapidly, and only into second. Did it with the OEM shifter as well.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, No Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 02-16-2012, 09:39 PM   #20
Bad70supreme
Royal P guys, trust me it made a big difference.
Old 02-16-2012, 09:58 PM   #21
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
OEM Hurst and no grind
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 02-17-2012, 01:44 AM   #22
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
Mine only grinds when the fluid is cold. Using the MGW shifter. 34,000 miles. Plan to install RP fluid to see if that helps.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected
obe1 is offline   Reply With Quote
Old 02-17-2012, 04:12 AM   #23
Run and Gun
Run and Gun's Avatar
Drives: 2011 1SS/RS , 1966 GTO
Yes, OEM Hurst
A machine for shrinking time and distance.
Run and Gun is offline   Reply With Quote
Old 02-17-2012, 04:28 AM   #24
MaRoFreK
MaRoFreK's Avatar
Drives: IOM 1SS w/factory Hurst
Its kinda odd. I had the OEM Hurst and had grind under hard accel and even just poking around a few times. Now that I have the aftermarket Hurst I've only had it happen once and my tranny seems to be shifting smoother.. I don't know if it just the more connected feeel that makes it feel smoother or what.
"Success is following the pattern of life one enjoys most."
Stainless works Catback with Flowmaster Single Chamber Mufflers, Vararam, Factory Hurst, SLP SS emblems, SLP Skip Shift
MaRoFreK is offline   Reply With Quote
Old 02-17-2012, 01:11 PM   #25
pnyklr
Drives: A Gift From My Wife
Once my tranny is up to temp I can redline shift to 1-2 without it grinding.
-Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping.
08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery).
08/16/2011 - (5000) Vehicle has been delivered to dealer.
08/19/2011 - In my possession.
pnyklr is offline   Reply With Quote
Old 02-17-2012, 01:19 PM   #26
insomniac2k2
Drives: 2012 2SS/RS IOM
Yes, OEM hurst. My grind is very minimal. I find that I "grind" more when I put weight on the stick towards the driver side. If I allow the stick to drift downward and a bit to the right before I try to enter second gear, I seem to avoid the slight grind.
It's completely counter intuitive, hard to speed shift, and should be unnecessary..... but this is what I must do apparently...
insomniac2k2 is offline   Reply With Quote
Old 02-17-2012, 06:53 PM   #27
dcplus14
dcplus14's Avatar
Drives: '12 Camaro 2SS/RS/Hurst
Yep, OEM Hurst here.
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars]
dcplus14 is offline   Reply With Quote
Old 02-17-2012, 11:54 PM   #28
Run and Gun
-Funk
Same here
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
Another TR6060 with 2nd gear grind DRG BSTN SQUIRREL V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 12-16-2011 04:41 PM
2011 2SS/RS Problems: Engine Squealing, Brake Squealing, 1,2 Gear Grind. Please Help. qniknam V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 10-30-2011 11:36 AM
2nd gear and Reverse of Fiero grind/won't go into gears. Any takers? Arachnyd General Automotive + Other Cars Discussion 0 03-20-2011 02:05 PM
3rd gear grind ? Only 3000km Inferno Orange SS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 22 12-28-2010 04:25 PM
