02-16-2012, 09:15 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Nov 2011
STRUT BAR
Hey Guys, whats a good strut bar for a 2010 ss??
02-17-2012, 11:11 AM | #2 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Our strut tower bar for the 2010 is a pretty simple install, and can provide some tangible increase in handling performance. It's not going to be as drastic as say a set of sway bars, but as a finishing touch to your suspension package or as an engine bay dress up item it will work great. They come unfinished so a trip to your local powdercoater can quickly turn them what ever color you want to match your engine bay or exterior color.
Take a look at this video we took documenting the reduction in deformation between the strut towers before our bar to see what this piece can do for you: |
02-17-2012, 01:23 PM | #3 |
Drives: Race Car Join Date: Sep 2009
We have 3 different strut tower brace options available for the 2010 Camaros. They all work very well and attach directly to the shock towers. Here are a couple pictures.
02-17-2012, 04:08 PM | #4 |
Drives: 2SS RS Join Date: Mar 2010
I have the 3rd one above from BMR, but have yet to install it. I might be doing a supercharger this summer, and that one won't fit over a Magnuson. :-(
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
02-17-2012, 08:09 PM | #5 |
Do any of them fit over a Magnuson??
02-17-2012, 09:00 PM | #6 |
Love my BMR
02-17-2012, 09:57 PM | #7 |
Drives: Camaro Justice Join Date: Jun 2007
02-17-2012, 10:33 PM | #8 | |
COTW [4/23/12]
Drives: Camaro Of The Week. Join Date: Aug 2011
waiting to be shipped to my door from bmr. i have the 3rd one.
2010 Camaro V6 1LT | Kooks Catback Exhaust + MBRP exhaust tips | TF3 Stripes | GM Transformers Emblem and Door Sill | Stillen splitter | GMX rear diffuser | K&N CAI | Pulstar iridium spark plugs. | Gm High Wing Spoiler | BBK LT Headers | BMR 4 Point Strut Bar | BMR 1" Lowering Springs | ZL1 Side Skirt | Black Ice-olator | Trifecta Tune | My Build Thread |
02-19-2012, 09:46 PM | #9 |
02-19-2012, 10:02 PM | #10 |
We are not advocates for a strut tower bar. Our Pedders USA Camaro pulls 1.3G plus steady state turns without a strut bar. The 5th Gen shipped from the factory without a strut tower bar, until one was developed for the Vert. For the Vert a strut tower bar as well as under car bracing is required -- becuase they cut the top off the car. Here is the structure that was built in to your 5th Gen.
When GM designed the Camaro they built it well, very well. It was engineered to have an exceptionally strong monocoque. A solid monocoque translates into a higher perception of quality while enhancing performance and function. In the following series of pictures you can see how the 5th Gen Camaro has numerous 'chassis braces' built in at the factory using state-of the art design in the form of shape, construction and materials -- High-strength low-alloy (HSLA) steel is a type of alloy steel that provides better mechanical properties or greater resistance to corrosion than carbon steel. HSLA steels vary from other steels in that they aren't made to meet a specific chemical composition, but rather to specific mechanical properties. They have a carbon content between 0.05–0.25% to retain formability and weldability. Other alloying elements include up to 2.0% manganese and small quantities of copper, nickel, niobium, nitrogen, vanadium, chromium, molybdenum, titanium, calcium, rare earth elements, or zirconium.[1][2] Copper, titanium, vanadium, and niobium are added for strengthening purposes.[2] These elements are intended to alter the microstructure of carbon steels, which is usually a ferrite-pearlite aggregate, to produce a very fine dispersion of alloy carbides in an almost pure ferrite matrix. This eliminates the toughness-reducing effect of a pearlitic volume fraction, yet maintains and increases the material's strength by refining the grain size, which in the case of ferrite increases yield strength by 50% for every halving of the mean grain diameter. Precipitation strengthening plays a minor role, too. Their yield strengths can be anywhere between 250–590 megapascals (36,000–86,000 psi). Due to their higher strength and toughness HSLA steels usually require 25 to 30% more power to form, as compared to carbon steels Martensitic Ultra High Strength Steel Maraging steels (a portmanteau of martensitic and aging) are iron alloys which are known for possessing superior strength and toughness without losing malleability, although they cannot hold a good cutting edge. 'Aging' refers to the extended heat-treatment process. These steels are a special class of low-carbon ultra-high-strength steels which derive their strength not from carbon, but from precipitation of inter-metallic compounds. The principal alloying element is 15 to 25% nickel.[1] Secondary alloying elements are added to produce intermetallic precipitates, which include cobalt, molybdenum, and titanium. Photos originally posted 11.11.2008 by aston70 This isn't a 4th Gen, or a Mustang. Our Mustang project car took four different braces to get track ready. The Camaro took NONE. There is an excellent resource available here on Camaro5 THE Book on 5th Gen Suspension. It should have been titles the Book on the 5th Gen as it covers suspension, brakes, wheels, tires, exhaust, headers, superchargers, thermal management and more. Take a read through it. If you choose to add a strut tower bar it is cool. I am hoping you'll start with the foundation. |
02-19-2012, 10:03 PM | #11 |
I've been looking at Lakewood's bar. I believe it'll clear a blower.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
02-19-2012, 11:24 PM | #12 |
The BMR folks have been talking about a bar to fit over the maggie for a while, but I don't think they have one yet.
02-20-2012, 09:12 AM | #13 | |
06-02-2012, 08:37 PM | #14 |
Drives: 2010 camaro ss Join Date: Jul 2010
I get a lot of compliments with this and it looks clean
Thread Tools | |
Similar Threads | ||||
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ | JusticePete | Suspension / Chassis / Brakes | 111 | 05-08-2013 10:38 PM |
Pfadt Race Engineering DIY Drop Spring installation procedure | PfadtRacing | Suspension / Chassis / Brakes | 20 | 09-23-2011 09:31 PM |
SS sway bars on v6? | jatt5ab1soorma | Suspension / Brakes / Chassis | 9 | 07-07-2011 08:32 PM |
Better Handling | Tbanks | Suspension / Brakes / Chassis | 30 | 12-15-2010 11:50 AM |
