BeckyD@RodgersChevrolet
Old 04-28-2009, 11:16 AM   #15
NUCAR
Drives: 68 big block
Originally Posted by MerlinZero View Post
the indexing issue is that it just plain doesnt work.
the dealer car at Friendly still currently has the problem.
Indexing of the windows is a method, like in a mustang, or a G6 GXP for us GM folks... When you open the door the window drops just about an inch... and when you close the door the window doesnt go UP until the door is closed. Its to help keep a good seal and for air pressure.
WHen the indexing isnt working, the window just doesnt move when the door opens or closes. The windows still function normally, they just dont "index"
It is also a timing issue. You do NOT want to quickly jerk the door open. There has to be a delay built into the latch release to allow the window to drop out of the door seal before the latch releases. Try to activate the handle, slight wait, then pull open to let the system do its thing. The end result is a much quieter interior due to improved sealing against wind noise!
NUCAR is offline   Reply With Quote
Old 04-28-2009, 11:20 AM   #16
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
Originally Posted by Supermans View Post
Perhaps when you try and roll two windows up at the same time, the car thinks it is a Prius and shoots to 80 mph uncontrollably and cannot be stopped by brakes.. GM is avoiding blaming the consumer for mistaking the foot pedal as a brake and is fixing this problem. Good for them..
quoted for sig
got tequila?
SilverTurtle is offline   Reply With Quote
Old 04-28-2009, 11:24 AM   #17
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Originally Posted by Chevyrocker View Post
Welcome to the site. Don't mind the constant flaming here, it's really just come of the newer members that get frustrated so easily. Feel free to ask anything you want, most of us are helpful.
Originally Posted by camaroqueen View Post
Thanx Chevyrocker!
And if that doesn't work you can always PM one of the mods.
Old 04-28-2009, 11:29 AM   #18
IROCanSS
Drives: 89 IROC 350
Originally Posted by levi1922 View Post
wait, if the window doesnt drop...does the door still open...?
Yes... but it wont close. When the door is closed the window closes the rest of the way and makes a wonderful seal. When you open the door, it drops and little and makes opening and closing the door easy.
Now if it is broken and doesn't drop, the door will open, it kinda pops out of the seal but you CAN NOT close it. It would need to be put down a bit, shut the door then put up. Not possible if you are exiting the vehicle.
It is not a timing issue, it works very quickly. By the time you open the latch, the window is down enough.
That help?
Old 04-28-2009, 12:05 PM   #19
GM'r_For_Life
9A108207
GM'r_For_Life's Avatar
Drives: 95 S10
For all of you planning on getting your windows tinted.
Let the tint installer know that your Camaro has indexing window.
If they do not know as the people that did my 2004 SSR the tint will end up short by the indexing height. They had to tear mine off and do them again.
They can take care of the problem by opening the door and then flipping the door latch in the door to make it think it is shut and the window will index back up.
GM'r_For_Life is offline   Reply With Quote
Old 04-28-2009, 12:08 PM   #20
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
Originally Posted by SilverTurtle View Post
quoted for sig
I am honored to be in your sig
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 04-28-2009, 12:11 PM   #21
IROCanSS
Drives: 89 IROC 350
Good advice. They got my C6 and my dad's Mustang right without telling them. Any good tint shop should notice this when they open the door the first time...
Old 04-28-2009, 01:06 PM   #22
Teleplayer
Drives: 92 Bonnie SSEI - 2010 GT Soon
That help?
Ok, so what happens in the middle of the winter when the car is all iced up, I go to open the door and the window can't possibly go down? (for those of you who live in warm climates, on some days a car can ice up so badly that you can't even open the doors, never mind a window!)
1) Will the door still open up?
2) Will the window motor burn out trying to go down?
3) Will the door then close? (apparently not)
Why does everything have to be so complicated?
I like doors that have the entire window frame as part of the door, then you don't have this issue.
1992 SSEI Supercharged 177k miles. 2010 GT coming soon.
Teleplayer is offline   Reply With Quote
Old 04-28-2009, 01:21 PM   #23
MontyCarlo
MontyCarlo's Avatar
Drives: 2010 2LT/RS auto IBM
Ugh, I know about those days. Sometimes in winter I'll pull up to a drivethrough, only to realize my window's frozen shut and I have to open the whole door just to tell them my order. Yet another reason for me to keep the Grand Am and never subject the Camaro to harsh weather.
FAQs:
1. No, I do not have any strong opinions about the Monte Carlo.
2. Yes, I know what my name looks like.
3. Yes, but the medication helps immensely.
2LT/RS IBM/gray #21,895 ordered April 21st, delivered July 3rd
MontyCarlo is offline   Reply With Quote
Old 04-28-2009, 01:26 PM   #24
TRENZMAN
Drives: 2010 Camaro SS/RS
If they ever get this first issue with the window indexing fixed you can fix it later without having to go to the dealer. Its easy to reset, close both doors, Roll both windows down and hold both switches down for 10 sec. Then roll both windows up holding the switches in the up position for a few seconds. That will solve the issue in the future if your battery ever goes dead and they need to be reset.
TRENZMAN is offline   Reply With Quote
Old 04-28-2009, 01:53 PM   #25
IROCanSS
Drives: 89 IROC 350
Wow great questions... I have no idea. The C6 never gets frost bite... I know what you mean though, here in Ohio that happens frequently in the winter. My guesses:
1) Will the door still open up? - PROBABLY
2) Will the window motor burn out trying to go down? - NOT LIKELY I BET IT WOULD TRY THEN STOP RUNNING. More likely it would rip weatherstrip if its really frozen.
3) Will the door then close? (apparently not) - PROBABLY NOT
Not the case on the corvette. Doors closed, windows up, hold up 3 seconds, release, hold up 3 seconds, release... done. Not sure how the Camaro will be unless you are sure this is the way...
Old 04-28-2009, 02:11 PM   #26
camaroqueen
Jules11 is home!
camaroqueen's Avatar
Drives: 2SS/RS/M-6 RJT/BLK 'Vert
Send a message via AIM to camaroqueen
Well, I was sorry I brought up a subject (window indexing) that had already been talked about. BUT, I found all the information very helpful! Thanks again everyone!
VIN: 2G1FT3DW7B9190673
03/16/2011 - (3000) Order accepted by production
05/19/2011 - Dealership received my baby and I picked her up on 5/20/2011!
camaroqueen is offline   Reply With Quote
Old 04-28-2009, 03:05 PM   #27
MikeZ28
Drives: '04 GTO, '00 Z28, '95 Z28
Somehow, we lived without "window indexing" on cars for many decades, but now everything has it. Just one more needless gadget that causes more problems than it solves.
MikeZ28 is offline   Reply With Quote
Old 04-28-2009, 03:24 PM   #28
dougmac
Drives: 2011 V6 MCA & 1969 GT Mustang
Wind noise can be pretty annoying in my '69 Mustang & '67 Fairlane (both real Hardtops with original roof rail weatherstripping) ... but on the 3 SN-95 Mustangs I've had without "INDEXING" ('94. '98 & '04), I've never heard ANY wind noise in 335,000 miles of driving !!
Yet, it had to designed into the 2005-up Mustang and now most new designs including the Camaro.
I suppose now there are people out there that have been brainwashed into thinking they can't buy a new car without it, so we are now stuck with one more unneccessary feature that may require servicing sooner or later. Kind of like power sliding doors & lift gates on today's minivans ... are these problematic features REALLY neccessary ??
Doug
dougmac is offline   Reply With Quote
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 08:57 PM
Problem Window Tinting? 87irocz Cosmetics and Lighting Modification Discussions 23 06-05-2009 08:17 PM
Some accessories can be listed on your window sticker. jjy59 Camaro Price | Ordering | Tracking | Dealers Discussions 12 03-23-2009 10:33 AM
Engine Oil problem. TonytheTiger 4th Generation Camaros 5 10-06-2008 08:07 PM
Problem with my v6 TonytheTiger 4th Generation Camaros 12 08-22-2008 02:34 PM
